Rotational Constraint at the center of a beam
Hi Guys,
I am trying to compute mode shapes for a 2D wedge (in XY plane) with U_x=0 and UR_z=0 (rotation about the z-axis) constraints at the center.
When I tried for the left and right clamped constraints it was working correctly. But for the center constraint, I am getting incorrect results
from ufl import nabla_div, nabla_grad
from pathlib import Path
import json
from mshr import Polygon, generate_mesh
from scipy.optimize import root
from math import cos, cosh
import sys
import argparse
from functools import partial
import pandas as pd
import meshio as mio
from stl import mesh as mstl
# General Functions
def int_zfill(index, total_len):
    from math import floor, log10
    return str(index).zfill(1+floor(log10(total_len)))
print(int_zfill(2,271))
# File locations
main_dir = Path(".")
out_dir = main_dir / "CaseElasWedge_out"
properties_file = main_dir / "properties.json"
mesh_file = main_dir / "mesh.xml"
plot_dir = main_dir / "plots"
fdebug_file = out_dir / "FloatingAce_mkbound_0.csv"
fmotion_file = out_dir / "floatinginfo/FloatingMotion_mk11.csv"
fforce_file = out_dir / "forces/_FloatingForce.csv"
stress_dir = out_dir / "stress"
nonlin = False
Path.cwd()
mesh_file
# Meshing
# Paths to the material property folders
plot_dir.mkdir(parents=True, exist_ok=True)
# importing properties
with properties_file.open(mode="r") as pf:
    properties = json.load(pf)
wedge_length = 0.3
dim = 2
N_eig = 16   # number of eigenvalues
wedge_thickness = properties["thickness"]
youngs_modulus = Constant(properties["young's modulus"])
poisson_ratio = Constant(properties["poisson's ratio"])
density = Constant(properties["density"])
beta_deg = properties["beta"]
beta_rad = np.deg2rad(beta_deg)
cosb = np.cos(beta_rad)
sinb = np.sin(beta_rad)
gravity = 9.81
domain = Polygon([
    Point(-wedge_length * cosb, wedge_length * sinb),
    Point(0.0, 0.0),
    Point(wedge_length * cosb, wedge_length * sinb),
    Point(wedge_length * cosb, wedge_length * sinb + wedge_thickness * cosb),
    Point(0.0, wedge_thickness),
    Point(-wedge_length * cosb, wedge_length * sinb + wedge_thickness * cosb),
mesh = generate_mesh(domain,100)
mesh
strain_gauges = [
    Point(0.03 * cosb, 0.03 * sinb + wedge_thickness / cosb),
    Point(0.12 * cosb, 0.12 * sinb + wedge_thickness / cosb)
strain_gauges
File("mesh.pvd") << mesh
File("mesh.xml") << mesh
msh = mio.read("mesh000000.vtu")
mio.write("mesh_xy.stl",msh)
stl_mesh = mstl.Mesh.from_file('mesh_xy.stl')
stl_mesh.rotate([1.0, 0.0, 0.0], np.radians(270))
stl_mesh.save('mesh_xz.stl')
    (0.0, 0.0),
    properties
# Strain and Stress Functions
V = VectorFunctionSpace(mesh, 'Lagrange', degree=1)
v2d = vertex_to_dof_map(V).reshape((-1, dim))
d2v = dof_to_vertex_map(V)[range(0, len(dof_to_vertex_map(V)), dim)]/dim
u_ = TrialFunction(V)
du = TestFunction(V)
# Lame coefficient for constitutive relation
mu = Constant( youngs_modulus / (2.0*(1+poisson_ratio)) )
lmbda = Constant(youngs_modulus * poisson_ratio/((1+poisson_ratio)*(1-2*poisson_ratio)))
def eps(v):
    return 0.5*(nabla_grad(v) + nabla_grad(v).T)
def green_eps(v):
    I = Identity(dim)
    F = I + nabla_grad(v)
    return 0.5*(F.T*F - I)
def sigma(eps,v):
    return 2.0*mu*eps(v) + lmbda*tr(eps(v))*Identity(dim)
strain = eps
stress = partial(sigma,strain)
mesh.coordinates()
# Boundary Conditions
def left(x, on_boundary):
    return on_boundary and near(x[0], -wedge_length * cosb)
def right(x, on_boundary):
    return on_boundary and near(x[0], wedge_length * cosb)
def center(x, on_boundary):
# https://fenicsproject.org/qa/9617/2d-boundary-condition/
# bc = DirichletBC(V, Constant((0,0)), left)
# bc = DirichletBC(V, Constant((0,0)), right)
bc = DirichletBC(V.sub(0), Constant(0), center)
# bc = None
# Compute solution
# u = TrialFunction(V)
# d = u.geometric_dimension() # space dimension
# v = TestFunction(V)
# f = Constant((0,-density*gravity))
# T = Constant((0,0))
# a = inner(stress(u), strain(v))*dx
# L = dot(f, v)*dx + dot(T, v)*ds
# u = Function(V, name="displacement")
# solve(a == L, u, bc)
# with XDMFFile(f"{main_dir}/deflection.xdmf") as file_results:
#     file_results.parameters["flush_output"] = True
#     file_results.parameters["functions_share_mesh"] = True
#     file_results.write(u, 0.)
# plot(u)
# Compute Mode Shapes and frequencies
k_form = inner(stress(du),strain(u_))*dx
l_form = Constant(1.)*u_[0]*dx
K = PETScMatrix()
b = PETScVector()
assemble_system(k_form, l_form, bc, A_tensor=K, b_tensor=b)
m_form = density*dot(du,u_)*dx
M = PETScMatrix()
assemble(m_form, tensor=M)
# https://fenicsproject.discourse.group/t/modal-analysis-of-a-beam-with-plain-strain/3952
bc.zero(M)
eigensolver = SLEPcEigenSolver(K, M)
eigensolver.parameters['problem_type'] = 'gen_hermitian'
eigensolver.parameters['spectral_transform'] = 'shift-and-invert'
eigensolver.parameters['spectral_shift'] = 0.0
print("Computing {} first eigenvalues...".format(N_eig))
eigensolver.solve(N_eig)
falpha = lambda x: cos(x)*cosh(x)+1
alpha = lambda n: root(falpha, (2*n+1)*pi/2.)['x'][0]
normal_M =  []
normal_K =  []
lamba = []
Modes = []
Modes_vectors = []
file_results = XDMFFile(f"{main_dir}/modes.xdmf")
format_len = np.ceil(np.log10(N_eig)).astype(int)
print("id - freq(Hz) - Ang Freq(rad/s) - Lambda")
for i in range(N_eig):
    # Extract eigenpair
    r, c, rx, cx = eigensolver.get_eigenpair(i)
    # 3D eigenfrequency
    freq_3D = sqrt(r)/2/pi
    lamba.append(r)
    print(f"{i+1} - {freq_3D:.3f} - {2*np.pi*freq_3D:.3f} - {r:.3f}", )
    # Initialize function and assign eigenvector
    eigenmode = Function(V,name=f"Eigenvector {int_zfill(i+1, N_eig)}")
    eigenmode.vector()[:] = rx
    Modes.append(rx[:].reshape((dim,int(rx[:].shape[0]/dim)),order='F').T)
    Modes_vectors.append(eigenmode)
    normal_M.append(np.dot(rx[:],M*rx[:]))
    normal_K.append(np.dot(rx[:],K*rx[:]))
    # Function can be plotted as usual:
    rx_func = Function(V)
    rx_func.vector()[:] = rx
    file_results.write(eigenmode, 0.)
Can anyone tell me, how to apply U_x=0 and UR_z=0 constraint at the center of the wedge?
