Is the dofmap contains glocal index or local index?
I think you are misunderstanding what should be modified in your code.
Here you are only changing the index map, but not the dofmap.
You need to change both in a consistent way, which is quite some work.
Here is a code that creates a periodic BC for a 1D problem (with a single dof being replaced in the dofmap)
# A DOFMAP reduction code for periodic boundary conditions in 1D
# SPDX-License-Identifier: MIT
# Author: Jørgen S. Dokken
from dolfinx import fem, mesh, cpp, io
from ufl import dx
import basix
msh = mesh.create_unit_interval(
    MPI.COMM_WORLD, 10, ghost_mode=mesh.GhostMode.none)
V = fem.functionspace(msh, ("Lagrange", 1))
def left(x):
    return np.isclose(x[0], 0.0)
def right(x):
    return np.isclose(x[0], 1.0)
puppet = fem.locate_dofs_geometrical(V, left)
master = fem.locate_dofs_geometrical(V, right)
assert len(puppet) <= 2
assert len(master) <= 2
# Currently assuming single puppet
V_index_map = V.dofmap.index_map
has_master = np.full(msh.comm.size, -1, dtype=np.int64)
has_puppet = np.zeros(msh.comm.size, dtype=np.int32)
owned_puppet = False
if len(puppet) > 0 and puppet[0] < V_index_map.size_local:
    has_puppet[:] = 1
    owned_puppet = True
# Send master to do slave process
owned_master = False
if len(master) > 0 and master[0] < V_index_map.size_local:
    has_master[:] = V_index_map.local_range[0] + master[0]
    owned_master = True
puppet_to_master = np.zeros_like(has_puppet)
master_to_puppet = np.zeros_like(has_master)
msh.comm.Alltoall(has_puppet, puppet_to_master)
msh.comm.Alltoall(has_master, master_to_puppet)
puppet_ranks = np.flatnonzero(puppet_to_master)
master_indicator = (master_to_puppet > -1).astype(np.int32)
master_ranks = np.flatnonzero(master_indicator)
# If has puppet, this process should communicate with the master
i_to_dest = V_index_map.index_to_dest_ranks()
src = np.unique(i_to_dest.array[:i_to_dest.offsets[V_index_map.size_local]])
dest = np.unique(V_index_map.owners)
local_range = V_index_map.local_range
local_size = V_index_map.size_local
# Map ghosts to a lower index to account for the removed dof
old_ghosts = V.dofmap.index_map.ghosts
new_ghosts = []
new_owners = []
for owner, ghost in zip(V_index_map.owners, old_ghosts):
    new_ghosts.append(ghost - sum(puppet_to_master[:owner]))
    new_owners.append(owner)
if not owned_master:
    assert not owned_master
    if (gd := (master_to_puppet[master_ranks[0]] - sum(puppet_to_master[:master_ranks[0]]))) not in new_ghosts:
        ghost_pos = len(new_ghosts)
        new_ghosts.append(gd)
        new_owners.append(master_ranks[0])
        ghost_pos = np.where(np.asarray(new_ghosts) == gd)[0][0]
if owned_puppet:
    local_size -= 1
new_index_map = cpp.common.IndexMap(
    MPI.COMM_WORLD, local_size, np.asarray(new_ghosts, dtype=np.int64), np.asarray(new_owners, dtype=np.int32))
old_dofs = V.dofmap.list.copy()
shape = old_dofs.shape
new_dofs = old_dofs.reshape(-1).copy()
pupp = -1
if len(puppet) > 0:
    pupp = puppet[0]
for i, dof in enumerate(old_dofs.reshape(-1)):
    if dof > pupp:
        new_dofs[i] = dof - int(pupp > -1)
    elif dof == pupp:
        if owned_master:
            new_dofs[i] = master[0] - int(master[0] > pupp)*int(pupp > -1)
            new_dofs[i] = local_size + ghost_pos
dofs = cpp.graph.AdjacencyList_int32(new_dofs.reshape(shape))
new_dofmap = cpp.fem.DofMap(V.dofmap.dof_layout,
                            new_index_map, V.dofmap.index_map_bs,
                            dofs, V.dofmap.bs)
# Creat the functionspace
cppV = cpp.fem.FunctionSpace_float64(
    msh._cpp_object, V.element, new_dofmap, V.value_shape)
e = fem.ElementMetaData("Lagrange", 1)
ufl_e = basix.ufl.element(e.family, msh.basix_cell(), e.degree, shape=e.shape,
                          symmetry=e.symmetry)
V_pbc = fem.FunctionSpace(msh, ufl_e, cppV)
def solve_problem(V):
    u = ufl.TrialFunction(V)
    v = ufl.TestFunction(V)
    x = ufl.SpatialCoordinate(msh)
    f = x[0]*ufl.sin(x[0])
    a = ufl.dot(ufl.grad(u), ufl.grad(v)) * dx
    L = f * v * dx
    problem = LinearProblem(a, L, bcs=[], petsc_options={
                            "ksp_type": "preonly", "pc_type": "lu",
                            "pc_factor_mat_solver_type": "mumps",
                            "mat_mumps_icntl_24": 1,  # Option to support solving a singular matrix
                            "mat_mumps_icntl_25": 0  # Option to support solving a singular matrix
    nullspace = PETSc.NullSpace().create(constant=True)  # type: ignore
    PETSc.Mat.setNearNullSpace(problem.A, nullspace)
    uh = problem.solve()
    print(problem.A[:, :])
    print(problem.b[:])
    with io.XDMFFile(msh.comm, "test.xdmf", "w") as xdmf:
        xdmf.write_mesh(msh)
        xdmf.write_function(uh, 0.0)
solve_problem(V)
solve_problem(V_pbc)
yielding (non-periodic)
[[ 10. -10.   0.   0.   0.   0.   0.   0.   0.   0.   0.]
 [-10.  20. -10.   0.   0.   0.   0.   0.   0.   0.   0.]
 [  0. -10.  20. -10.   0.   0.   0.   0.   0.   0.   0.]
 [  0.   0. -10.  20. -10.   0.   0.   0.   0.   0.   0.]
 [  0.   0.   0. -10.  20. -10.   0.   0.   0.   0.   0.]
 [  0.   0.   0.   0. -10.  20. -10.   0.   0.   0.   0.]
 [  0.   0.   0.   0.   0. -10.  20. -10.   0.   0.   0.]
 [  0.   0.   0.   0.   0.   0. -10.  20. -10.   0.   0.]
 [  0.   0.   0.   0.   0.   0.   0. -10.  20. -10.   0.]
 [  0.   0.   0.   0.   0.   0.   0.   0. -10.  20. -10.]
 [  0.   0.   0.   0.   0.   0.   0.   0.   0. -10.  10.]]
[8.32777934e-05 1.16322600e-03 4.13331213e-03 9.01733729e-03
 1.57171653e-02 2.40974738e-02 3.39877899e-02 4.51850600e-02
 5.74567199e-02 7.05442245e-02 3.97830923e-02]
Periodic
[[ 20. -10.   0.   0.   0.   0.   0.   0.   0. -10.]
 [-10.  20. -10.   0.   0.   0.   0.   0.   0.   0.]
 [  0. -10.  20. -10.   0.   0.   0.   0.   0.   0.]
 [  0.   0. -10.  20. -10.   0.   0.   0.   0.   0.]
 [  0.   0.   0. -10.  20. -10.   0.   0.   0.   0.]
 [  0.   0.   0.   0. -10.  20. -10.   0.   0.   0.]
 [  0.   0.   0.   0.   0. -10.  20. -10.   0.   0.]
 [  0.   0.   0.   0.   0.   0. -10.  20. -10.   0.]
 [  0.   0.   0.   0.   0.   0.   0. -10.  20. -10.]
 [-10.   0.   0.   0.   0.   0.   0.   0. -10.  20.]]
[0.00116323 0.00413331 0.00901734 0.01571717 0.02409747 0.03398779
 0.04518506 0.05745672 0.07054422 0.03986637]
