Hello, I’m trying to assign materials (and therefore picking subdomains) for imported mesh. I’m using an external tool to create mesh and then exporting it as med
file format. I’m using meshio
to convert mesh. I’m also exporting all meshes for all subdomains in order to further mark which element of whole domain (in file 1_full
) belongs to which subdomain (files 1_air
, 1_iron
and 1_wire
I’m doing it simply by assumption, that i might have domains of complex shape, so creating both geometry and mesh using external tool is preferable. The shape of those subdomains is complex enough, so that using any reasonable analytical function to mark boundary is impossible.
I’ve figured out, that in order to assign materials to elements in mesh 1_full
, FEniCS is checking edges as well as cell centers. In order to find cell center I’ve created additional method that does exactly that.
This algorithm works, but it becomes computationally heavy and time-consuming for not that high number of elements (order of tens of thousands).
Is there any simpler way to choose subdomains and assign materials when dealing with imported mesh?
print("Converting meshes...")
mesh = meshio.read('1_full.med')
meshio.write("1_full.xml", mesh)
mesh = meshio.read('1_air.med')
meshio.write("1_air.xml", mesh)
mesh = meshio.read('1_wire.med')
meshio.write("1_wire.xml", mesh)
mesh = meshio.read('1_iron.med')
meshio.write("1_iron.xml", mesh)
import mshr
import copy
from scipy import constants
print("Loading mesh...")
mesh = Mesh("1_full.xml")
mesh_iron = Mesh("1_iron.xml")
mesh_wire = Mesh("1_wire.xml")
mesh_air = Mesh("1_air.xml")
plot(mesh)
tol = 1e-14
def getMidPoint(pt1, pt2):
return (pt1+pt2)*0.5
def getLine(pt1, pt2):
A = -(pt1[1] - pt2[1])
B = (pt1[0] - pt2[0])
C = pt1[0]*A + pt1[1]*B
return {'A': A, 'B': B, 'C': C}
def getMeshCellCenters(mesh):
centers = []
for cell in mesh.cells():
pts = []
for point in cell:
pts.append(copy.copy(mesh.coordinates()[point]))
line1 = getLine(pts[0], getMidPoint(pts[1], pts[2]))
line2 = getLine(pts[1], getMidPoint(pts[0], pts[2]))
W = line1['A']*line2['B'] - line2['A']*line1['B']
Wx = line1['C']*line2['B'] - line2['C']*line1['B']
Wy = line1['A']*line2['C'] - line2['A']*line1['C']
centers.append([Wx/W, Wy/W])
return np.array(centers)
class MeshDomain(SubDomain):
def __init__(self):
SubDomain.__init__(self)
self.nodes = []
self.cell_centers = []
def physicalSurface(self, mesh):
self.nodes = mesh.coordinates()
self.cell_centers = getMeshCellCenters(mesh)
def inside(self, point, on_boundry):
for pt in self.nodes:
if near(point[0], pt[0], tol) & near(point[1], pt[1], tol):
return True
for pt in self.cell_centers:
return True
return False
print("Assigning materials...")
materials = MeshFunction('size_t', mesh, mesh.topology().dim())
subdom_air = MeshDomain()
subdom_iron = MeshDomain()
subdom_wire = MeshDomain()
subdom_air.physicalSurface(mesh_air)
subdom_iron.physicalSurface(mesh_iron)
subdom_wire.physicalSurface(mesh_wire)
subdom_air.mark(materials, 0)
subdom_iron.mark(materials, 1)
subdom_wire.mark(materials, 2)
print("Saving materials to file...")
File('materials.xml') << materials
