Hello sir
I try to use LU+GMRES but it shows following error. Help me in resolving this error.
from fenics_adjoint import *
nx = 32
mesh = UnitCubeMesh(nx, nx, nx)
element = mesh.ufl_cell()
H = VectorElement("Lagrange", element, 2) # velocity subspace
Q = FiniteElement("Lagrange", element, 1) # pressure subspace
HxQ = FunctionSpace(mesh, MixedElement([H,Q])) # Mixed subspace
wh = Function(HxQ)
(uh, ph) = split(wh)
(vh, qh) = TestFunctions(HxQ)
u_in = Expression(("(16*0.45*x[1]*x[2]*(0.41-x[1])*(0.41-x[2]))/(0.41*0.41*0.41*0.41)","0","0"), domain = mesh, degree=6)
p_exact = Expression("0",domain=mesh, degree=4)
f = Constant((0,0,0))
nu = Constant(1)
# Strain:
def epsilon(v):
return 0.5*(grad(v) + grad(v).T)
B_S = (2.0*nu*inner(epsilon(uh), epsilon(vh)) + div(vh)*ph - qh*div(uh))*dx + dot(grad(uh)*uh,vh)*dx
L_S = inner(f,vh)*dx
#u_n = project(u_exact, Z.sub(0).collapse(), solver_type="mumps", form_compiler_parameters=None)
tol=1E14
def boundary(x, on_boundary):
return on_boundary and (near(x[1],0,tol) or near(x[1],1,tol) or near(x[2],0,tol) or near(x[2],1,tol))
def boundary_D(x, on_boundary):
return on_boundary and (near(x[0],0,tol))
bc1 = DirichletBC(HxQ.sub(0), Constant((0,0,0)), boundary)
bc2 = DirichletBC(HxQ.sub(0), u_in, boundary_D)
bc = [bc1, bc2]
F = B_S - L_S
# Assemble system.
a = lhs(F)
L = rhs(F)
A, b = assemble_system(a, L, bc)
MAX_ITERS = 10000
solver = PETScKrylovSolver('gmres','none')
solver.ksp().setGMRESRestart(MAX_ITERS)
solver.parameters["monitor_convergence"] = True
solver.parameters['relative_tolerance'] = 1e-6
solver.parameters['maximum_iterations'] = MAX_ITERS
solver.solve(A,wh.vector(),b)
(uh, ph) = wh.split(True)
error:
File "/home/ayush/.local/lib/python3.10/site-packages/fenics_adjoint/assembly.py", line 47, in assemble_system
A, b = backend.assemble_system(*args, **kwargs)
File "/usr/lib/petsc/lib/python3/dist-packages/dolfin/fem/assembling.py", line 423, in assemble_system
assembler = cpp.fem.SystemAssembler(A_dolfin_form, b_dolfin_form, bcs)
RuntimeError:
*** Error: Unable to assemble system.
*** Reason: expected a bilinear form for a.
*** Where: This error was encountered inside SystemAssembler.cpp.
*** Process: 0
*** Git changeset: ubuntu
