Slope limiting for the St.Venant equations in DOLFINx
Hi, I am currently using a RK solver to solve the ST. Venant equations for a square channel given by
\frac{\partial A}{\partial t}+\frac{\partial Q}{\partial s}=0
and
\frac{\partial Q}{\partial t} + \frac{\partial}{\partial s}(\frac{Q^2}{A}+g A^2/(2 w)) + gA(S_f -S)=0
Here Q is the discharge, A the area of the flow, w the width of the channel, S the surface gradient and S_f the surface friction given by the Manning friction law.
To do this I use the discontinious Galerkin method (code given below). The code works fine, until shocks arise. Does anyone know of a good way to implement a slope limiter in DOLFINx?
from dolfinx import default_real_type, fem, has_adios2, io, mesh
from dolfinx.fem.petsc import LinearProblem, NonlinearProblem
import time
import pyvista
def butcher(order):
    """Butcher table data"""
    if order==2:
        # Explicit trapezium method
        b_runge=[1/2,1/2]
        c_runge=[0,1]
        a_runge=np.zeros((order,order),dtype=np.float64)
        a_runge[1,0]=1
    elif order==3:
        # Third-order RK3
        b_runge=[1/6,4/6,1/6]
        c_runge=[0,1/2,1]
        a_runge[1,0]=1/2
        a_runge[2,0]=-1
        a_runge[2,1]=2
    elif order==4:
        # "Classical" 4th-order Runge-Kutta method
        b_runge=[1/6,1/3,1/3,1/6]
        c_runge=np.array([0,1/2,1/2,1])
        a_runge[1,0]=1/2
        a_runge[2,1]=1/2
        a_runge[3,2]=1
    elif order==5:
        # Fehlberg 5th order
        b_runge=[16/135,0,6656/12825,28561/56430,-9/50,2/55]
        c_runge=[0,1/4,3/8,12/13,1,1/2]
        a_runge[1,0]=1/4
        a_runge[2,0:2]=[3/32,9/32]
        a_runge[3,0:3]=[1932/2197,-7200/2197,7296/2197]
        a_runge[4,0:4]=[439/216,-8,3680/513,-845/4104]
        a_runge[5,0:5]=[-8/27,2,-3544/2565,1859/4104,-11/40]
        print("INVALID ORDER")
        exit()
    return a_runge,b_runge,c_runge
# PARAMETERS
x_l=0.0
x_r=10.0
n_grid=100
t0=0.0
t_end=1.0
dt=1e-3
n_t=int((t_end-t0)/dt)
g=9.81
width=1.0
#The DG order
p=3
#inflow discharge
q_left = 1.0
#initial areas
A_left = 2.0
A_right = 1.0
#the RK order, which we take as the DG order plus one
n_RK=p+1
# MESH
domain=mesh.create_interval(
    MPI.COMM_WORLD,
    n_grid,
    [x_l,x_r])
#generate a vector valued function space that contains (A,q)
V=fem.functionspace(domain,("Discontinuous Lagrange",p,(2,)))
# FACET TAGGING
#the dimension of the boundaries
fdim=domain.topology.dim-1
#define the boundaries itself
def left_boundary(x):
    return np.isclose(x[0], x_l)
def right_boundary(x):
    return np.isclose(x[0], x_r)
#locate the boundaries
left_facets=mesh.locate_entities_boundary(domain,fdim,left_boundary)
right_facets=mesh.locate_entities_boundary(domain,fdim,right_boundary)
#store the indices in an array
facet_indices=np.hstack([left_facets,right_facets])
facet_markers=np.hstack([
    np.full(len(left_facets), 1, dtype=np.int32),
    np.full(len(right_facets), 2, dtype=np.int32)])
#sort the indices
sorted_facets=np.argsort(facet_indices)
#place tags on them
facet_tag = mesh.meshtags(
    domain,
    fdim,
    facet_indices[sorted_facets],
    facet_markers[sorted_facets]
#define ds, the integral over the boundary
ds=ufl.Measure("ds",domain=domain,subdomain_data=facet_tag)
# FUNCTIONS
u=fem.Function(V)
u_tmp=fem.Function(V)
v=ufl.TestFunction(V)
du=ufl.TrialFunction(V)
# INITIAL CONDITION
L=x_r-x_l
def initial_condition(x):
    #this generates a linear decrese/increase in A and sets q initially to one
    values = np.ones((2, x.shape[1]))
    # area
    values[0]=(A_left*(1.0-x[0]/L)+A_right*x[0]/L)
    # discharge initially one
    values[1]=1.0
    return values
#interpolate the initial conditions
u.interpolate(initial_condition)
# INFLOW BC
q_in=fem.Constant(domain,PETSc.ScalarType(q_left))
#DEFINE THE BED SLOPE
#the manning constant for this river
n_manning=0.01
def dz_ds(x):
    #this returns -e^-x, so the flow should be pushed to the right, as there is a negative height gradient
    return -1*ufl.exp(-x)
# SHALLOW WATER EQUATIONS
def velocity(U):
    #computes the velocity q/A, but prevents A getting negative
    A = ufl.max_value(U[0], 1e-6)
    return U[1]/A
def wave_speed(U):
    #calucaltes the wave speed, but once again prevents negative values
    A=ufl.max_value(U[0],1e-6)
    return ufl.sqrt(g*A/width)
def max_eigenvalue(U):
    #calculates the maximum eigenvalue for U
    return abs(velocity(U))+wave_speed(U)
def Fc(U):
    #The st venant equations, currently wihtout surface friction and gradients and for a square channel
    # so g*I_1= g*A*A/width
    q=U[1]
    #this is the d/ds term
    momentum=(q*q/A+0.5*g*A*A/width)
    #now we add pressure correction because of surface height gradient
    #IS THIS EVEN NEEDED? NO
    #x=ufl.SpatialCoordinate(domain)
    #p_cor=g*ufl.exp(-x[0])
    #momentum+=p_cor
    #return the results
    return ufl.as_vector([q,momentum])
def source(u):
    #THIS ADDS THE SOURCE THERMS, S_SLOPE, S_F AND THE INFLOW
    A=ufl.max_value(u[0],1e-6)
    q=u[1]
    #the resulting force caused by a terrain given by exp(-x)
    S_slope=ufl.as_vector([0,-g*A*(dz_ds(x[0]))])
    #gives the frictions from manningś law
    S_f=ufl.as_vector([0,g*n_manning**2*q*ufl.sqrt(q*q)/(A**(7/3))])
    #ADD RIVER INFLOW FROM THE SIDE
    return S_slope+S_f
# INFLOW STATE
def inflow_state(U):
    #this is the inflow on the left side, so only q_in is prescribed
    return ufl.as_vector([U[0],q_in])
# RUSANOV FLUX
n=ufl.FacetNormal(domain)
def rusanov_flux(Up, Um, normal):
    #compute the function at both sides
    Fp=Fc(Up)
    Fm=Fc(Um)
    #caluclate alpha
    alpha=ufl.max_value(max_eigenvalue(Up),max_eigenvalue(Um))
    #return the Rusanov flux
    return 0.5*((Fp+Fm)*normal[0]+alpha*(Up-Um))
# DG FORMULATION
# wehich is Fc*d/dx v integrated
volume_term=(ufl.inner(Fc(u_tmp),v.dx(0))*ufl.dx)
#the source term because of the friciton and slope, later also add inflow from the side!!!!!!
source_term=ufl.inner(source(u_tmp),v)*ufl.dx
#the interial numerical flux
interior_flux=(ufl.inner(rusanov_flux(u_tmp("+"),u_tmp("-"),n("+")),ufl.jump(v))*ufl.dS)
#caluclte the flux on the left boundary, where we have an inflow q, defined by the inflow_state
left_flux=(ufl.inner(rusanov_flux(u_tmp,inflow_state(u_tmp),n),v)*ds(1))
#on the right boundary the flow can flow out freely IS THIS CORRECT?????
right_flux=(ufl.inner(Fc(u_tmp)*n[0],v)*ds(2))
# Complete semidiscrete form
L_form=fem.form(volume_term+source_term-interior_flux-left_flux-right_flux)
# MASS MATRIX
#define the matrix a
a=ufl.inner(du,v)*ufl.dx
A_matrix=fem.petsc.assemble_matrix(fem.form(a))
A_matrix.assemble()
#define the solver
solver=PETSc.KSP().create(domain.comm)
solver.setOperators(A_matrix)
solver.setType("preonly")
solver.getPC().setType("lu")
# RHS VECTOR
b=fem.petsc.assemble_vector(L_form)
# RK STORAGE
#this just makes 5 functions just in case, this is kinda wacky, can just make less if not needed I guess
k1=fem.Function(V)
k2=fem.Function(V)
k3=fem.Function(V)
k4=fem.Function(V)
k5=fem.Function(V)
k_arr=[k1,k2,k3,k4,k5]
#this contains k for a certain stage
u_stage=fem.Function(V)
# RHS ASSEMBLY
def compute_rhs(Uin, kout):
    #set the values for the temprotray u that are used to compute this step
    u_tmp.x.array[:]=Uin.x.array[:]
    #update the vlaues
    u_tmp.x.scatter_forward()
    with b.localForm() as loc:
        loc.set(0)
    #assemble the vecot
    fem.petsc.assemble_vector(b,L_form)
    #update
    b.ghostUpdate(addv=PETSc.InsertMode.ADD,mode=PETSc.ScatterMode.REVERSE)
    #osolver
    solver.solve(b,kout.x.petsc_vec)
    kout.x.scatter_forward()
    #return kout so we return it again and put it back into the array
    return kout
# INITIAL PLOT
vals=u.x.array.reshape((-1,2))
A_vals=vals[:,0]
q_vals=vals[:,1]
plt.figure()
plt.title("Initial Area")
plt.plot(A_vals[::n_RK])
plt.figure()
plt.title("Initial Discharge")
plt.plot(q_vals[::n_RK])
# RK4 TIME STEPPING
#get the coefficients
a_runge,b_runge,c_runge=butcher(n_RK)
#set the initial time
t=t0
for step in range(n_t):
    #now we compute all the runge kutta steps
    #we first caluctelate ht einital stuff
    k_arr[0]=compute_rhs(u,k_arr[0])
    for i in range(1,n_RK):
        #this computes u_stage for the stage
        u_stage.x.array[:]=u.x.array
        for j in range(i):
            #now loop over the runge kutta coefficients
            u_stage.x.array[:]+=a_runge[i,j]*dt*k_arr[j].x.array[:]
        #nowe we hvae computed u stage, we can solve the equations
        k_arr[i]=compute_rhs(u_stage,k_arr[i])
    #now we got all the Kś and can thus update the solotion to the next tiem step
    #now update u_n
    for i in range(n_RK):
        u.x.array[:]+=dt*b_runge[i]*k_arr[i].x.array
    #TODO add protection against negative values
    u.x.scatter_forward()
    t+=dt
# FINAL PLOT
A_vals=vals[:,0]
q_vals=vals[:,1]
plt.figure()
plt.title("Final Area")
plt.figure()
plt.title("Final Discharge")
One of the few projects I know which has implemented slope limiters for DG methods with FEniCS is Ocellaris. See, e.g.,
thanks! I will have a look
I got it working now, but massively decreased the efficiency of the code. I will try to optimize it and once it works decently upload it here so people can use it as a reference in case they ever need it.
This is a TVD limited code that is relatively quick, but only works for p=1:
import time
import pyvista
#TODO SSPRK
def butcher(order):
    if order==2:
        b_runge=[1/2,1/2]
        c_runge=[0,1]
        a_runge[1,0]=1
    elif order==3:
        # Third-order RK3
        c_runge=[0,1/2,1]
        a_runge[1,0]=1/2
        a_runge[2,0]=-1
        a_runge[2,1]=2
    elif order==4:
        a_runge[1,0]=1/2
        a_runge[2,1]=1/2
        a_runge[3,2]=1
    elif order==5:
        a_runge[1,0]=1/4
        exit()
# PARAMETERS
x_l=0.0
x_r=10.0
n_grid=100
dx=(x_r-x_l)/n_grid
t0=0.0
t_end=3.0
dt=1e-4
g=9.81
width=1.0
#The DG order
p=1
#TODO CURRENT CODE ONLY WORKS CORRECTLY FOR P=1
if p!=1:
    print("THE TVD SLOPE LIMITER DOESNT WORK CORRECTLY FOR THIS YET")
    exit()
#inflow discharge
q_left=1.0
#initial areas
A_left=1.
A_right=1.
n_RK=p+1
#ARTIFICIAL VISCOSITY
artificial_viscosity=False
nu_visc=1e-3
# MESH
    MPI.COMM_WORLD,
    n_grid,
    [x_l,x_r])
#sort the indices
#place tags on them
    domain,
    fdim,
# FUNCTIONS
u=fem.Function(V)
# INITIAL CONDITION
L=x_r-x_l
    #now it just sets everything to one
    # area
    #values[1]=1.0
    return values
# INFLOW BC
A_in=fem.Constant(domain,PETSc.ScalarType(A_left))
n_manning=0.01
# def z(x):
#     #the height itself, needed for the pressure correction
#     return ufl.exp(-x)
def dz_ds(x):
    return -0.3*ufl.exp(-x)
def velocity(U):
    #computes the velocity q/A, but prevents A getting too small
    return U[1]/A
def wave_speed(U):
    #calucaltes the wave speed, but once again prevents too small values, needs to be made cleaner
def Fc(U):
    #square channel so g*I_1= g*A*A/width
    q=U[1]
    #return the results
def source(u):
    #TODO ADD INFLOW FROM THE SIDE
    q=u[1]
    S_f=ufl.as_vector([0,-g*n_manning**2*q*ufl.sqrt(q*q)/(A**(7/3))])
    return S_slope+S_f
# INFLOW STATE
# RUSANOV FLUX
    Fp=Fc(Up)
    Fm=Fc(Um)
    #caluclate alpha
# DG FORMULATION
#ADD ARTIVICIAL VISCOSITY
if artificial_viscosity:
    #the size of the cell
    h=ufl.CellDiameter(domain)
    #penalty parameter
    alpha=10.0
    #we only apply the viscosity to the q, so in the momentum equation
    q_trial=u_tmp[1]
    q_test=v[1]
    #compute the integral nu* d/dx q d/dx v
    visc_volume=(nu_visc*q_trial.dx(0)*q_test.dx(0)* ufl.dx)
    #TODO THIS IS STILL NOT FULLY RIGHT
    #compute the consistensy term, which is the sum over the integrals
    visc_consistency=(-nu_visc*ufl.avg(q_trial.dx(0))*ufl.jump(q_test)*ufl.dS
        -nu_visc*ufl.avg(q_test.dx(0))*ufl.jump(q_trial)*ufl.dS)
    #and introduce the penalty for the jumps
    jump_penalty=(nu_visc*alpha/ufl.avg(h)*ufl.jump(q_trial)*ufl.jump(q_test)*ufl.dS)
    #add them to the function
    volume_term-=visc_volume
    volume_term+=visc_consistency
    volume_term+=jump_penalty
# MASS MATRIX
A_matrix.assemble()
#define the solver
# RHS VECTOR
# RK STORAGE
k1=fem.Function(V)
k2=fem.Function(V)
k3=fem.Function(V)
k4=fem.Function(V)
k5=fem.Function(V)
#for plotting
V_plot=fem.functionspace(domain,("CG",1,(2,)))
u_plot=fem.Function(V_plot)
# RHS ASSEMBLY
    #update the vlaues
        loc.set(0)
    #assemble the vecot
    #update
    #osolver
    return kout
#DEFINE THE SLOPE LIMITER
#the amount of degrees of freedom per cell
nodfs_cell=(p+1)
#the number of cells
ncells=domain.topology.index_map(domain.topology.dim).size_local
def sigma_minmod(slope_left,slope_right):
    #eq 4.26
    sigma=(np.sign(slope_left)+np.sign(slope_right))/2*np.minimum(np.abs(slope_left),np.abs(slope_right))
    return sigma
#this is the array with x values, only needs to be created once, needed for equation 4.20
x_factor=np.linspace(-0.5,0.5,nodfs_cell)*dx
def slope_limiter(u):
    #applies slope limiter according to equation 4.26 to the problem
    #we generate two arrays, one with the area and one with the discharge
    #CURRENTLY ONLY WORKS FOR P=1
    arr=u.x.array
    #print(arr)
    A_arr=arr[::2].copy()
    q_arr=arr[1::2].copy()
    #print(A_arr)
    #SET TO ZERO WHENEVER SOMETHING IS TOO SMAL, we first order them per cell
    A_cell=A_arr.reshape(-1,nodfs_cell)
    q_cell=q_arr.reshape(-1,nodfs_cell)
    #apply a mask, this sets the discharge to zero whenever there is a area below the threshold of 1e-6
    mask=np.any(A_cell<1e-6,axis=1)
    q_cell[mask]=0.0
    #now we also set the water height to very low for these cases
    A_cell[mask]=1e-6
    #we now have two arrays, both for A and for q, we now compute the average for each cell
    #TODO THIS IS NOT GENRALLY TRUE
    A_avg=A_cell.mean(axis=1)
    q_avg=q_cell.reshape(-1,nodfs_cell).mean(axis=1)
    #now get the differences of the mean between the cells
    #TODO FLEXIBLE DX, but then it just needs to be an array so not that difficult
    dA=np.diff(A_avg)/dx
    dq=np.diff(q_avg)/dx
    #now get the values for sigma for both
    dAL=dA[:-1]
    dAR=dA[1:]
    dqL=dq[:-1]
    dqR=dq[1:]
    sigma_A=sigma_minmod(dAL,dAR)
    sigma_q=sigma_minmod(dqL,dqR)
    #calculate the TVD limited values
    A_lim=A_avg[1:-1,None]+sigma_A[:,None]*x_factor[None,:]
    q_lim=q_avg[1:-1,None]+sigma_q[:,None]*x_factor[None,:]
    #updated the values per cell
    A_cell[1:-1,:]=A_lim
    q_cell[1:-1,:]=q_lim
    #ENFORCE THE MASK AGAIN AFTER LIMITING
    q_cell[mask]=0.0
    A_cell[mask]=1e-6
    #now flatten them again
    arr[::2]=A_cell.flatten()
    arr[1::2]=q_cell.flatten()
    #now scatter forward
# INITIAL PLOT
vals=u.x.array.reshape((-1,2)).copy()
A_vals_init=vals[:,0]
q_vals_init=vals[:,1]
# RK4 TIME STEPPING
t=t0
        for j in range(i):
        #apply slope limiting
        slope_limiter(u_stage)
    #now update u_n
    #tvd_limiter(u)
    #and also slope limiting here
    slope_limiter(u)
    t+=dt
#     if step%1000==0 and step>5000:
#         #make a plot to see whats going wrong
#         u_plot.interpolate(u)
#         vals = u_plot.x.array.reshape((-1,2))
#         A_vals=vals[:,0]
#         q_vals=vals[:,1]
#         plt.figure()
#         plt.title("A nt="+str(step))
#         plt.plot(A_vals)
#         plt.figure()
#         plt.title("Dischargent="+str(step))
#         plt.plot(q_vals)
#         plt.figure()
#         plt.title("Final velocities"+str(step))
#         plt.plot(q_vals/A_vals)
# plt.show()
# FINAL PLOT
A_vals=vals[:,0]
q_vals=vals[:,1]
# plt.figure()
# plt.title("Initial Area")
# plt.plot(A_vals_init[::n_RK])
# plt.figure()
# plt.title("Initial Discharge")
# plt.plot(q_vals_init[::n_RK])
    print("CURRENT SIMULATIONS DONE WITH ARTIFICIAL VISCOSITY")
plt.figure()
plt.plot(A_vals)
plt.figure()
plt.plot(q_vals)
plt.figure()
plt.title("Final velocities")
print(len(u.x.array))
