Hi all,
I have an issue and honestly I am not sure, if a solution exists…
I am trying to model a Darcy flow through porous media: -div( k/mu * grad p ). This is fine, I have a simple demo that works. Now I wish to create a more complicated expression for the porosity, i.e. create another formulation for the permeability tensor k.
In my working demo, k is defined as the expression:
k=max_value(Expression('exp(-pow((x[1]-0.5-0.1*sin(10*x[0]))/0.1, 2))',degree=2), Expression('0.01',degree=2))
The above formulation for k defines a porous fraction following a sine curve.
Now I wish to model a flow trough gravel. For this I am using Perlin Noise and the code from: https://stackoverflow.com/questions/42147776/producing-2d-perlin-noise-with-numpy?fbclid=IwAR0IUD9FyM9DbbwRXhg9KmdGOUvy275h1y-JYnXDApa-nWmQ5EUx29Oi91Y
The definition of the Perlin Noice can be used within FEniCS by help of an UserExpression:
class RandomField(UserExpression):
def eval(self, value, x):
self.s=5
value[:] = perlin(x[0]*self.s, x[1]*self.s, seed=8465)/2. + 0.5
def value_shape(self):
return ()
k=RandomField(degree=2)
My issue is, that every time k is used it is generated again, which is very time consuming. Can it be implemented such that k is only initialized once and then used as a tensor afterwards?
Thank you.
Below is a minimal working example, showing that the test-UserExpression is executed twice
#Create mesh
mesh = UnitSquareMesh(64, 64)
#create function space
Q = FunctionSpace(mesh, 'DG', 0) # pressure space, Discontinuous Lagrange space
class test(UserExpression):
def eval(self, values, x):
values[:] = np.random.rand()
return ()
k=test(degree=2)
kplot = project(k,Q)
f1 = plt.figure(1)
c=plot(kplot)
plt.colorbar(c)
f1 = plt.figure(2)
c=plot(kplot)
plt.colorbar(c)
