Real-space Lagrange multiplier constraint silently violated (non-deterministically) when a periodic MPC slave/master pair spans different MPI ranks — reproducible on v0.10.5 and v0.11.0
I’m solving a periodic elasticity/Poisson-type problem where the periodic fluctuation field v (in a MultiPointConstraint-constrained space V) has its mean pinned to zero via a scalar Lagrange multiplier gamma living in a “Real” space R (scifem.create_real_functionspace). I expect that
sum(∫v dx) ≈ 1e-17 (machine precision) for any number of MPI ranks, since this is exactly what the Lagrange multiplier system is solving for. This is what happens:
  • -n 1: always correct (~1e-19).
  • -n 2 / -n 3 / -n 4: frequently wrong, but not consistently — the same script, same parameters, same rank count occasionally gives the correct machine-precision result and occasionally doesn’t, run to run.
    Here a minimal reproducer script:
    import dolfinx.fem.petsc
    from dolfinx.mesh import create_rectangle, CellType, GhostMode
    from scifem import create_real_functionspace
    from dolfinx_mpc import (
        MultiPointConstraint,
        create_matrix_nest,
        assemble_matrix_nest,
        create_vector_nest,
        assemble_vector_nest,
    comm = MPI.COMM_WORLD
    Lx, Ly = 1.0, 0.3
    nx, ny = 40, 12
    mesh = create_rectangle(
        comm,
        [[0.0, 0.0], [Lx, Ly]],
        [nx, ny],
        cell_type=CellType.triangle,
        ghost_mode=GhostMode.shared_facet,
    R = create_real_functionspace(mesh)
    vh = dolfinx.fem.Function(V, name="v")
    bcs = []
    def is_right(x):
        return np.isclose(x[0], Lx)
    def is_top(x):
        return np.isclose(x[1], Ly)
    mpc = MultiPointConstraint(V)
    def slave_to_master_map_1(x):
        out_x = x.copy()
        out_x[1] = x[1] - Ly
        idx = is_right(x)
        out_x[1][idx] = np.nan
        return out_x
    mpc.create_periodic_constraint_geometrical(V, is_top, slave_to_master_map_1, bcs)
    def slave_to_master_map_0(x):
        out_x = x.copy()
        out_x[0] = x[0] - Lx
        idx = is_top(x)
        out_x[0][idx] = np.nan
        return out_x
    mpc.create_periodic_constraint_geometrical(V, is_right, slave_to_master_map_0, bcs)
    def slave_to_master_map_corner(x):
        out_x = x.copy()
        idx = np.logical_and(is_right(x), is_top(x))
        out_x[0][~idx] = np.nan
        out_x[1][~idx] = np.nan
        return out_x
    mpc.create_periodic_constraint_geometrical(V, is_top, slave_to_master_map_corner, bcs)
    mpc.finalize()
    mpc_r = MultiPointConstraint(R)
    mpc_r.finalize()
    v = ufl.TrialFunction(V)
    gamma = ufl.TrialFunction(R)
    v_star = ufl.TestFunction(V)
    dl = ufl.TestFunction(R)
    Eps = dolfinx.fem.Constant(mesh, dolfinx.default_scalar_type(1.0))
    zero = dolfinx.fem.Constant(mesh, dolfinx.default_scalar_type(0.0))
    a00 = ufl.inner(ufl.grad(v), ufl.grad(v_star)) * ufl.dx
    a01 = ufl.inner(gamma, v_star) * ufl.dx
    a10 = ufl.inner(v, dl) * ufl.dx
    a11 = None
    a = [
        [dolfinx.fem.form(a00), dolfinx.fem.form(a01)],
        [dolfinx.fem.form(a10), dolfinx.fem.form(a11)],
    L0 = -ufl.inner(Eps, v_star) * ufl.dx
    L1 = ufl.inner(zero, dl) * ufl.dx
    L = [dolfinx.fem.form(L0), dolfinx.fem.form(L1)]
    A = create_matrix_nest(a, [mpc, mpc_r])
    assemble_matrix_nest(A, a, [mpc, mpc_r], bcs)
    b = create_vector_nest(L, [mpc, mpc_r])
    assemble_vector_nest(b, L, [mpc, mpc_r])
    for bi in b.getNestSubVecs():
        bi.ghostUpdate(addv=PETSc.InsertMode.ADD, mode=PETSc.ScatterMode.REVERSE)
    bcs0 = dolfinx.fem.bcs_by_block(dolfinx.fem.extract_function_spaces(L), bcs)
    dolfinx.fem.petsc.set_bc(b, bcs0)
    ksp = PETSc.KSP().create(mesh.comm)
    ksp.setOperators(A)
    ksp.setType("preonly")
    pc = ksp.getPC()
    pc.setType("lu")
    ksp.setFromOptions()
    Xi = b.copy()
    ksp.solve(b, Xi)
    Xi0 = Xi.getNestSubVecs()[0]
    Xi0.copy(vh.x.petsc_vec)
    vh.x.scatter_forward()
    mpc.backsubstitution(vh)
    mean_local = dolfinx.fem.assemble_scalar(dolfinx.fem.form(vh * ufl.dx))
    mean_global = comm.allreduce(mean_local, op=MPI.SUM)
    if comm.rank == 0:
        print(f"MPI size={comm.size}  mean(v)_global={mean_global:.6e}")
Could you try the same thing with the basix.ufl.real_element which was introduced in 0.11?
I’ve refactored that a few times now to ensure that it is correct:
I modified the minimal example by simply replacing R with R = dolfinx.fem.functionspace(mesh, basix.ufl.real_element(mesh.basix_cell(), ())), but I am still experiencing the exact same issue.
Weird. I’ll have a look.
@czolesi1 there are a few things to improve in your code.
Instead of using a mapping for each side, you can map them all at once with:
atol = 1e-12
def is_right(x):
    return np.isclose(x[0], Lx, atol=atol)
def is_top(x):
    return np.isclose(x[1], Ly, atol=atol)
def slave_boundary(x):
    return np.isclose(x[0], Lx, atol=atol) | np.isclose(x[1], Ly, atol=atol)
# mapping from slave -> master
def periodic_relation(x):
    out = np.zeros_like(x)
    out[0] = x[0] - np.isclose(x[0], Lx, atol=atol)
    out[1] = x[1] - np.isclose(x[1], Ly, atol=atol)
    return out
mpc.create_periodic_constraint_geometrical(V, slave_boundary, periodic_relation, [])
mpc.finalize()
furthermore.
The main error lies in the definition of:
which in turn is used in:
In parallel, you require additional information about ghosts that the MPC add in. Therefore, vh should be created as:
vh = dolfinx.fem.Function(mpc.function_space, name="vh")
after the finalization of mpc.
Full working script:
    create_matrix_nest,
    create_vector_nest,
Lx, Ly = 1.0, 0.3
nx, ny = 40, 12
    comm,
    [nx, ny],
import basix.ufl
r_el = basix.ufl.real_element(mesh.basix_cell(), value_shape=())
R = dolfinx.fem.functionspace(mesh, r_el)
bcs = []
atol = 1e-12
def is_right(x):
def is_top(x):
    return out
mpc.finalize()
mpc_r.finalize()
a11 = None
a = [
    bi.ghostUpdate(addv=PETSc.InsertMode.INSERT, mode=PETSc.ScatterMode.FORWARD)
ksp.setOperators(A)
pc = ksp.getPC()
pc.setType("lu")
ksp.setErrorIfNotConverged(True)
Xi = b.copy()
ksp.solve(b, Xi)
if comm.rank == 0:
Thanks a lot! It works now
Please do not post further comments on this, as the problem is already solved in the post above: Real-space Lagrange multiplier constraint silently violated (non-deterministically) when a periodic MPC slave/master pair spans different MPI ranks — reproducible on v0.10.5 and v0.11.0 - #5 by dokken
