# Meshio does not read Gmsh physical groups
**URL:** <https://fenicsproject.discourse.group/t/meshio-does-not-read-gmsh-physical-groups/5561>\
**Category:** mesh\
**Created:** [April 11, 2021, 4:03am UTC](https://fenicsproject.discourse.group/t/meshio-does-not-read-gmsh-physical-groups/5561 "2021-04-11T04:03:24Z")\
**Showing post:** 8
**Author:** ![Nexius](https://avatars.discourse-cdn.com/v4/letter/n/50afbb/32.png) [@Nexius](https://fenicsproject.discourse.group/u/Nexius)\
**Post date:** [April 11, 2021, 7:19pm UTC](https://fenicsproject.discourse.group/t/meshio-does-not-read-gmsh-physical-groups/5561/8 "2021-04-11T19:19:58Z")
… and, because this might get important: once created a `gmsh` file, you have an interest for the import of the `gmsh` mesh into FEniCS. Below you find two definitions, how I import 2D or 3D meshes into FEniCS (this was derived, e.g., from [here](https://fenicsproject.discourse.group/t/pygmsh-tutorial/2506/4) and so on).
First you use `convert_mesh_xdmf` and then `load_mesh_to_fenics`. It is written such that you can use MPI (see, e.g., [here](https://fenicsproject.discourse.group/t/mesh-conversion-xdmf-in-a-mpi-environment/3499/5)).
Greetings … .
import os
# _________________________________________________________________ Definitions
# Convert the 'gmsh' specific mesh into a XDMF mesh. This is done for MPI
# i => process number (MPI)
# file_mesh => gmsh file
# dir_data => directory of the mesh files
# dimension => either "2D" or "3D"
def convert_mesh_xdmf(i, file_mesh, dir_data, dimension):
    mesh = meshio.read(file_mesh)
    string_nr = "{:04d}".format(i)
    tetra_cells = None # For 3D only
    tetra_data = None # For 3D only
    triangle_cells = None # For 2D and 3D
    triangle_data = None # For 2D and 3D
    line_cells = None # For 2D only
    line_data = None # For 2D only
    for key in mesh.cell_data_dict["gmsh:physical"].keys():
        if key == "triangle":
            triangle_data = mesh.cell_data_dict["gmsh:physical"][key]
        elif key == "tetra":
            tetra_data = mesh.cell_data_dict["gmsh:physical"][key]
        elif key == "line":
            line_data = mesh.cell_data_dict["gmsh:physical"][key]
    for cell in mesh.cells:
        if cell.type == "tetra":
            if tetra_cells is None:
                tetra_cells = cell.data
                tetra_cells = np.vstack([tetra_cells, cell.data])
        elif cell.type == "triangle":
            if triangle_cells is None:
                triangle_cells = cell.data
                triangle_cells = np.vstack([triangle_cells, cell.data])
        elif cell.type == "line":
            if line_cells is None:
                line_cells = cell.data
                line_cells = np.vstack([line_cells, cell.data])
    line_mesh = meshio.Mesh(points=mesh.points,
                             cells={"line": line_cells},
                             cell_data={"name_to_read":[line_data]})
    tetra_mesh = meshio.Mesh(points=mesh.points,
                             cells={"tetra": tetra_cells},
                             cell_data={"name_to_read":[tetra_data]})
    triangle_mesh =meshio.Mesh(points=mesh.points,
                               cells=[("triangle", triangle_cells)],
                               cell_data={"name_to_read":[triangle_data]})
    file_msh_subd = os.path.join(dir_data, "Data_"+string_nr+"_msh_subd.xdmf")
    file_bound = os.path.join(dir_data, "Data_"+string_nr+"_bound.xdmf")
    if dimension == "2D":
        meshio.write(file_msh_subd, triangle_mesh)
        meshio.write(file_bound, line_mesh)
    if dimension == "3D":
        meshio.write(file_msh_subd, tetra_mesh)
        meshio.write(file_bound, triangle_mesh)
# Import the mesh, boundaries and subdomains into FEniCS.
def load_mesh_to_fenics(i, dir_data):
    # Open the latter files and obtain the mesh, subdomains, boundaries,
    # dx and ds.
    mesh = Mesh(MPI.comm_self)
    with XDMFFile(MPI.comm_self, file_msh_subd) as infile:
        infile.read(mesh)
    mvc = MeshValueCollection("size_t", mesh, 2)
    with XDMFFile(MPI.comm_self, file_bound) as infile:
    boundaries = cpp.mesh.MeshFunctionSizet(mesh, mvc)
    mvc2 = MeshValueCollection("size_t", mesh, 3)
        infile.read(mvc2, "name_to_read")
    subdomains = cpp.mesh.MeshFunctionSizet(mesh, mvc2)
    dx = Measure("dx", domain=mesh, subdomain_data=subdomains)
    ds = Measure("ds", domain=mesh, subdomain_data=boundaries)
    dS = Measure("dS", domain=mesh, subdomain_data=boundaries)
    # We note some statistical information into the parameter class
    n_cells = mesh.num_cells()
    n_facets = mesh.num_faces()
    n_vertices = mesh.num_vertices()
    n_edges = mesh.num_edges()
    # We print out this info on the terminal for the case that we decide to
    # eventually stop the calculations.
    print("Mesh information")
    print("================")
    print("No. of cells : ", n_cells)
    print("No. of faces : ", n_facets)
    print("No. of vertices: ", n_vertices)
    print("No. of edges : ", n_edges)
    return n_cells, n_facets, n_vertices, n_edges, mesh, subdomains, boundaries, dx, ds, dS
_[View the full topic](https://fenicsproject.discourse.group/t/meshio-does-not-read-gmsh-physical-groups/5561)._
