Hi all,
I am trying to compute the mesh quality (scaled Jacobian) after a Lagrangian-type displacement step, where I manually modify the mesh coordinates via domain.geometry.x. Conceptually, some elements should be inverted after the displacement, so I expect some negative values of scaled_jacobian. However, with the code below, the minimum value of scaled_jacobian is still positive.
from dolfinx.fem import (
Constant,
dirichletbc,
Function,
functionspace,
assemble_scalar,
form,
locate_dofs_geometrical,
locate_dofs_topological,
from dolfinx.io import gmshio
from dolfinx.mesh import create_unit_square, locate_entities
from ufl import SpatialCoordinate, TestFunction, TrialFunction, dx, grad, inner
import pyvista
from dolfinx import fem
import time
import pyvista as pv
from dolfinx import plot
domain, cell_tags, facet_tags = gmshio.read_from_msh(
"rectangle_with_armature.msh",
comm=MPI.COMM_WORLD,
rank=0,
gdim=2
cell_markers = cell_tags
facet_markers = facet_tags
V_linear = fem.functionspace(domain, ("Lagrange", 1))
tdim = domain.topology.dim
fdim = tdim - 1
topology, cell_types, geometry = plot.vtk_mesh(V_linear)
domain.topology.create_connectivity(tdim, tdim) # cell -> cell
domain.topology.create_connectivity(fdim, tdim) # facet -> cell(
domain.topology.create_connectivity(fdim, 0) # facet -> vertex
domain.topology.create_connectivity(tdim, 0) # cell -> vertex
f2v = domain.topology.connectivity(fdim, 0)
c2v = domain.topology.connectivity(tdim, 0)
facets_16 = cell_tags.find(16)
verts_facets16 = np.unique(np.hstack([c2v.links(int(f)) for f in facets_16]))
x = domain.geometry.x
x0 = x.copy()
gdim = domain.geometry.dim
dx = np.array((0.5, 0.5, 0.0))
x1 = x0.copy()
x1[verts_facets16, :gdim] += dx[:gdim]
import pyvista
grid = pyvista.UnstructuredGrid(topology, cell_types, x1)
plotter = pyvista.Plotter()
plotter.view_xy()
plotter.show()
x_backup = x.copy()
x[:] = x1
cqual = grid.compute_cell_quality("scaled_jacobian")
q = cqual["CellQuality"]
print("cell_number =", q.size)
print("scaled_jacobian: min =", float(q.min()), " max =", float(q.max()), "mean =",float(q.mean()))
plt.figure()
plt.hist(q, bins=30)
plt.xlabel("scaled_jacobian")
plt.ylabel("Number of cells")
plt.title("Mesh quality: scaled_jacobian")
