I am new to FEniCS. I am trying to figure out how to compute convergence of the L2 error norm using C++. For this reason I am interested in the undocumented/poisson-disc example.
I am getting an error while compiling with ffs the example undocumented/poisson-disc/cpp. The original file compiles well. Compilation fails if I modify the example a bit: I replace the triangle with quadrilateral. It works fine if cell = quadrilateral and degree = 1. It fails if cell = quadrilateral and degree = 2. The error message and the code are attached.
Does anyone knows what is wrong? Is there a good example of how to compute convergence of L2 and H1 error norms (i.e. method of manufactured solutions) in C++?
Thanks!
Kenneth
Error
File “/usr/bin/ffc”, line 33, in
sys.exit(load_entry_point(‘fenics-ffc==2019.2.0.dev0’, ‘console_scripts’, ‘ffc’)())
File “/usr/lib/python3/dist-packages/ffc/main.py”, line 215, in main
resultcode = _compile_files(args, parameters, enable_profile)
File “/usr/lib/python3/dist-packages/ffc/main.py”, line 254, in _compile_files
code_h, code_c = compile_ufl_data(ufd, prefix, parameters)
File “/usr/lib/python3/dist-packages/ffc/main.py”, line 95, in compile_ufl_data
code_h, code_c = compile_form(ufd.forms, ufd.object_names,
File “/usr/lib/python3/dist-packages/ffc/compiler.py”, line 142, in compile_form
return compile_ufl_objects(forms, “form”, object_names,
File “/usr/lib/python3/dist-packages/ffc/compiler.py”, line 200, in compile_ufl_objects
code = generate_code(oir, parameters)
File “/usr/lib/python3/dist-packages/ffc/codegeneration.py”, line 74, in generate_code
code_integrals = [_generate_integral_code(ir, parameters)
File “/usr/lib/python3/dist-packages/ffc/codegeneration.py”, line 249, in _generate_integral_code
code = r.generate_integral_code(ir, ir[“prefix”], parameters)
File “/usr/lib/python3/dist-packages/ffc/uflacs/uflacsgenerator.py”, line 45, in generate_integral_code
parts = ig.generate()
File “/usr/lib/python3/dist-packages/ffc/uflacs/integralgenerator.py”, line 225, in generate
self.generate_quadrature_loop(num_points)
File “/usr/lib/python3/dist-packages/ffc/uflacs/integralgenerator.py”, line 386, in generate_quadrature_loop
body = self.generate_unstructured_varying_partition(num_points)
File “/usr/lib/python3/dist-packages/ffc/uflacs/integralgenerator.py”, line 551, in generate_unstructured_varying_partition
parts = self.generate_partition(arraysymbol,
File “/usr/lib/python3/dist-packages/ffc/uflacs/integralgenerator.py”, line 584, in generate_partition
vdef = self.backend.definitions(mt.terminal,
File “/usr/lib/python3/dist-packages/ufl/corealg/multifunction.py”, line 89, in call
return self._handlers[o.ufl_typecode](o, *args)
File “/usr/lib/python3/dist-packages/ffc/uflacs/backends/ffc/definitions.py”, line 239, in jacobian
return self._define_coordinate_dofs_lincomb(e, mt, tabledata, num_points, access)
File “/usr/lib/python3/dist-packages/ffc/uflacs/backends/ffc/definitions.py”, line 132, in _define_coordinate_dofs_lincomb
assert end - begin <= num_scalar_dofs
AssertionError
Code
Copyright (C) 2015-2015 Martin Sandve Alnæs
This file is part of DOLFIN.
DOLFIN is free software: you can redistribute it and/or modify
it under the terms of the GNU Lesser General Public License as published by
the Free Software Foundation, either version 3 of the License, or
(at your option) any later version.
DOLFIN is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
GNU Lesser General Public License for more details.
You should have received a copy of the GNU Lesser General Public License
along with DOLFIN. If not, see http://www.gnu.org/licenses/.
The bilinear form a(u, v) and linear form L(v) for
Poisson’s equation with quadratic isoparametric elements.
Compile this form with FFC: ffc -r uflacs -l dolfin PoissonDisc.ufl
Solving
-laplace u = 1
u(r=1) = 0
These are original lines of code
degree = 2
cell = triangle
The ffc compiles it well with the following modification
degree = 1
The ffc fails on the following modification
degree = 2
coordinate_element = VectorElement(“Lagrange”, cell, degree)
mesh = Mesh(coordinate_element)
element = FiniteElement(“Lagrange”, cell, degree)
x = SpatialCoordinate(mesh)
f = Coefficient(V)
Variational formulation
a = dot(grad(u), grad(v))dx
L = fv*dx
Exact solution
uexact = (1.0 - x**2) / 4.0
Error norm functional
uh = Coefficient(V)
M = (uh - uexact)**2*dx
