Hi! I have a gmsh mesh and the separate array of markers for every point of this mesh. I want to create UserExpression and project this expression on the function space. The problem is next: how can I get the index of the current evaluated point in the markers array? I want to do something like this (simplified example):
class MyExpression(UserExpression):
super().__init__(**kwargs)
self.markers = markers
# In reality we don't have idx variable
def eval(self, values, x, idx):
point_marker = self.markers[idx]
if point_marker == 0:
values[0] = x[0] ** 2
values[0] = 0
def value_shape(self):
return ()
mesh = UnitSquareMesh(2, 2)
V = FunctionSpace(mesh, 'Lagrange', 1)
markers = [1, 0, 1, 0, 1, 0, 1, 0]
expr = MyExpression(markers)
result = project(expr, V)
To me it seems easier to first define your custom UserExpression after which you apply the markers to select an appropriate part of your solution. You can use the FEniCS MeshFunction to define your markers, or use your own array. Try something like this:
mesh = UnitSquareMesh(10, 10)
# Interpolate expression
def eval(self, values, x):
return ()
expr = MyExpression(degree=1)
u = project(expr, V)
# Define markers
vertex_markers = MeshFunction("size_t", mesh, dim=0)
vertex_markers.set_all(0)
for vertex in vertices(mesh):
if vertex.x(0) <= 0.5: # Example
vertex_markers.set_value(vertex.index(), 1)
# Apply on expr
v2d = vertex_to_dof_map(V)
u.vector()[v2d] = u.vector()[v2d] * vertex_markers.array()
