Right now I don’t think it is possible to read functions in parallel from a XDMF file. The way to do it would be to use checkpointing io to restore the saved solutions but checkpointing is not implemented yet in dolifinx (see this issue).
A workaround would be to read your solutions from a single process with meshio, assuming you are using CG1 or DG0 elements, as I explained here, and then distribute your data manually with MPI. dolfinx might have helper functions to handle that kind of communications, but I doubt they are available from the python API.
Obviously, you could also simply skip writing solutions to a file, and run your other simulation right after the first one, so you still have you previous solution in memory.
