Hello, how to build a graph on the x-axis by “xi”?
I’m trying to build an automodal solution, but I’m not sure if the graph is based on “xi”
import scipy.special
import math
import os
plt.figure(figsize=(10, 5), dpi=80)
set_log_level(LogLevel.ERROR)
alpha = 1
T = 1
M = 100
dt = T/M
nx = 65
t = -1
k0 = 1
A = 1
sigma = 2
n = -1/(sigma) ### n = -1/sigma - S mode, n < -1/sigma - HS mode, 0 > n > -1/sigma - LS mode
print(f'n={n}')
L_f = np.sqrt(2*k0*(A**sigma)*(sigma+2)/sigma)
mesh = IntervalMesh(nx, 0, L_f)
V = FunctionSpace(mesh, 'CG', 10)
xi = Expression('x[0]/(pow(k0, 0.5)*pow(A, sigma*0.5)*pow(-t, (1+n*sigma)*0.5))', degree=10, sigma=sigma, n=n, t=t, k0=k0, A=A)
if n == -1/sigma:
u0 = Expression('A*pow(-t,n)*pow((1-(x[0])/L_f),(2/sigma))', degree=10, sigma=sigma, t=t, n=n, A=A, k0=k0, L_f=L_f)
print('u02')
u0 = Expression('A*pow(-t,n)*pow((1-(xi)/L_f),(2/sigma))', degree=10, sigma=sigma, t=t, n=n, A=A, k0=k0, xi=xi, L_f=L_f)
def b1(x, on_boundary):
return near(x[0], 0)
def b2(x, on_boundary):
if x[0] <= L_f:
return near(x[0], L_f)
return 0
bc1 = DirichletBC(V, u0, b1)
bc2 = DirichletBC(V, 0, b2)
def q(uk):
return uk**sigma
ut = [interpolate(u0, V) for j in range(M)]
for k in range(1, M):
t = t + dt
xi.t = t
u0.t = t
u0.xi = xi
F = u*v*dx + (dt**alpha)*dot(q(ut[k-1])*grad(u), grad(v))*dx - (ut[0] - sum( (-1)**j * scipy.special.binom(alpha, j) * (ut[k-j]-ut[0]) for j in range(1, k)) )*v*dx
J = derivative(F, u)
problem = NonlinearVariationalProblem(F, u, [bc1,bc2], J)
prm = solver.parameters
prm['newton_solver']['absolute_tolerance'] = 1E-5
prm['newton_solver']['relative_tolerance'] = 1E-4
prm['newton_solver']['maximum_iterations'] = 50000
prm['newton_solver']['relaxation_parameter'] = 1.0
solver.solve()
ut[k].assign(u)
if k % 10 == 0 or k == M - 1:
plot(u,label='t=%.2f'%(t))
plt.title(f'alpha={alpha}, \u0394x={1/nx}')
plt.grid(True)
plt.ylim(-0.5, 25)
print('complete')
