As f and g are finite element functions this will return \int_{\Omega_1} 0.5\nabla f \cdot \nabla g~\mathrm{d}x, a scalar value, where \Omega_1\subset \Omega such that \Omega_1 = \{k\in cells(\Omega)\vert marker(k)=1 \}
As non_local_interaction is a scalar value, you can add it to any variational form.
materials = MeshFunction("size_t", mesh, mesh.topology().dim()) # over cells
dx = Measure('dx', domain=mesh, subdomain_data = materials)
for cell_no in range(len(materials.array())):
#define the cell
cell = MeshEntity(mesh, 2, cell_no)
#define the barycenter
cell_bc = cell.midpoint()
# create a subdomain class of radius r for each cell on the mesh
class Interaction_range(SubDomain):
return on_boundary and (x[0]-cell_bc[0])*(x[0]-cell_bc[0]) + (x[1]-cell_bc[1])*(x[1]-cell_bc[1]) <= r*r + tol
# mark the interaction range
subdomain_1 = Interaction_range()
subdomain_1.mark(materials, 1)
# integrate over the subdomain (removing the text function to get float results instead of a vector)
nonlocal_interaction = assemble(0.5*dot(grad(f), grad(g))*dx(1))
In C++ how can I go about it?
I actually need to carry out this subdomain integration either at every time step or 10-time steps depending on my choice but it’s expensive to loop through all the elements at every time step for nx=ny=256
Or is there a faster way to iterate through all the elements in materials without a loop?
Do you mean how to code this in C++?
There are many C++ demos illustrating how dolfin works. I do not have the time to translate your code to another language
Yes, to code it in C++ either still within python (where we do it in quotes) or otherwise, perhaps you can give me a link? or is there a faster way to do it without involving C++?
arr = np.array([])
for cell_no in range(len(materials.array())): # type: ignore
#define the cell
#define the barycenterof the cell
# create subdomain class of radius r for each cell on the mesh
return (x[0]-cell_bc[0])*(x[0]-cell_bc[0]) + (x[1]-cell_bc[1])*(x[1]-cell_bc[1]) <= r*r + tol
'''Interaction_range = CompiledSubDomain('(x[0]-cell_bc_0)*(x[0]-cell_bc_0) + (x[1]-cell_bc_1)*(x[1]-cell_bc_1) <= r*r + tol', cell_bc_0=cell_bc[0],cell_bc_1=cell_bc[1], tol=tol, r=r)'''
arr = np.append(arr, subdomain_1)
but it returns as
<__main__.Interaction_range object at 0x7fc70c274d00>
How do I specify dx(1) for each cell after collecting these interaction ranges for each cell when integrating for each time step? I apologize if my questions are a bit dumb.
import time
r = 0.1
tol = 10*DOLFIN_EPS
def __init__(self, cell_bc, r, **kwargs):
super().__init__(**kwargs)
self.r = r
self.cell_bc = cell_bc
return (x[0]-self.cell_bc[0])*(x[0]-self.cell_bc[0]) +\
(x[1]-self.cell_bc[1])*(x[1]-self.cell_bc[1]) <= self.r*self.r + tol
N = 35
mesh = UnitSquareMesh(N, N)
start = time.perf_counter()
value = 3
data = np.array([], dtype=np.int32)
offsets = [0]
materials = MeshFunction("size_t", mesh, mesh.topology().dim(), 0)
for cell in cells(mesh):
subdomain = Interaction_range(cell_bc, r)
materials.set_all(0)
subdomain.mark(materials, value)
local_cells = np.flatnonzero(materials.array()==value)
data = np.hstack([data, local_cells])
offsets.append(len(data))
end = time.perf_counter()
print(f"Generate radius {end-start:.2e}")
materials.array()[data[offsets[cell.index()]:offsets[cell.index()+1]]] = value
# Pick a random cell to visualize
if cell.index() == 3*N:
print(cell.midpoint()[0], cell.midpoint()[1])
File("mat.pvd") << materials
print(f"Assign marker for each domain {end-start:.2e}")
however it does scale with the number of elements, which is not good.
Generate radius 2.43e+01
0.49523809523809526 0.047619047619047616
Assign marker for each domain 3.10e-02
