I have been making use of the PETScDMCollection.create_transfer_matrix()
for sometime and have had success. I am seeing issues today though and so created the following simple code (MWE) where I am able to recreate the issue.
import dolfin as dl
# create the coarse mesh
nx_coarse = 5
mesh_coarse = dl.UnitSquareMesh(nx_coarse, nx_coarse)
# create the fine mesh
mesh_fine = dl.refine(mesh_coarse)
# store all meshes
meshes = [mesh_coarse, mesh_fine]
num_of_meshes = len(meshes)
# define finite-element spaces on each of the meshes
P1s = [dl.FiniteElement("CG", meshes[i].ufl_cell(), 1) \
for i in range(num_of_meshes)]
Vhs = [dl.FunctionSpace(meshes[i], P1s[i]) \
# create-transfer matrix
P = dl.PETScDMCollection.create_transfer_matrix(Vhs[0], Vhs[1])
Upon running this code I receive the error message
PETSC ERROR: Logging has not been enabled.
You might have forgotten to call PetscInitialize().
application called MPI_Abort(MPI_COMM_WORLD, 70033056) - process 0
[unset]: write_line error; fd=-1 buf=:cmd=abort exitcode=70033056
system msg for write_line failure : Bad file descriptor
Error in system call pthread_mutex_destroy: Device or resource busy
src/mpi/init/initthread.c:284
I am using dolfin version 2019.1.0 which was installed using conda. Any tips would be greatly appreciated!
