Sure, as for the pde I’m trying to simulate, is the same I stated in this post.
My code is the following:
import pyvista
from dolfinx.fem import (Constant, Function, FunctionSpace, assemble_scalar,
dirichletbc, form, locate_dofs_topological)
from dolfinx.mesh import create_unit_square, locate_entities, meshtags
from petsc4py.PETSc import ScalarType
from ufl import (FacetNormal, Measure, SpatialCoordinate, TestFunction, TrialFunction,
div, dot, dx, grad, inner, lhs, rhs)
from dolfinx.io import XDMFFile
from dolfinx.plot import create_vtk_mesh
mesh = create_unit_square(MPI.COMM_WORLD, 10, 10)
V = FunctionSpace(mesh, ("CG", 3))
n_temp = 1.4
reff= -1.44*n_temp**-2+0.71*n_temp**-1+0.668+0.0636*n_temp
temp = (1+reff)/(1-reff)
A = Constant(mesh, ScalarType(temp))
u_ex = lambda x: x[0]**3*x[1]+x[0]**2*x[1]+2*x[1]**2+10*x[1]
mu_s = Constant(mesh, ScalarType(1.22))
D = Constant(mesh, ScalarType(1/(3*1.22)))
mu_a = fem.Function(V)
mu_a.interpolate(lambda x: 0.036 + 0.082*(np.square(x[0]-0.5)+np.square(x[1]-0.3)<=np.square(0.2)))
n = ufl.FacetNormal(mesh)
g = -ufl.dot(D*ufl.grad(u_ex(x)),n)
S = fem.Constant(domain, ScalarType(0.0))
u, v = ufl.TrialFunction(V), ufl.TestFunction(V)
F = D * ufl.inner(ufl.grad(u), ufl.grad(v)) * ufl.dx + mu_a * ufl.inner(u,v) * ufl.dx - ufl.inner(S, v) * ufl.dx
boundaries = [(1, lambda x: np.isclose(x[0], 0)),
(2, lambda x: np.isclose(x[0], 1)),
(3, lambda x: np.isclose(x[1], 0)),
(4, lambda x: np.isclose(x[1], 1))]
facet_indices, facet_markers = [], []
fdim = mesh.topology.dim - 1
for (marker, locator) in boundaries:
facets = locate_entities(mesh, fdim, locator)
facet_indices.append(facets)
facet_markers.append(np.full(len(facets), marker))
facet_indices = np.array(np.hstack(facet_indices), dtype=np.int32)
facet_markers = np.array(np.hstack(facet_markers), dtype=np.int32)
sorted_facets = np.argsort(facet_indices)
facet_tag = meshtags(mesh, fdim, facet_indices[sorted_facets], facet_markers[sorted_facets])
ds = Measure("ds", domain=mesh, subdomain_data=facet_tag)
class BoundaryCondition():
def __init__(self, type, marker, values):
self._type = type
if type == "Dirichlet":
u_D = Function(V)
u_D.interpolate(values)
facets = np.array(facet_tag.indices[facet_tag.values == marker])
dofs = locate_dofs_topological(V, fdim, facets)
self._bc = dirichletbc(u_D, dofs)
elif type == "Neumann":
self._bc = inner(values, v) * ds(marker)
elif type == "Robin":
self._bc = values[0] * inner(u-values[1], v)* ds(marker)
raise TypeError("Unknown boundary condition: {0:s}".format(type))
@property
def bc(self):
return self._bc
@property
def type(self):
return self._type
boundary_conditions = [BoundaryCondition("Dirichlet", 1, lambda x: np.zeros(x[0].size)),
BoundaryCondition("Dirichlet", 2, lambda x: np.zeros(x[0].size)),
BoundaryCondition("Robin", 3, (1/(2*A), Constant(mesh, 0.0))),]
#BoundaryCondition("Neumann", 4, g)]
bcs = []
for condition in boundary_conditions:
if condition.type == "Dirichlet":
bcs.append(condition.bc)
F += condition.bc
# Solve linear variational problem
a = lhs(F)
L = rhs(F)
problem = LinearProblem(a, L, bcs=bcs, petsc_options={"ksp_type": "preonly", "pc_type": "lu"})
uh = problem.solve()
uh.name = 'uh'
#Data extraction
W = fem.VectorFunctionSpace(domain, ("DG", 0))
grad = ufl.grad(uh)
grad_expression = fem.Expression(grad, W.element.interpolation_points)
grad_h = fem.Function(W)
grad_h.interpolate(grad_expression)
outfile1 = open("dofs.csv", "w")
coords = V.tabulate_dof_coordinates().reshape((-1,gdim))
for x in coords:
print(x[0],",",x[1],file = outfile1)
outfile2 = open("solution.csv", "w")
sol = uh.x.array
for x in sol:
print(x, file = outfile2)
outfile3 = open("grad_solution.csv", "w")
outfile4 = open("mu_a.csv", "w")
data_mua = mu_a.x.array
for x in data_mua:
print(x, file = outfile4)
So what I’m trying to do is extract the dofs, the solution at the dofs, the gradient of the solution at the dofs and the constant mu_a at the dofs
