Hello, everyone. Recently, I have been solving the compressible NS equations on the unit disk, with the model as follows:
where,
J =E + u \times B.
and
The numerical scheme is:
When solving this equation, the pressures p, electric fields E and magnetic fields B all involved were substituted using the exact solutions. If the functions ρ and u are discretized using the P1 element, the L^2 convergence order obtained in both cases is 2. Now my main goal is to test the calculation of higher-order elements in curved domain.
However, when I discretize using the P2 element, the L2 error convergence order of rho can only reach 2nd order, while the L2 error convergence order of u can reach 3rd order.
Here is my code:
from dolfinx.io import gmshio
from dolfinx import mesh, fem
from dolfinx.fem.petsc import assemble_matrix, assemble_vector, apply_lifting, create_vector, set_bc
from dolfinx.fem import Function
import time
from ufl import dx, grad, dot,inner, div,nabla_grad,curl,split, lhs, rhs
from basix.ufl import element,mixed_element
from numpy import sin, cos, pi, exp
# 精确解
mu = 1.0
muc = 2.0
Rm=1.0
gamma=5/3
kappa=1.0
def ExactRho(x, t): # 用恒正的 ρ 能解决问题——所有内部节点的 ρ 都远离零,矩阵条件数好
r2 = x[0]**2 + x[1]**2
return (exp(-t) + 1.0) * (1 - r2)
def ExactU(x,t):
factor = t * (1 - r2)
u1 = factor * sin(pi*x[0]) * cos(pi*x[1])
u2 = factor * cos(pi*x[0]) * sin(pi*x[1])
return [u1, u2]
def Exactp(x,t):
return (exp(-t) + 1.0) * (1 - r2) * sin(pi*x[0])
def ExactE(x,t):
fr = 1 - r2
return pi * fr**2 * sin(pi*x[0]) * sin(pi*x[1]) * sin(pi*t)
def ExactB(x, t):
xv, yv = x[0], x[1]
r2 = xv**2 + yv**2
fr = 1 - r2
phi_f = cos(pi*t) + 2.0
sinx = sin(pi*xv); siny = sin(pi*yv)
cosx = cos(pi*xv); cosy = cos(pi*yv)
B1 = fr * phi_f * sinx * (pi*fr*cosy - 4*yv*siny)
B2 = -fr * phi_f * siny * (pi*fr*cosx - 4*xv*sinx)
return [B1, B2]
def rhs_expr0(x, t):
xv, yv = x[0], x[1]
r2 = xv**2 + yv**2
fr = 1 - r2
sinx = sin(pi*xv); cosx = cos(pi*xv)
siny = sin(pi*yv); cosy = cos(pi*yv)
exp_t = exp(-t)
f1 = 1.0 + exp_t
h = (- 4*t*xv*f1*fr*sinx*cosy
- 4*t*yv*f1*fr*siny*cosx
+ 2*pi*t*f1*fr*fr*cosx*cosy
- fr*exp_t)
return h
def rhs_expr1(x, t):
xv, yv = x[0], x[1]
r2 = xv**2 + yv**2
fr = 1 - r2
sinx = sin(pi*xv)
cosx = cos(pi*xv)
siny = sin(pi*yv)
cosy = cos(pi*yv)
sint = sin(pi*t)
# ρ
rho = (exp(-t) + 1.0) * (1 - r2)
# u
u1 = t * fr * sinx * cosy
u2 = t * fr * cosx * siny
# ∂u/∂t
du1_dt = fr * sinx * cosy
du2_dt = fr * cosx * siny
# ∂u1/∂x, ∂u1/∂y
du1_dx = t * (-2*xv*sinx*cosy + fr*pi*cosx*cosy)
du1_dy = t * (-2*yv*sinx*cosy - fr*pi*sinx*siny)
# ∂u2/∂x, ∂u2/∂y
du2_dx = t * (-2*xv*cosx*siny - fr*pi*sinx*siny)
du2_dy = t * (-2*yv*cosx*siny + fr*pi*cosx*cosy)
# u·∇u
u_grad_u1 = u1*du1_dx + u2*du1_dy
u_grad_u2 = u1*du2_dx + u2*du2_dy
# Δu
# ∂²u1/∂x²
d2u1_dx2 = t * (-2*sinx*cosy - 4*xv*pi*cosx*cosy - fr*pi**2*sinx*cosy)
# ∂²u1/∂y²
d2u1_dy2 = t * (-2*sinx*cosy + 4*yv*pi*sinx*siny - fr*pi**2*sinx*cosy)
lap_u1 = d2u1_dx2 + d2u1_dy2
# ∂²u2/∂x²
d2u2_dx2 = t * (-2*cosx*siny + 4*xv*pi*sinx*siny - fr*pi**2*cosx*siny)
# ∂²u2/∂y²
d2u2_dy2 = t * (-2*cosx*siny - 4*yv*pi*cosx*cosy - fr*pi**2*cosx*siny)
lap_u2 = d2u2_dx2 + d2u2_dy2
# \nabla p
dp_dx = (exp(-t) + 1.0)* (pi*fr*cosx - 2*xv*sinx)
dp_dy = (exp(-t) + 1.0) * (-2*yv*sinx)
# E和B
E_val = pi * fr*fr * sinx * siny * sint
Px = pi*fr*cosx - 4*xv*sinx
Py = pi*fr*cosy - 4*yv*siny
B1 = fr * phi_f * sinx * Py
B2 = -fr * phi_f * siny * Px
# E×B = [-E*B2, E*B1]
E_cross_B1 = -E_val * B2
E_cross_B2 = E_val * B1
# u×B×B = [-(u×B)*B2, (u×B)*B1]
u_cross_B = u1*B2 - u2*B1
u_B_B1 = -u_cross_B * B2
u_B_B2 = u_cross_B * B1
# ∇(∇·u)
d_div_u_dx = t * (-2*sinx*cosy - 6*xv*pi*cosx*cosy + 2*yv*pi*sinx*siny - 2*fr*pi*pi*sinx*cosy)
d_div_u_dy = t * (2*xv*pi*sinx*siny - 2*cosx*siny - 6*yv*pi*cosx*cosy - 2*fr*pi*pi*cosx*siny)
# 组装 f = ρ*(∂u/∂t + u·∇u) + \nabla p-J\times B- Δu
f1 = rho*du1_dt + rho*u_grad_u1 + dp_dx - E_cross_B1-u_B_B1-(2*muc-mu)*d_div_u_dx- mu*lap_u1
f2 = rho*du2_dt + rho*u_grad_u2+ dp_dy - E_cross_B2-u_B_B2-(2*muc-mu)*d_div_u_dy- mu*lap_u2
return [f1, f2]
def cross_2d(a, b):
return a[0]*b[1] - a[1]*b[0]
def cross1(a, b):
return ufl.as_vector([-a*b[1], a*b[0]])
def cross1_rev(b, a):
return ufl.as_vector([a * b[1], -a * b[0]])
def clamped_boundary(x):
return np.isclose(np.sqrt(x[0]**2 + x[1]**2), 1)
# 固定终止时间
T = 1
# 结果记录
hs = []
errorsrho_L2 = []
errorsrho_H1 = []
errorsU_L2 = []
errorsU_H1 = []
start_time = time.time()
for i in range(3):
n = 2 ** (i + 2)
h = 1.0 / n
num_steps = 2 ** (3 * i + 6)
dt = T / num_steps
t = 0.0
# 生成网格
membrane = gmsh.model.occ.addDisk(0,0,0,1,1)
gmsh.model.occ.synchronize()
gdim = 2
gmsh.model.addPhysicalGroup(gdim, [membrane], 1)
gmsh.option.setNumber("Mesh.CharacteristicLengthMin", h)
gmsh.option.setNumber("Mesh.CharacteristicLengthMax", h)
gmsh.option.setNumber("Mesh.ElementOrder", 2)
domain, _, _ = gmshio.model_to_mesh(gmsh.model, MPI.COMM_WORLD, 0, gdim=gdim)
gmsh.finalize()
V = fem.functionspace(domain, ("Lagrange", 2)) # 线性 Lagrange 元
VE_element = element("Lagrange", domain.basix_cell(), 2)
VB_element = element("RT", domain.basix_cell(), 2)
VU_element = element("Lagrange", domain.basix_cell(), 2, shape=(2, ))
V_element = element("Lagrange", domain.basix_cell(), 2)
Vv = fem.functionspace(domain, VU_element)
VE = fem.functionspace(domain, VE_element)
VB = fem.functionspace(domain, VB_element)
VM = fem.functionspace(domain, mixed_element([VU_element, V_element])) # 混合有限元空间
V0 = VM.sub(0)
V1 = VM.sub(1)
Q, _ = V0.collapse() # u 平铺成了标量空间
S, _ = V1.collapse() # rho
## 从这里开始计算
u_n = fem.Function(Q)
u_n.interpolate(lambda x:ExactU(x,t))
p_n = fem.Function(V)
p_n.interpolate(lambda x: Exactp(x,t))
rho_n = fem.Function(S)
rho_n.interpolate(lambda x: ExactRho(x, t))
# 边界条件
rho_D = fem.Function(S)
rho_D.interpolate(lambda x: ExactRho(x, t))
u_D = fem.Function(Q)
u_D.interpolate(lambda x: ExactU(x, t))
B_n = fem.Function(VB)
B_n.interpolate(lambda x: ExactB(x, t))
E_n = fem.Function(VE)
# 右端函数定义
f_fun0 = fem.Function(S)
f_fun1 = fem.Function(Q)
f_fun0.interpolate(lambda x: rhs_expr0(x, t))
f_fun1.interpolate(lambda x: rhs_expr1(x, t))
# 施加 Dirichlet 边界条件(3D 边界)
tdim = domain.topology.dim
fdim = tdim - 1
# 施加 Dirichlet 边界条件
facets = mesh.locate_entities_boundary(
domain,
dim=(domain.topology.dim - 1),
marker=clamped_boundary)
boundary_dofs0 = fem.locate_dofs_topological((V0, Q), entity_dim=1, entities=facets)
boundary_dofs3 = fem.locate_dofs_topological((V1, S), entity_dim=1, entities=facets)
bc0 = fem.dirichletbc(value=u_D, dofs=boundary_dofs0, V=V0)
bc3 = fem.dirichletbc(value=rho_D, dofs=boundary_dofs3, V=V1)
bc=[bc0,bc3]
# 在时间循环前创建 wh_n 并设置初始条件
wh_n = Function(VM)
# 设置初始条件到 wh_n
u_init = fem.Function(Q)
u_init.interpolate(lambda x: ExactU(x, 0.0)) # t=0的初始条件
rho_init = fem.Function(S)
rho_init.interpolate(lambda x: ExactRho(x, 0.0))
wh_n.sub(0).interpolate(u_init)
wh_n.sub(1).interpolate(rho_init)
# u E B 的变分形式
wh = Function(VM)
u_h = fem.Function(Q)
rho_h = fem.Function(S)
u, rho = split(wh)
v, w = ufl.TestFunctions(VM)
F1 = rho * w * dx - rho_n * w * dx - dt * dot(rho * u, grad(w)) * dx - dt *f_fun0* w * dx \
+ rho_n* dot(u, v) *dx - rho_n* dot(u_n, v) *dx\
+ dt*(1/2)*inner(rho_n*grad(dot(u,u)),v)*dx - dt*inner(rho_n*cross1_rev(u,curl(u_n)), v)*dx \
+ dt* mu * inner(nabla_grad(u),nabla_grad(v))*dx + dt*(2*muc-mu)*inner(div(u),div(v))*dx- dt* inner(f_fun1,v)*dx\
- dt* dot(p_n, div(v))*dx - dt*inner(cross1(cross_2d(u,B_n),B_n), v) * dx-dt*inner(cross1(E_n, B_n), v) * dx
for n_step in range(num_steps):
E_n.interpolate(lambda x:ExactE(x, t))
wh.x.array[:] = wh_n.x.array[:]
problem = NonlinearProblem(F1, wh, bcs=bc)
solver.atol = 1e-10
solver.rtol = 1e-10
solver.max_it = 100
solver.krylov_options = {
"ksp_type": "preonly",
"pc_type": "lu",
n_iter, converged = solver.solve(wh)
u_h = wh.sub(0).collapse()
rho_h = wh.sub(1).collapse()
if not converged:
print(f" WARNING: N={n}, step={num_steps+1}, "
f"t={t:.4f}: not converged ({n_iter} iter)")
wh_n.x.array[:] = wh.x.array[:]
rho_n.x.array[:] = rho_h.x.array
u_n.x.array[:] = u_h.x.array
p_n.interpolate(lambda x:Exactp(x, t))
B_n.interpolate(lambda x:ExactB(x, t))
# 计算误差
V_ex = fem.functionspace(domain, ("Lagrange", 3))
rho_ex = fem.Function(V_ex)
rho_ex.interpolate(lambda x: ExactRho(x,T))
# E 的误差
E_ex = fem.Function(V_ex)
E_ex.interpolate(lambda x: ExactE(x,T))
p_ex = fem.Function(V_ex)
p_ex.interpolate(lambda x: Exactp(x,T))
Vv_ex = fem.functionspace(domain, ("Lagrange", 3, (2, )))
# u 的误差
u_ex = fem.Function(Vv_ex)
u_ex.interpolate(lambda x: ExactU(x,T))
# B 的误差
B_ex = fem.Function(Vv_ex)
B_ex.interpolate(lambda x: ExactB(x,T))
# L2 误差
errorrho_L2 = np.sqrt(domain.comm.allreduce(fem.assemble_scalar(fem.form((rho_h - rho_ex)**2 * ufl.dx)), op=MPI.SUM))
errorrho_H1 = np.sqrt(domain.comm.allreduce(fem.assemble_scalar(fem.form(dot(grad(rho_h - rho_ex),grad(rho_h - rho_ex)) * ufl.dx)), op=MPI.SUM))
errorU_L2 = np.sqrt(domain.comm.allreduce(fem.assemble_scalar(fem.form((u_h - u_ex)**2 * ufl.dx)), op=MPI.SUM))
errorU_H1 = np.sqrt(domain.comm.allreduce(fem.assemble_scalar(fem.form(inner(grad(u_h - u_ex),grad(u_h - u_ex)) * ufl.dx)), op=MPI.SUM))
if MPI.COMM_WORLD.rank == 0:
hs.append(h)
errorsrho_L2.append(errorrho_L2)
errorsrho_H1.append(errorrho_H1)
errorsU_L2.append(errorU_L2)
errorsU_H1.append(errorU_H1)
print(f"[i={i}] n={n}, num_steps={num_steps}, dt={dt:.3e}, h={h:.3e}")
print(f" → L2 errorrho = {errorrho_L2:.3e}, H1 errorrho = {errorrho_H1:.3e}")
print(f" → L2 errorU = {errorU_L2:.3e}, H1 errorU = {errorU_H1:.3e}") #
end_time = time.time() # 计时结束
elapsed = end_time - start_time
print("\nEstimated convergence rates (L2):")
for j in range(1, len(hs)):
e1 = np.log(errorsrho_L2[j-1]/errorsrho_L2[j]) / np.log(hs[j-1]/hs[j])
e2 = np.log(errorsrho_H1[j-1]/errorsrho_H1[j]) / np.log(hs[j-1]/hs[j])
r1 = np.log(errorsU_L2[j-1]/errorsU_L2[j]) / np.log(hs[j-1]/hs[j])
r2 = np.log(errorsU_H1[j-1]/errorsU_H1[j]) / np.log(hs[j-1]/hs[j])
print(f"h={hs[j-1]:.3e} → h={hs[j]:.3e}, rate_rho_L2 ≈ {e1:.2f},rate_rho_H1 ≈ {e2:.2f}")
print(f"h={hs[j-1]:.3e} → h={hs[j]:.3e}, rate_u_L2 ≈ {r1:.2f},rate_u_H1 ≈ {r2:.2f}")
print(f"\nTotal runtime: {elapsed:.2f} seconds")
Why does the error convergence order of ρ only reach 2nd order, and not 3rd order? Looking forward to your reply!
