# Precondition appears not to happen
**URL:** <https://fenicsproject.discourse.group/t/precondition-appears-not-to-happen/15969>\
**Category:** dolfinx\
**Tags:** linear-algebra\
**Created:** [October 3, 2024, 4:00pm UTC](https://fenicsproject.discourse.group/t/precondition-appears-not-to-happen/15969 "2024-10-03T16:00:43Z")\
**Showing post:** 5
**Author:** ![Stein](https://yyz2.discourse-cdn.com/free1/user_avatar/fenicsproject.discourse.group/stein/32/8751_2.png) [@Stein](https://fenicsproject.discourse.group/u/Stein)\
**Post date:** [November 13, 2024, 10:40am UTC](https://fenicsproject.discourse.group/t/precondition-appears-not-to-happen/15969/5 "2024-11-13T10:40:21Z")
I ran a little scaling study, focusing on the effect of increasing polynomial order. I’m comparing three different solvers:
- Direct solve with mumps
- Iterative solve with GMRes and preconditioning per [Stokes equations using Taylor-Hood elements — DOLFINx 0.9.0 documentation](https://docs.fenicsproject.org/dolfinx/v0.9.0/python/demos/demo_stokes.html#monolithic-block-iterative-solver)
- Iterative solve with GMREs and precondition described above.
For relevancy of the testcase, I am considering a 3D domain (cube) and I added an advective term to the stokes equation to mimick a Newton iteration in a Navier-Stokes solve. I’ve added the code below.
For weak scaling I obtain:
 ![WeakScaling-PolOrder](https://global.discourse-cdn.com/free1/uploads/fenicsproject1/original/2X/2/2bc9d161b9af5f9456033b9ca0a8acfcb1115111.png)
with wall-clock runtime of the solve step on the y-axis, and DOF-count on the x-axis. Each marker corresponds to an increase in core numbers: 1, 2, 4, 8, 16, 32 and 48. I’ve tried to stick to roughly 100k dofs per core.
For the higher-order cases, the runtime was severely limited by the assembly/integration and not by the solve. This implies strong scaling is more important:
 ![image](https://global.discourse-cdn.com/free1/uploads/fenicsproject1/original/2X/b/bab1c5934267c296e9bd127fe6b1a2fddea5a6ea.png)
with on the x-axis number of cores. It doesn’t appear to scale so great, but that’s due to the limited number of 800k dofs. I’m just happy to see that GMRes outperforms mumps in all cases.
Here is the code:
```auto
import os
from dolfinx import mesh, fem
from dolfinx.fem.petsc import assemble_matrix, assemble_vector, NonlinearProblem, LinearProblem
from dolfinx.nls.petsc import NewtonSolver
from ufl import div, nabla_grad, dot, inner, outer, dx, sym
from basix.ufl import element, mixed_element
import time
import pickle
def main(outputdir:str = "", # Directory for storing output
         CASE:int = 0, # 0: MUMPS, 1: GMRes with block diagonal precon, 2: GMRes with block Schur precon
         Re:float = 10, # Reynolds number. With using domainsize and unit advective velocity, this is 1/nu
         N:int = 10, # Elements in x & y
         Pu:int = 2, # Polynomial order u
         Pp:int = 1, # Polynomial order p
     # Function space
     L = 1 # Domain size
     domain = mesh.create_box(MPI.COMM_WORLD, [(0,0,0),(L,L,L)], [N,N,N], mesh.CellType.hexahedron)
     Ve = element("Lagrange", domain.basix_cell(), Pu, shape=(domain.geometry.dim,))
     Qe = element("Lagrange", domain.basix_cell(), Pp)
     W_el = mixed_element([Ve, Qe])
     W = fem.functionspace(domain, W_el)
     V, WV_map = W.sub(0).collapse() # DOF map from W to V
     Q, WQ_map = W.sub(1).collapse() # DOF map from W to Q
     # Trial and test functions
     w_trial = ufl.TrialFunction(W)
     u, p = ufl.split(w_trial)
     v, q = ufl.TestFunctions(W)
     u_p = fem.Function(W)
     # Physical parameters
     nu = fem.Constant(domain, PETSc.ScalarType(1/Re)) # Viscosity
     u_adv = fem.Function(V) # Dummy advection velocity, to mimic a Navier-Stokes solve
     u_adv.interpolate( lambda x: ( np.sin(2*np.pi*x[0,:]/L)*np.cos(2*np.pi*x[1,:]/L)*np.sin(np.pi*x[2,:]/L), \
                                   -np.cos(2*np.pi*x[0,:]/L)*np.sin(2*np.pi*x[1,:]/L)*np.sin(np.pi*x[2,:]/L),
                                    0*x[0,:] ) )
     # Linearized Navier-Stokes weak form
     B = inner( dot(u_adv,nabla_grad(u)), v )*dx \
       + inner( 2*nu*sym(nabla_grad(u)), sym(nabla_grad(v)) )*dx \
       - dot( q, div(u) )*dx \
       - dot( div(v), p )*dx
     F = dot( q, fem.Constant(domain, PETSc.ScalarType(0)) )*dx
     P = inner( dot(u_adv,nabla_grad(u)), v )*dx \
       + dot( 1/nu*q, p )*dx
     # Boundary conditions
     def node_origin(x):
          return np.logical_and(np.isclose(x[0],0),np.logical_and(np.isclose(x[1],0),np.isclose(x[2],0)))
     dof_origin_p = fem.locate_dofs_geometrical((W.sub(1), Q), node_origin)
     bc_zero_p = fem.dirichletbc(fem.Function(Q), dof_origin_p, W.sub(1))
     def walls(x):
          return np.isclose(x[0],0) | np.isclose(x[0], L) | np.isclose(x[1],0) | np.isclose(x[2], 0) | np.isclose(x[2], L)
     facets_wall = mesh.locate_entities_boundary(domain, domain.geometry.dim-1, walls)
     dofs_walls = fem.locate_dofs_topological((W.sub(0), V), domain.geometry.dim-1, facets_wall)
     bc_zero_u = fem.dirichletbc(fem.Function(V), dofs_walls, W.sub(0))
     def lid(x):
          return np.isclose(x[1], L)
     facets_lid = mesh.locate_entities_boundary(domain, domain.geometry.dim-1, lid)
     dofs_lid = fem.locate_dofs_topological((W.sub(0), V), domain.geometry.dim-1, facets_lid)
     u_unit = fem.Function(V)
     u_unit.interpolate(lambda x: (np.ones(x.shape[1]),np.zeros(x.shape[1]),np.zeros(x.shape[1])) )
     bc_unit_u = fem.dirichletbc(u_unit, dofs_lid, W.sub(0))
     bcs = [bc_zero_p,bc_zero_u,bc_unit_u]
     # Assemble matrices
     Bmat = assemble_matrix(fem.form(B), bcs=bcs)
     Bmat.assemble()
     Pmat = assemble_matrix(fem.form(P), bcs=bcs)
     Pmat.assemble()
     Fvec = assemble_vector(fem.form(F))
     fem.petsc.apply_lifting(Fvec, [fem.form(B)], bcs=[bcs])
     Fvec.ghostUpdate(addv=PETSc.InsertMode.ADD, mode=PETSc.ScatterMode.REVERSE)
     fem.petsc.set_bc(Fvec, bcs)
     # Below is where the solver and its settings are
     ksp = PETSc.KSP().create(domain.comm)
     if CASE == 1:
          ksp.setOperators(Bmat, Pmat)
          ksp.setOperators(Bmat)
     opts = PETSc.Options()
     ksp.setOptionsPrefix("")
     option_prefix = ksp.getOptionsPrefix()
     if CASE == 0:
          # Direct solve
          opts[f"{option_prefix}ksp_type"] = "preonly"
          opts[f"{option_prefix}pc_type"] = "lu"
          opts[f"{option_prefix}pc_factor_mat_solver_type"] = "mumps"
          # GMRes with block-based preconditioning
          opts[f"{option_prefix}ksp_type"] = "gmres"
          opts[f"{option_prefix}ksp_pc_side"] = "right"
          W_indexmap = W.dofmap.index_map
          localdofs_u = np.setdiff1d( W_indexmap.local_to_global(np.array(WV_map)), W_indexmap.ghosts ) # getting the global velocity dofs that live on this core
          localdofs_p = np.setdiff1d( W_indexmap.local_to_global(np.array(WQ_map)), W_indexmap.ghosts ) # getting the global pressure dofs that live on this core
          IS_u = PETSc.IS().createGeneral(np.array(localdofs_u,dtype=np.int32), comm=domain.comm).sort()
          IS_p = PETSc.IS().createGeneral(np.array(localdofs_p,dtype=np.int32), comm=domain.comm).sort()
          pc = ksp.getPC()
          pc.setType("fieldsplit")
          pc.setFieldSplitIS(('u',IS_u),('p',IS_p))
          ksp_u, ksp_p = pc.getFieldSplitSubKSP()
          if CASE == 1:
               # Block-diagonal precondition, AMG on velocity, Jacobi on pressure mass
               pc.setFieldSplitType(PETSc.PC.CompositeType.ADDITIVE)
          elif CASE == 2:
               # Schur-based precondition, AMG on velocity, Jacobi on Schur complement.
               pc.setFieldSplitType(PETSc.PC.CompositeType.SCHUR)
               pc.setFieldSplitSchurFactType(PETSc.PC.FieldSplitSchurFactType.UPPER)
               pc.setFieldSplitSchurPreType(PETSc.PC.FieldSplitSchurPreType.SELFP)
          option_prefix_u = ksp_u.getOptionsPrefix()
          opts[f"{option_prefix_u}ksp_type"] = "preonly" # Precondition only once in Newton iterations
          opts[f"{option_prefix_u}pc_type"] = "hypre" # Hypre (algebraic multigrid) preconditioning for p-block
          opts[f"{option_prefix_u}pc_hypre_type"] = "boomeramg" # Choice of implementation
          opts[f"{option_prefix_u}pc_hypre_boomeramg_coarsen_type"] = "pmis" # Grid coarsening strategy
          opts[f"{option_prefix_u}pc_hypre_boomeramg_interp_type"] = "FF1" # Projection on to coarser grid
          opts[f"{option_prefix_u}pc_hypre_boomeramg_strong_threshold"] = "0.5" # Coarsening limit
          option_prefix_p = ksp_p.getOptionsPrefix()
          opts[f"{option_prefix_p}ksp_type"] = "preonly" # Precondition only once in Newton iterations
          opts[f"{option_prefix_p}pc_type"] = "jacobi"
          ksp_u.setFromOptions()
          ksp_p.setFromOptions()
     ksp.setFromOptions()
     # Above is where the solver and its settings are
     start = time.time()
     ksp.solve(Fvec, u_p.x.petsc_vec)
     end = time.time()
     u_sol,p_sol = [f.collapse() for f in u_p.split()]
     uL2 = fem.assemble_scalar( fem.form(ufl.inner(u_sol, u_sol) * ufl.dx) )
     uL2 = domain.comm.allreduce(uL2, op=MPI.SUM)
     if MPI.COMM_WORLD.rank == 0:
          print('runtime:', end - start)
          print('dofs:', (N*Pu-1)**3*3+(N*Pp+1)**3)
          print('L2 norm:', uL2)
          postprocessing_data = {'case':CASE,'Re':Re,'N':N,'Pu':Pu,'Pp':Pp,'time':float(end-start),'dofs':(N*Pu-1)**3*3+(N*Pp+1)**3}
          with open(outputdir+'/postprocessdata.pickle', 'wb') as handle:
               pickle.dump(postprocessing_data, handle, protocol=pickle.HIGHEST_PROTOCOL)
While the Schur-based preconditioner performs quite well, it doesn’t show perfect weak scaling. I believe that is to be expected due to the ‘selfp’ option. Better would be to combine the two iterative approaches; approximate the Schur complement with the pressure mass matrix, while retaining the ‘upper’ block. That should give near-perfect (weak) scaling. I believe this is done in:
- [Rafinex-external-RIFLE / FEniCSx-pctools · GitLab](https://gitlab.com/rafinex-external-rifle/fenicsx-pctools)
- [GitHub - marchirschvogel/ambit: FEniCSx-based cardiovascular multi-physics solver](https://github.com/marchirschvogel/ambit)
Those implementations are a bit too invasive for me now, but if someone is interested in implementing a light-weight version thereof I’d be interested to be kept in the loop.
_[View the full topic](https://fenicsproject.discourse.group/t/precondition-appears-not-to-happen/15969)._
