I am not that familiar to share thoughts on your suggestion. If I provide you an MWE, could you use it to try it out?
#%% input parameters
fov_R = 1 # radius of the field of view
R_int = 0.5 # radial position of the interface
n_stat_poles = 8 # number of poles i.e. sector
sec_angle = 2*np.pi/n_stat_poles
rot_angle = 350 * np.pi / 180 # angle of rotation of the rotor
fem_order = 2
rot_dom_idx = (1, ) # rotating (top) domain, by inspection
stat_dom_idx = (2, 3)
mag_dom = (2,) # by inspection
#%% cad model
gmsh.option.setNumber("General.Terminal", 0)
gmsh.clear()
occ = gmsh.model.occ
gdim = 2
c1 = occ.addCircle(0, 0, 0, fov_R, angle1=np.pi/2-sec_angle/2, angle2=np.pi/2+sec_angle/2)
pnts = occ.getEntities(0)
p0 = occ.addPoint(0, 0, 0)
l1 = occ.addLine(p0, pnts[0][1])
l2 = occ.addLine(p0, pnts[1][1])
loop = occ.addCurveLoop([c1, l1, l2])
slice_ = occ.addPlaneSurface([loop])
slice_copy = occ.copy([(gdim, slice_)])
d1 = occ.addDisk(0, 0, 0, fov_R, fov_R)
d2 = occ.addDisk(0, 0, 0, R_int, R_int)
rot = occ.cut([(gdim, d1)], [(gdim, d2)])
stat = occ.addDisk(0, 0, 0, R_int, R_int)
occ.synchronize()
rot = occ.intersect([(gdim, slice_)], rot[0])
stat = occ.intersect(slice_copy, [(gdim, stat)])
r1 = occ.addRectangle(-0.025, 0.25, 0, 0.05, 0.2)
stat = occ.fragment(stat[0], [(gdim, r1)])
occ.synchronize()
all_doms = occ.getEntities(gdim)
all_doms = gmsh.model.getEntities(gdim)
for j, dom in enumerate(all_doms):
gmsh.model.addPhysicalGroup(dom[0], [dom[1]], j + 1) # create the main group/node
# number all boundaries
all_edges = gmsh.model.getEntities(gdim - 1)
for j, edge in enumerate(all_edges):
gmsh.model.addPhysicalGroup(edge[0], [edge[1]], edge[1]) # create the main group/node
all_edges = gmsh.model.getEntities(gdim - 2)
gmsh.model.mesh.refine()
mpi_rank = 0
dolfinx_model = dolfinx.io.gmsh.model_to_mesh(gmsh.model, MPI.COMM_WORLD, mpi_rank, gdim)
mesh, ct, ft, rt = dolfinx_model.mesh, dolfinx_model.cell_tags, dolfinx_model.facet_tags, dolfinx_model.ridge_tags
# gmsh.fltk.run()
#%% physical model
def rotate_mesh(mesh, ct, dom_idx, angle):
'''Rotate cells in submodains identified in dom_idx tuple by the specified angle'''
# https://fenicsproject.discourse.group/t/how-to-rotate-a-mesh-in-fenics/7162/6
from scipy.spatial.transform import Rotation
gdim = 2
# identify vertices that will be rotated
rot_cell_indices = [ct.find(idx) for idx in dom_idx]
rot_cell_indices = np.hstack(rot_cell_indices)
# vertices are shared between cells. Therefore, we keep only unique
cell_vertex_indices = dolfinx.cpp.mesh.entities_to_geometry(mesh._cpp_object, gdim, rot_cell_indices, False)
cell_vertex_indices = np.unique(cell_vertex_indices.ravel())
# finally apply rotation on identified vertices
rotation = Rotation.from_euler("z", angle, degrees=False)
mesh.geometry.x[cell_vertex_indices,:] = rotation.apply(mesh.geometry.x[cell_vertex_indices])
# rotate rotor
rotate_mesh(mesh, ct, np.hstack(rot_dom_idx), rot_angle)
Omega_A = dolfinx.fem.functionspace(mesh, ("CG", fem_order))
A, At = ufl.TrialFunction(Omega_A), ufl.TestFunction(Omega_A)
A0 = dolfinx.fem.Function(Omega_A) # for previous time step
A_3d, At_3d = ufl.as_vector((0, 0, A)), ufl.as_vector((0, 0, At))
A0_3d = ufl.as_vector((0, 0, A0))
def curl_2d(A):
return ufl.as_vector((A[2].dx(1), -A[2].dx(0), 0))
dx = ufl.Measure("dx", domain=mesh, subdomain_data=ct, metadata={"quadrature_degree": 8})
ds = ufl.Measure("ds", domain=mesh, subdomain_data=ft, metadata={"quadrature_degree": 8})
dS = ufl.Measure("dS", domain=mesh, subdomain_data=ft, metadata={"quadrature_degree": 8})
a = ufl.inner(1/1000*curl_2d(A_3d), curl_2d(At_3d))*dx(rot_dom_idx[0])
a += ufl.inner(curl_2d(A_3d), curl_2d(At_3d))*dx(tuple(stat_dom_idx))
# add permanent magnet
L = ufl.inner(dolfinx.fem.Constant(mesh, (0.0, 1.0, 0.0)), curl_2d(At_3d))*dx(mag_dom)
dbc = []
#%% MPC
# https://github.com/jorgensd/dolfinx_mpc/blob/main/python/demos/demo_periodic_geometrical.py
# periodicity constraint
def periodic_boundary_stator(x):
r = np.sqrt(x[0]**2+x[1]**2)
theta = np.arctan2(x[1], x[0])
sector_angle = 2*np.pi/n_stat_poles
bnd_marker = np.isclose(theta, np.pi/2 - sector_angle/2, atol=tol)
stator_marker = r <= R_int
return bnd_marker & stator_marker
def periodic_boundary_rotor(x, rot_angle):
bnd_marker = np.isclose(theta, np.pi/2 - sector_angle/2 + rot_angle, atol=tol)
rotor_marker = r >= R_int
return bnd_marker & rotor_marker
#Cyclic Symmetry Condition
def periodic_relation(x, rot_angle=0.0):
out_x = np.zeros(x.shape)
rot_mat = np.array([
[np.cos(sector_angle+rot_angle), -np.sin(sector_angle+rot_angle)],
[np.sin(sector_angle+rot_angle), np.cos(sector_angle+rot_angle)]
out_x[:2,:] = rot_mat @ x[:2,:]
return out_x
mpc = dolfinx_mpc.MultiPointConstraint(Omega_A)
tol = 250 * np.finfo(dolfinx.default_scalar_type).resolution
interface_bnd_idx = (12, 17) # rotor boundary, stator boundary - by visible inspection
mpc.create_contact_inelastic_condition(ft, interface_bnd_idx[0], interface_bnd_idx[1], eps2=tol, allow_missing_masters=True)
# stator periodicity
mpc.create_periodic_constraint_geometrical(Omega_A, periodic_boundary_stator, periodic_relation, dbc, scale=-1.0)
# rotor periodicity
lambda x: periodic_boundary_rotor(x, rot_angle),
lambda x: periodic_relation(x, rot_angle), dbc, scale=-1.0)
mpc.finalize()
petsc_options = {"pc_type": "lu", "pc_factor_mat_solver_type": "mumps"}
problem = dolfinx_mpc.problem.LinearProblem(a, L, mpc, bcs=dbc, petsc_options=petsc_options)
Az = problem.solve() # Wb/m
Az.x.scatter_forward()
Omega_B = dolfinx.fem.functionspace(mesh, ("DG", fem_order-1, (3,)))
B_stat = dolfinx.fem.Function(Omega_B)
B_expr = dolfinx.fem.Expression(curl_2d(ufl.as_vector((0, 0, Az))), Omega_B.element.interpolation_points)
B_stat.interpolate(B_expr)
#%% Generate pyvista plot
u_topology, u_cell_types, u_geometry = dolfinx.plot.vtk_mesh(Omega_A)
u_grid = pyvista.UnstructuredGrid(u_topology, u_cell_types, u_geometry)
u_grid.point_data["Az"] = Az.x.array
u_grid.set_active_scalars("Az")
u_plotter = pyvista.Plotter()
u_plotter.add_mesh(u_grid, show_edges=False, cmap="viridis")
u_plotter.view_xy()
if not pyvista.OFF_SCREEN:
u_plotter.show()
# |B|
u_topology, u_cell_types, u_geometry = dolfinx.plot.vtk_mesh(B_stat.function_space)
u_grid.point_data["B"] = np.sqrt(B_stat.x.array[::3]**2 + B_stat.x.array[1::3]**2)
u_grid.set_active_scalars("B")
u_plotter.view_xy()
u_plotter.show()
