# Fourth-order partial differential equation is solved but not satisfied in the bulk
**URL:** <https://fenicsproject.discourse.group/t/fourth-order-partial-differential-equation-is-solved-but-not-satisfied-in-the-bulk/16814>\
**Category:** General\
**Created:** [January 22, 2025, 9:39pm UTC](https://fenicsproject.discourse.group/t/fourth-order-partial-differential-equation-is-solved-but-not-satisfied-in-the-bulk/16814 "2025-01-22T21:39:02Z")\
**Showing post:** 3
**Author:** ![mekong](https://yyz2.discourse-cdn.com/free1/user_avatar/fenicsproject.discourse.group/mekong/32/7729_2.png) [@mekong](https://fenicsproject.discourse.group/u/mekong)\
**Post date:** [January 23, 2025, 8:54am UTC](https://fenicsproject.discourse.group/t/fourth-order-partial-differential-equation-is-solved-but-not-satisfied-in-the-bulk/16814/3 "2025-01-23T08:54:28Z")
> [@Stein](#):
> In your code you only prescribe Dicherlet BCs on `Q.sub(0)`
No, I am also imposing boundary conditions on the normal derivative via Nitsche’s method, see
```auto
F_N = alpha / r_mesh * ( \
            + (((n_circle( omega ))[i] * omega[i] - omega_r) * ((n_circle( omega ))[k] * g( omega )[k, l] * nu_omega[l])) * sqrt_deth_circle( omega, c_r ) * (1.0 / r) * ds_r \
            + (((n_circle( omega ))[i] * omega[i] - omega_R) * ((n_circle( omega ))[k] * g( omega )[k, l] * nu_omega[l])) * sqrt_deth_circle( omega, c_R ) * (1.0 / R) * ds_R \
F = (F_z + F_omega + F_mu + F_nu) + F_N
where `n_circle()` is the boundary normal and \omega\_i = \nabla\_i z. The boundary conditions are correct, I suspect that there is something else…
I observed a similar behavior in a simpler example for the bi-harmonic equation to which you replied, I posted it [here](https://fenicsproject.discourse.group/t/problem-solving-fourth-order-pde/16789/7), maybe it can help understand the problem in this post too ! 🙂
Thank you for your help
_[View the full topic](https://fenicsproject.discourse.group/t/fourth-order-partial-differential-equation-is-solved-but-not-satisfied-in-the-bulk/16814)._
