Hello. I faced with the next problem: I generate the simple circle mesh using pygmsh library and save it in xml format. After that I try to load this mesh with Mesh dolfin object and create FunctionSpace. When I try to get vertex_to_dof_map, I faced with duplicates! Moreover, when I try to project some expression on this FunctionSpace, I get nan values in the tail of the projected function vector. The example below. Is it a correct behaviour? How could I get duplicates in vertex_to_dof_map? Thank you advance!
import pygmsh
geom = pygmsh.built_in.Geometry() # Circle mesh generation
geom.add_circle(
[0.0, 0.0, 0.0],
1.0,
lcar=0.1,
num_sections=4,
compound=True
mesh_data = pygmsh.generate_mesh(geom, prune_z_0=True)
meshio.write_points_cells("mesh.xml", mesh_data.points, mesh_data.cells)
mesh = Mesh("mesh.xml")
v2d = vertex_to_dof_map(V)
v2d_len = v2d.shape[0]
unique_v2d_len = np.unique(v2d).shape[0]
print(v2d_len == unique_v2d_len) # False -> v2d contains duplicates :(
exp = Expression("x[0] + x[1]", degree=1)
f = project(exp, V)
print(f.vector().get_local()) # nan values in the tail
I have found the solution. The reason why some elements in vector array was “nan” is that these elements was structural, generated by gmsh and not included in any cell. Solution of this problem was add “remove_faces=True” option in generate_mesh function. The complete code below.
import pygmsh
geom.add_circle(
[0.0, 0.0, 0.0],
1.0,
lcar=0.1,
num_sections=4,
compound=True,
mesh_data = pygmsh.generate_mesh(geom, prune_z_0=True, remove_faces=True)
print(v2d_len == unique_v2d_len) # True -> v2d doesn't contains duplicates!
f = project(exp, V)
print(f.vector().get_local()) # no one nan value
