In the Hyperelasticity example, how could one compute the ratio of the Piola-Kirchoff components P[0, 0]/P[1, 1] at a given point in the structure?
You can for instance use:
- Locate which cell your point is in
- Pull it back to the reference element
- Use
dolfinx.fem.Expression
to evaluate the expressionP[0,0]/P[1,1]
at the point of interest.
Most of the methodology is shown in:
and can thus be added to the demo above as:
def compute_expression_value(expr, points):
# Determine what process owns a point and what cells it lies within
mesh = V.mesh
collision_data = dolfinx.cpp.geometry.determine_point_ownership(
mesh._cpp_object, points, 1e-6
owning_points = collision_data.dest_points
cells = collision_data.dest_cells
# Pull owning points back to reference cell
mesh_nodes = mesh.geometry.x
cmap = mesh.geometry.cmap
ref_x = np.zeros((len(cells), mesh.geometry.dim), dtype=mesh.geometry.x.dtype)
for i, (point, cell) in enumerate(zip(owning_points, cells)):
geom_dofs = mesh.geometry.dofmap[cell]
ref_x[i] = cmap.pull_back(point.reshape(-1, 3), mesh_nodes[geom_dofs])
import math
expr_size = math.prod(expr.ufl_shape)
if len(cells) > 0:
# NOTE: Expression lives on only this communicator rank
compiled_expr = dolfinx.fem.Expression(expr, ref_x, comm=MPI.COMM_SELF)
values = compiled_expr.eval(mesh, np.asarray(cells, dtype=np.int32))
# Extract values for each (cell, point) pair
stripped_values = np.diagonal(
values.reshape(
len(cells),
ref_x.shape[0],
expr_size,
axis1=0,
axis2=1,
).T.reshape(len(cells), *expr.ufl_shape)
return stripped_values
return np.empty((0, *expr.ufl_shape))
# Example to illustrate that this works for any expression of any shape
# is commented out here
# P_rate = ufl.as_tensor([[x[0], x[1]], [x[2], -x[0]]])
P_rate = P[0, 0] / P[1, 1]
values = compute_expression_value(
P_rate, np.array([[0.5, 0.2, 0.3], [1, 0, 0.1], [0.764, 0.33, 0.23]])
print(f"P_rate: {values}")
