I have explained the mathematical equation, the objective function and adjoint equation i want to solve in this link Calculate sensitivity equation of reaction-diffusion systems with dolfinx and I tried as your tutorial but had this error
import dolfinx.nls.petsc
import dolfinx.fem.petsc
import pyvista
from dolfinx.mesh import CellType, create_rectangle
from dolfinx import fem, nls, io
from ufl import Measure, inner, grad, div, TestFunction, TrialFunction, adjoint, derivative, SpatialCoordinate, TestFunction, TrialFunction, dot, ds, dx
from dolfinx.fem import (Constant, Function, FunctionSpace,
assemble_scalar, dirichletbc, form, locate_dofs_geometrical)
from dolfinx import default_scalar_type
from dolfinx.plot import vtk_mesh
#Parameter
D0 = 0.1;
k0 = -1.0;
eta = 2.0;
gamma = 2.0;
# mesh and function space
mesh = create_rectangle(MPI.COMM_WORLD, [[0, 0], [1, 1]], [100, 100], CellType.triangle)
V = fem.FunctionSpace(mesh, ("CG", 1))
c = fem.Function(V)
phi = TestFunction(V)
# The eps is the design variable
eps = fem.Function(V)
eps.x.array[:] = 0.5
#boundary_markers = FacetFunction('size_t',mesh)
dx = Measure("dx") ##integration over different parts of the domain
x = SpatialCoordinate(mesh)
gu = Constant(mesh, default_scalar_type(0)) ##Neauman = 0
# Residual of the variational form of Poisson problem
R = inner(D0*eps**eta*grad(c), grad(phi))*dx - inner(k0*(1-eps)**gamma*c,phi)*dx - inner(gu,phi) *ds # " - inner(gu,phi) *ds " is boundary neauman
##Dirichlet
def on_boundary(x):
return np.isclose(x[0], 0)
dofs_L = fem.locate_dofs_geometrical(V , on_boundary)
bc_L = fem.dirichletbc(default_scalar_type(1), dofs_L, V) ##Dirichlet = 1
bcs = [bc_L]
#Forming and solving the linear system
problem_u = fem.petsc.NonlinearProblem(R, c, bcs)
solver = nls.petsc.NewtonSolver(MPI.COMM_WORLD,problem_u)
solver.rtol = 1e-16
solver.solve(c)
J = -ufl.inner((k0*(1-eps)**gamma),c)*dx ##Objective function
J_form = fem.form(J)
dRdc = adjoint(derivative(R, c))
lhs = fem.form(dRdc)
rhs = derivative(J, c)
lmbda = fem.Function(V)
lambda_0 = fem.Function(V)
lambda_0.x.array[:] = 0
bcs_adjoint = [fem.dirichletbc(lambda_0, bc._cpp_object.dof_indices()[0]) for bc in bcs]
adjoint_problem = dolfinx.fem.petsc.LinearProblem(lhs, rhs, c=lmbda,bcs=bcs_adjoint, petsc_options={"ksp_type": "preonly", "pc_type": "lu"})
Exception ignored in: <function LinearProblem.__del__ at 0x7f334b39d510>
File "/usr/local/dolfinx-complex/lib/python3.10/dist-packages/dolfinx/fem/petsc.py", line 627, in __del__
self._solver.destroy()
AttributeError: 'LinearProblem' object has no attribute '_solver'
TypeError Traceback (most recent call last)
Cell In[7], line 12
10 lambda_0.x.array[:] = 0
11 bcs_adjoint = [fem.dirichletbc(lambda_0, bc._cpp_object.dof_indices()[0]) for bc in bcs]
---> 12 adjoint_problem = dolfinx.fem.petsc.LinearProblem(lhs, rhs, c=lmbda,bcs=bcs_adjoint, petsc_options={"ksp_type": "preonly", "pc_type": "lu"})
TypeError: LinearProblem.__init__() got an unexpected keyword argument 'c'
