Anisotropic material definition and results issue
Might the problem be that the weak form in the code (definition of F) is using the gradient, rather than the curl? Note that, although the UFL curl operator is only defined for 3D vectors, you can conveniently define your own 2D scalar-to-vector curl as a Python function
def curl2D(v):
    return as_vector((v.dx(1),-v.dx(0)))
