# Mixed dimensional Diffusion Problem
**URL:** <https://fenicsproject.discourse.group/t/mixed-dimensional-diffusion-problem/18217>\
**Category:** General\
**Tags:** dolfinx\
**Created:** [September 17, 2025, 11:15am UTC](https://fenicsproject.discourse.group/t/mixed-dimensional-diffusion-problem/18217 "2025-09-17T11:15:42Z")\
**Showing post:** 10
**Post date:** [September 19, 2025, 6:33pm UTC](https://fenicsproject.discourse.group/t/mixed-dimensional-diffusion-problem/18217/10 "2025-09-19T18:33:09Z")
You don’t need to generate the weak forms again at each time step, but you would need to modify the list of boundary conditions on each time step.
Here is an illustration using an indicator function:
```python
# # Ilustration of varying boundary conditions through physical parameters
# Author: Jørgen S. Dokken <dokken@simula.no>
# SPDX-License-Identifier: MIT
import dolfinx.fem.petsc
comm = MPI.COMM_WORLD
N = 40
mesh = dolfinx.mesh.create_unit_square(comm, N, N)
V = dolfinx.fem.functionspace(mesh, ("Lagrange", 1))
u, v = ufl.TrialFunction(V), ufl.TestFunction(V)
uh = dolfinx.fem.Function(V, name="u")
mesh.topology.create_connectivity(mesh.topology.dim - 1, mesh.topology.dim)
exterior_facets = dolfinx.mesh.exterior_facet_indices(mesh.topology)
facet_mesh, entity_map = dolfinx.mesh.create_submesh(
    mesh, mesh.topology.dim - 1, exterior_facets
)[:2]
Q = dolfinx.fem.functionspace(facet_mesh, ("Lagrange", 1))
# Create an initial split of the boundary
indicator = dolfinx.fem.Function(Q, name="indicator")
indicator.interpolate(lambda x: x[0] + 0.6)
is_dirichlet = ufl.conditional(ufl.ge(indicator, 1.0), 1, 0)
# Define an analytical solution to enforce bcs
uD = dolfinx.fem.Function(V)
u_ex = 1 + x[0] **2 + 2 * x[1]** 2
uD.interpolate(dolfinx.fem.Expression(u_ex, V.element.interpolation_points))
f = -ufl.div(ufl.grad(u_ex))
n = ufl.FacetNormal(mesh)
g = -ufl.dot(ufl.grad(u_ex), n)
dx = ufl.dx(domain=mesh)
ds = ufl.ds(domain=mesh)
F = ufl.inner(ufl.grad(u), ufl.grad(v)) * dx
F -= f * v * dx
F += (1 - is_dirichlet) * g * v * ds
h = 2 * ufl.Circumradius(mesh)
alpha = dolfinx.fem.Constant(mesh, dolfinx.default_scalar_type(10))
F += -is_dirichlet * ufl.inner(n, ufl.grad(u)) * v * ds
F += (
    -is_dirichlet * ufl.inner(n, ufl.grad(v)) * (u - uD) * ds
    + is_dirichlet * alpha / h * ufl.inner(u - uD, v) * ds
a, L = ufl.system(F)
problem = dolfinx.fem.petsc.LinearProblem(
    a,
    L,
    bcs=[],
    petsc_options={
        "ksp_type": "preonly",
        "pc_type": "lu",
        "pc_factor_mat_solver_type": "mumps",
        "ksp_error_if_not_converged": True,
    u=uh,
    entity_maps=[entity_map],
    petsc_options_prefix="mwe_",
problem.solve()
vtx_u = dolfinx.io.VTXWriter(comm, "u.bp", [uh])
vtx_u.write(0.0)
is_dirichlet_func = dolfinx.fem.Function(Q, name="is_dirichlet")
is_dirichlet_expr = dolfinx.fem.Expression(is_dirichlet, Q.element.interpolation_points)
is_dirichlet_func.interpolate(is_dirichlet_expr)
vtx_id = dolfinx.io.VTXWriter(comm, "id.bp", [indicator, is_dirichlet_func])
vtx_id.write(0.0)
L2_u = dolfinx.fem.form(ufl.inner(uh - u_ex, uh - u_ex) * dx)
L2_local = dolfinx.fem.assemble_scalar(L2_u)
L2_u_global = np.sqrt(comm.allreduce(L2_local, op=MPI.SUM))
print(f"L2 error: {L2_u_global:.6e}")
is_dirichlet_area = dolfinx.fem.form(is_dirichlet * ds, entity_maps=[entity_map])
print(
    "Dirichlet area",
    comm.allreduce(dolfinx.fem.assemble_scalar(is_dirichlet_area), op=MPI.SUM),
indicator.interpolate(lambda x: x[0] + 0.1)
print(
    "Dirichlet area post change",
problem.solve()
vtx_u.write(1.0)
vtx_id.write(1.0)
vtx_u.close()
vtx_id.close()
First time solving:
 ![image](https://global.discourse-cdn.com/free1/uploads/fenicsproject1/original/2X/5/52e8ef1517c67e5c5cb4254313526f6785596e6c.png)
After update
 ![image](https://global.discourse-cdn.com/free1/uploads/fenicsproject1/original/2X/a/ab0184e8b9604aa4faf97d59243d2b88cf710f78.png)
Of course, if we now use a `g` that is different than the analytical `g`, we will clearly see the effect on the solution. For instance, using: `g = ufl.sin(x[0]) * ufl.cos(x[1] * ufl.pi)`:
 ![image](https://global.discourse-cdn.com/free1/uploads/fenicsproject1/original/2X/e/e2459fd76ddf0429f750b0377d42978b99eacad7.png)
 ![image](https://global.discourse-cdn.com/free1/uploads/fenicsproject1/original/2X/9/9d500f9f35dac43db5076c291bcba47681668952.png)
_[View the full topic](https://fenicsproject.discourse.group/t/mixed-dimensional-diffusion-problem/18217)._
