I am trying to implement a DG-ALE solver for the following simple scalar advection problem: \frac{\partial c}{\partial t} +\mathbf{u}\cdot\nabla c = 0
The weak form is given by \int_K\frac{\partial c}{\partial t}vdx +\int_{\partial K}\mathbf{u}\cdot\nabla cvdx = 0. Integrating by parts and assuming incompressibility (\nabla \cdot u =0):
\int_K\frac{\partial c}{\partial t}vdx +\int_{\partial K}c\mathbf{u}\cdot \mathbf{n}vds - \int_K c\mathbf{u} \cdot \nabla v dx=0
With the choice of a numerical flux \hat{uc}, the second term can be written as: \int_F (\hat{\mathbf{u}c}\cdot \mathbf{n})^+jump(v)ds since \mathbf{n}^+ = \mathbf{n}^-. Finally the upwind and downwind fluxes:
uU = 0.5(\mathbf{u}\cdot \mathbf{n}+ |\mathbf{u}\cdot \mathbf{n}|)
uD = 0.5(\mathbf{u}\cdot \mathbf{n}- |\mathbf{u}\cdot \mathbf{n}|)
The time derivative is discretized using a second order backward difference scheme:
\int_K(\frac{1.5 c - 2 c^n + 0.5 c^{n-1}}{dt} )v dx
All this works to my satisfaction in the code below. As for the ALE implementation (which can be enabled by setting ALE = True
), I am trying to discretize the time derivative in the reference/initial domain, and the rest of the terms in the current domain. Hence the following kinematic quantities are introduced: the gradient G of the ALE deformation wrt to X0, and the corresponding determinant J=det(G) for times n, n-1. From my math, I get:
\int_K J^n(\frac{1.5 J c - 2J^n c^n + 0.5 J^{n-1}c^{n-1}}{dt} )v dx
However, the solution doesn’t look right (the mesh motion seems to be polluting the solution.)
Can anyone help spot the error in this formulation and/or the implementation?
import dolfin
from dolfin import dot, div, grad, jump
ALE = False # Turn ALE on or off
mesh = dolfin.RectangleMesh(dolfin.Point(0,0), dolfin.Point(2,2), 64,64)
# Trial and test functions for advected scalar c
Vc = dolfin.FunctionSpace(mesh, 'DG',0)
c = dolfin.TrialFunction(Vc)
d = dolfin.TestFunction(Vc)
cp = dolfin.Function(Vc) # c at time t
cpp = dolfin.Function(Vc) # c at time t-1
# initial condition for c
cp_initial = dolfin.Expression('(0.25 <= x[0] && x[0] <= 0.5 && 0.25 <= x[1] && x[1] <= 0.5) ? 1.0 : 0.0', degree = 1)
cp.assign(dolfin.interpolate(cp_initial, Vc))
cpp.assign(dolfin.interpolate(cp_initial, Vc))
# dummy convecting velocity - diagonal upwards at 45 deg
Vu = dolfin.VectorFunctionSpace(mesh, 'DG', 2)
u_conv = dolfin.interpolate(dolfin.Expression(('1','1'), degree =1), Vu)
# Second order backward difference time stepping coefficients
c1, c2, c3 = 3/2, -2, 1/2
dt = 0.01
t = 0 # start time
T = 0.5 # Total time
if ALE:
# ALE setup
# initial domain coordinates as dolfin func
ale_x0 = dolfin.interpolate(dolfin.Expression(["x["+str(i)+"]" for i in range(2)], degree=1),
dolfin.VectorFunctionSpace(mesh, "CG", 1))
G = dolfin.inv(dolfin.grad(ale_x0))
# UFL determinant of ALE domain transformation for previous two time steps, initially all equal:
J = dolfin.det(G)
Jp = dolfin.det(G)
Jpp = dolfin.det(G)
Vu_mesh = dolfin.VectorFunctionSpace(mesh, 'CG', 1)
u_mesh_cpp = dolfin.Expression(('cos(pi/2*x[1])*sin(pi/2*x[1])*pow(sin(pi/2*x[0]), 2.0)*sin(pi/2*t)*2', '-cos(pi/2*x[0])*sin(pi/2*x[0])*pow(sin(pi/2*x[1]), 2.0)*sin(pi/2*t)*2'), degree =1,pi=dolfin.pi, t=0)
u_mesh = dolfin.interpolate(u_mesh_cpp, Vu)
u_mesh = dolfin.Function(Vu)
u_mesh.vector()[:] = 0
# Output
xdmf_file = dolfin.XDMFFile('DG_advection.xdmf')
xdmf_file.parameters['flush_output'] = True
xdmf_file.parameters['rewrite_function_mesh'] = True
xdmf_file.parameters['functions_share_mesh'] = True
c_new = dolfin.Function(Vc)
c_new.rename('c','c'); u_mesh.rename('u_mesh', 'u_mesh')
while t <T:
n = dolfin.FacetNormal(mesh)
dS, dx = dolfin.dS(mesh), dolfin.dx(mesh)
# Upstream and downstream normal velocities
w_nU = (dot(u_conv - u_mesh, n) + abs(dot(u_conv - u_mesh, n))) / 2
w_nD = (dot(u_conv - u_mesh, n) - abs(dot(u_conv - u_mesh, n))) / 2
# Blending factor beta (0: pure upwind, 1: pure downwind)
b = 0
flux = (1 - b) * jump(c * w_nU) + b * jump(c * w_nD)
# Discontinuous Galerkin implementation of the advection equation
if ALE:
eq = (
Jp*(J*c1 * c + Jp * c2 * cp + Jpp*c3 * cpp) / dt * d * dx
- dot(c * u_conv, grad(d)) * dx
+ flux * jump(d) * dS
eq = (
(c1 * c + c2 * cp + c3 * cpp) / dt * d * dx
- dot(c * (u_conv - u_mesh), grad(d)) * dx
a, L = dolfin.system(eq)
dolfin.solve(a==L, c_new)
if ALE:
u_mesh_cpp.t = t
u_mesh.assign(dolfin.interpolate(u_mesh_cpp, Vu_mesh))
mesh.bounding_box_tree().build(mesh)
displacement = dolfin.Function(Vu_mesh)
displacement.assign(u_mesh)
displacement.vector()[:] *= dt
dolfin.ALE.move(mesh, displacement)
Jpp = Jp
Jp = J
J = dolfin.det(G)
for func in [c_new, u_mesh]:
xdmf_file.write(func,t)
cpp.assign(cp)
cp.assign(c_new)
print(f't={t}')
t+=dt
xdmf_file.close()
