Hi everyone, I’m facing problem in performing Bloch analysis for wave propagation; transformation matrix is giving error.
from ufl import sym, grad, Identity, tr, inner, Measure, TestFunction, TrialFunction
import dolfinx.fem as fem
import dolfinx.fem.petsc as dolfinx_petsc # <--- alias for convenience
from dolfinx.mesh import create_rectangle, CellType
length, height = 1.0, 1.0
Nx, Ny = 5, 5
domain = create_rectangle(
MPI.COMM_WORLD,
[np.array([0.0, 0.0]), np.array([length, height])],
[Nx, Ny],
cell_type=CellType.triangle,
dim = domain.topology.dim
print(f"Mesh topology dimension d={dim}.")
degree = 2
shape = (dim,) # vector field of size `dim`
V = fem.functionspace(domain, ("P", degree, shape)) # using fem.functionspace (lowercase) as in newer dolfinx
u_sol = fem.Function(V, name="Displacement")
# material constants (use dtype-double arrays where necessary)
E = fem.Constant(domain, 210e3)
nu = fem.Constant(domain, 0.3)
lmbda = E * nu / (1 + nu) / (1 - 2 * nu)
mu = E / 2 / (1 + nu)
def epsilon(v):
return sym(grad(v))
def sigma(v):
return lmbda * tr(epsilon(v)) * Identity(dim) + 2 * mu * epsilon(v)
# variational forms
rho = 2e-3
g = 9.81
f = fem.Constant(domain, np.array([0.0, -rho * g]))
dx = Measure("dx", domain=domain)
a = inner(sigma(u), epsilon(v)) * dx
L = inner(f, v) * dx
m_form = rho * inner(u, v) * dx
# geometric boundary markers (x is shape (dim, Npoints))
def left(x):
return np.isclose(x[0], 0.0)
def right(x):
return np.isclose(x[0], length)
def bottom(x):
return np.isclose(x[1], 0.0)
def top(x):
return np.isclose(x[1], height)
left_dofs = fem.locate_dofs_geometrical(V, left)
right_dofs = fem.locate_dofs_geometrical(V, right)
bottom_dofs = fem.locate_dofs_geometrical(V, bottom)
top_dofs = fem.locate_dofs_geometrical(V, top)
print(left_dofs,'\n',right_dofs)
# Example: create a Dirichlet BC (zero displacement) on the left side
zero = np.zeros((dim,), dtype=np.double)
bc_left = fem.dirichletbc(zero, left_dofs, V)
# bcs must be a list of DirichletBC objects (or an empty list)
bcs = [] # if no BCs wanted, set bcs = []
# IMPORTANT: assemble_matrix expects a dolfinx form object; wrap with fem.form
A = dolfinx_petsc.assemble_matrix(fem.form(a), bcs=bcs)
M = dolfinx_petsc.assemble_matrix(fem.form(m_form), bcs=bcs)
M.assemble()
import scipy.sparse as sp
# Convert PETSc Mat to SciPy CSR
def petsc_to_scipy(A_petsc: PETSc.Mat):
# Convert to AIJ (CSR) format
A_csr = A_petsc.convert("aij")
ia, ja, a = A_csr.getValuesCSR()
return sp.csr_matrix((a, ja, ia), shape=A_csr.getSize())
# Convert PETSc Mat to dense NumPy
def petsc_to_numpy(A_petsc: PETSc.Mat):
A_dense = A_petsc.convert("dense")
return A_dense.getDenseArray()
# ---- Convert to SciPy CSR ----
A_csr = petsc_to_scipy(A)
M_csr = petsc_to_scipy(M)
# ---- Convert to NumPy dense ----
A_np = petsc_to_numpy(A)
M_np = petsc_to_numpy(M)
# Print matrix sizes
A_size = A.getSize()
M_size = M.getSize()
print("Stiffness matrix A size:", A_size)
print("Mass matrix M size:", M_size)
ndofs = V.dofmap.index_map.size_global * V.dofmap.index_map_bs
print("Number of DOFs:", ndofs)
import scipy.sparse.linalg as spla
# --- assume you have A_np, M_np as dense or CSR matrices ---
def build_TTBLOCH(V, left_dofs, right_dofs, bottom_dofs, top_dofs, kvec, length, height):
dim = V.dofmap.index_map_bs
ndofs = V.dofmap.index_map.size_global * dim
T = np.eye(ndofs, dtype=np.complex128)
dof_coords = V.tabulate_dof_coordinates()
node_ids = np.arange(ndofs) // dim
node_to_dofs = {i: np.where(node_ids == i)[0] for i in range(ndofs // dim)}
left_nodes = np.unique(node_ids[left_dofs])
right_nodes = np.unique(node_ids[right_dofs])
bottom_nodes = np.unique(node_ids[bottom_dofs])
top_nodes = np.unique(node_ids[top_dofs])
# --- X-direction: right -> left ---
phase_x = np.exp(1j * kvec[0] * length)
for rn, ln in zip(right_nodes, left_nodes):
rn_dofs = node_to_dofs[rn]
ln_dofs = node_to_dofs[ln]
for dr, dl in zip(rn_dofs, ln_dofs):
T[dr, :] = 0.0
T[dr, dl] = phase_x
# --- Y-direction: top -> bottom (skip corner nodes already mapped in X) ---
right_set = set(right_nodes)
top_nodes_noncorner = [n for n in top_nodes if n not in right_set]
phase_y = np.exp(1j * kvec[1] * height)
for tn, bn in zip(top_nodes_noncorner, bottom_nodes):
tn_dofs = node_to_dofs[tn]
bn_dofs = node_to_dofs[bn]
for dt, db in zip(tn_dofs, bn_dofs):
T[dt, :] = 0.0
T[dt, db] = phase_y
return T
# High-symmetry path in reciprocal space (2D square lattice)
k_points = [
np.array([0.0, 0.0]), # Gamma
np.array([0.0, np.pi]), # X
np.array([np.pi, np.pi]), # M
np.array([np.pi, 0.0]), # Y
np.array([0.0, 0.0]) # Gamma
band_eigs = []
for kvec in k_points:
T = build_TTBLOCH(V, left_dofs, right_dofs, bottom_dofs, top_dofs, kvec, length, height)
# reduced Bloch matrices
Kb = T.conj().T @ A_np @ T
Mb = T.conj().T @ M_np @ T
# Solve generalized eigenproblem (few lowest modes)
nev = 6
vals, vecs = spla.eigsh(Kb, k=nev, M=Mb, sigma=0.0, which='LM')
omegas = np.sqrt(np.real(vals))
band_eigs.append(omegas)
# Convert to array: (n_kpoints, nev)
band_eigs = np.array(band_eigs)
print("Band structure frequencies:\n", band_eigs)
