Hello, I have been working with the tutorial code navier-stokes from dokken as the basis for my work. I have a few questions:
- First, to resize the mesh to a considerable length, say L = 5000 and H = 300, is it enough to change the values?
- Can the values for viscosity and density be used if the fluid is air?
- If the upper boundary needs to be free, is there any literature on this type of physics? I have imposed a homogeneous Neumann boundary for velocity and pressure, but the velocities are unrealistic.
I would really appreciate your response, as I am just getting started with the software.
import tqdm.autonotebook
from basix.ufl import element
from dolfinx.fem import (Constant, Function, functionspace,
assemble_scalar, dirichletbc, form, locate_dofs_topological, set_bc)
create_vector, create_matrix, set_bc)
from dolfinx.io import (VTXWriter, distribute_entity_data, gmshio)
from ufl import (FacetNormal, Identity, Measure, TestFunction, TrialFunction,
as_vector, div, dot, ds, dx, inner, lhs, grad, nabla_grad, rhs, sym, system)
L = 5000
H = 500
c_x = c_y = 250
r = 0.05
gdim = 2
mesh_comm = MPI.COMM_WORLD
model_rank = 0
rectangle = gmsh.model.occ.addRectangle(0, 0, 0, L, H, tag=1)
obstacle = gmsh.model.occ.addDisk(c_x, c_y, 0, r, r)
fluid = gmsh.model.occ.cut([(gdim, rectangle)], [(gdim, obstacle)])
gmsh.model.occ.synchronize()
fluid_marker = 1
assert (len(volumes) == 1)
gmsh.model.addPhysicalGroup(volumes[0][0], [volumes[0][1]], fluid_marker)
gmsh.model.setPhysicalName(volumes[0][0], fluid_marker, "Fluid")
inlet_marker, outlet_marker, wall_marker, obstacle_marker, top_marker = 2, 3, 4, 5, 6
inflow, outflow, walls, obstacle, top = [], [], [], [], []
for boundary in boundaries:
if np.allclose(center_of_mass, [0, H / 2, 0]):
inflow.append(boundary[1])
elif np.allclose(center_of_mass, [L, H / 2, 0]):
outflow.append(boundary[1])
elif np.allclose(center_of_mass, [L / 2, 0, 0]):
walls.append(boundary[1])
elif np.allclose(center_of_mass, [L / 2, H, 0]):
top.append(boundary[1])
obstacle.append(boundary[1])
gmsh.model.setPhysicalName(1, inlet_marker, "Inlet")
gmsh.model.addPhysicalGroup(1, outflow, outlet_marker)
gmsh.model.setPhysicalName(1, outlet_marker, "Outlet")
gmsh.model.addPhysicalGroup(1, obstacle, obstacle_marker)
gmsh.model.setPhysicalName(1, obstacle_marker, "Obstacle")
gmsh.model.addPhysicalGroup(1, top, top_marker)
gmsh.model.setPhysicalName(1, top_marker, "Top")
res_min = r / 3
distance_field = gmsh.model.mesh.field.add("Distance")
gmsh.model.mesh.field.setNumbers(distance_field, "EdgesList", obstacle)
threshold_field = gmsh.model.mesh.field.add("Threshold")
gmsh.model.mesh.field.setNumber(threshold_field, "IField", distance_field)
gmsh.model.mesh.field.setNumber(threshold_field, "LcMin", res_min)
gmsh.model.mesh.field.setNumber(threshold_field, "LcMax", 0.25 * H)
gmsh.model.mesh.field.setNumber(threshold_field, "DistMin", r)
gmsh.model.mesh.field.setNumber(threshold_field, "DistMax", 2 * H)
min_field = gmsh.model.mesh.field.add("Min")
gmsh.model.mesh.field.setNumbers(min_field, "FieldsList", [threshold_field])
gmsh.model.mesh.field.setAsBackgroundMesh(min_field)
gmsh.option.setNumber("Mesh.Algorithm", 8)
gmsh.option.setNumber("Mesh.RecombinationAlgorithm", 2)
gmsh.option.setNumber("Mesh.RecombineAll", 1)
gmsh.option.setNumber("Mesh.SubdivisionAlgorithm", 1)
gmsh.model.mesh.setOrder(2)
mesh, _, ft = gmshio.model_to_mesh(gmsh.model, mesh_comm, model_rank, gdim=gdim)
ft.name = "Facet markers"
t = 0
T = 3600 # Final time
dt = 3 # Time step size
num_steps = int(T / dt)
mu = Constant(mesh, PETSc.ScalarType(1.87e-5 )) # Dynamic viscosity
rho = Constant(mesh, PETSc.ScalarType(1.225 )) # Density
v_cg2 = element("Lagrange", mesh.topology.cell_name(), 2, shape=(mesh.geometry.dim, ))
s_cg1 = element("Lagrange", mesh.topology.cell_name(), 1)
V = functionspace(mesh, v_cg2)
Q = functionspace(mesh, s_cg1)
W = functionspace(mesh, s_cg1)
fdim = mesh.topology.dim - 1
# Define boundary conditions
class InletVelocity:
def __call__(self, x):
values = np.zeros((gdim, x.shape[1]), dtype=PETSc.ScalarType)
values[0] = 2.0 * (x[1] / 1.0) ** 0.16
return values
# Inlet
u_inlet = Function(V)
inlet_velocity = InletVelocity()
u_inlet.interpolate(inlet_velocity)
bcu_inflow = dirichletbc(u_inlet, locate_dofs_topological(V, fdim, ft.find(inlet_marker)))
# Walls
u_nonslip = np.array((0,) * mesh.geometry.dim, dtype=PETSc.ScalarType)
V1, _ = V.sub(1).collapse()
u_slip = Function(V1)
u_slip.x.array[:] = 0.0
bcu_walls = dirichletbc(u_slip, locate_dofs_topological(V, fdim, ft.find(wall_marker)), V)
# Obstacle
bcu_obstacle = dirichletbc(u_nonslip, locate_dofs_topological(V, fdim, ft.find(obstacle_marker)), V)
bct_obstacle = dirichletbc(T_hot, locate_dofs_topological(W, fdim, ft.find(obstacle_marker)), W)
# Outlet
bcp_outlet = dirichletbc(PETSc.ScalarType(0), locate_dofs_topological(Q, fdim, ft.find(outlet_marker)), Q)
bcu = [bcu_inflow, bcu_obstacle, bcu_walls]
bcp = [bcp_outlet]
u_ = Function(V)
u_.name = "u"
u_s = Function(V)
u_n = Function(V)
u_n1 = Function(V)
p = TrialFunction(Q)
q = TestFunction(Q)
p_ = Function(Q)
p_.name = "p"
phi = Function(Q)
f = Constant(mesh, PETSc.ScalarType((0, 0))
F1 = rho / k * dot(u - u_n, v) * dx
F1 += inner(dot(1.5 * u_n - 0.5 * u_n1, 0.5 * nabla_grad(u + u_n)), v) * dx
F1 += 0.5 * inner(mu * grad(u + u_n), grad(v)) * dx - dot(p_, div(v)) * dx
F1 += dot(f, v) * dx
a1 = form(lhs(F1))
L1 = form(rhs(F1))
A1 = create_matrix(a1)
b1 = create_vector(L1)
a2 = form(dot(grad(p), grad(q)) * dx)
L2 = form(-rho / k * dot(div(u_s), q) * dx)
A2.assemble()
b2 = create_vector(L2)
a3 = form(rho * dot(u, v) * dx)
L3 = form(rho * dot(u_s, v) * dx - k * dot(nabla_grad(phi), v) * dx)
A3 = assemble_matrix(a3)
A3.assemble()
b3 = create_vector(L3)
# Solver for step 1
solver1 = PETSc.KSP().create(mesh.comm)
solver1.setOperators(A1)
pc1 = solver1.getPC()
pc1.setType(PETSc.PC.Type.JACOBI)
# Solver for step 2
solver2 = PETSc.KSP().create(mesh.comm)
solver2.setOperators(A2)
solver2.setType(PETSc.KSP.Type.MINRES)
pc2 = solver2.getPC()
pc2.setHYPREType("boomeramg")
# Solver for step 3
solver3 = PETSc.KSP().create(mesh.comm)
solver3.setOperators(A3)
pc3 = solver3.getPC()
from pathlib import Path
folder = Path("/home/gerard/Desktop/benchmark_buoyancy")
folder.mkdir(exist_ok=True, parents=True)
vtx_u = VTXWriter(mesh.comm, folder / "dfg2D-3-u.bp", [u_], engine="BP4")
vtx_p = VTXWriter(mesh.comm, folder / "dfg2D-3-p.bp", [p_], engine="BP4")
vtx_u.write(t)
vtx_p.write(t)
progress = tqdm.autonotebook.tqdm(desc="Solving PDE", total=num_steps)
for i in range(num_steps):
progress.update(1)
# Update current time step
# Update inlet velocity
inlet_velocity.t = t
A1.zeroEntries()
assemble_matrix(A1, a1, bcs=bcu)
A1.assemble()
with b1.localForm() as loc:
loc.set(0)
assemble_vector(b1, L1)
set_bc(b1, bcu)
solver1.solve(b1, u_s.x.petsc_vec)
u_s.x.scatter_forward()
# Step 2: Pressure corrrection step
with b2.localForm() as loc:
loc.set(0)
assemble_vector(b2, L2)
set_bc(b2, bcp)
solver2.solve(b2, phi.x.petsc_vec)
phi.x.scatter_forward()
p_.x.petsc_vec.axpy(1, phi.x.petsc_vec)
p_.x.scatter_forward()
with b3.localForm() as loc:
loc.set(0)
assemble_vector(b3, L3)
solver3.solve(b3, u_.x.petsc_vec)
u_.x.scatter_forward()
# Write solutions to file
vtx_u.write(t)
vtx_p.write(t)
with u_.x.petsc_vec.localForm() as loc_, u_n.x.petsc_vec.localForm() as loc_n, u_n1.x.petsc_vec.localForm() as loc_n1:
loc_n.copy(loc_n1)
loc_.copy(loc_n)
progress.close()
vtx_u.close()
vtx_p.close()
