mesh = UnitSquareMesh(32, 32)
# Define Dirichlet boundary (x = 0 or x = 1)
def boundary(x):
return x[0] < DOLFIN_EPS or x[0] > 1.0 - DOLFIN_EPS
# Define boundary condition
u0 = Constant(0.0)
bc = DirichletBC(V, u0, boundary)
f = Expression("10*exp(-(pow(x[0] - 0.5, 2) + pow(x[1] - 0.5, 2)) / 0.02)")
g = Expression("sin(5*x[0])")
a = inner(grad(u), grad(v))*dx
L = f*v*dx + g*v*ds
# Compute solution
solve(a == L, u, bc)
error:
File "/home/ayush/poisson.py", line 1, in <module>
File "/usr/lib/petsc/lib/python3/dist-packages/dolfin/__init__.py", line 138, in <module>
from . import parameter
File "/usr/lib/petsc/lib/python3/dist-packages/dolfin/parameter/__init__.py", line 11, in <module>
from ffc import default_jit_parameters
File "/home/ayush/.local/lib/python3.10/site-packages/ffc/__init__.py", line 24, in <module>
from ffc.compiler import compile_form, compile_element
File "/home/ayush/.local/lib/python3.10/site-packages/ffc/compiler.py", line 129, in <module>
from ffc.codegeneration import generate_code
File "/home/ayush/.local/lib/python3.10/site-packages/ffc/codegeneration.py", line 37, in <module>
import ffc.uflacs.language.cnodes as L
File "/home/ayush/.local/lib/python3.10/site-packages/ffc/uflacs/__init__.py", line 23, in <module>
from ffc.uflacs.uflacsrepresentation import compute_integral_ir
File "/home/ayush/.local/lib/python3.10/site-packages/ffc/uflacs/uflacsrepresentation.py", line 26, in <module>
from ffc.representationutils import initialize_integral_ir
File "/home/ayush/.local/lib/python3.10/site-packages/ffc/representationutils.py", line 28, in <module>
from ufl.cell import cellname2facetname
ImportError: cannot import name 'cellname2facetname' from 'ufl.cell' (/usr/lib/python3/dist-packages/ufl/cell.py)
ayush@ayush-Precision-5820-Tower:~$ python3 poisson.py
ModuleNotFoundError: No module named 'fenics'
You have not stated what commands you have executed to remove the offending module, or how you installed dolfin in the first place. Please consider that you need to add the context of your error messages to your post, not just post the error message.
ayush@ayush-Precision-5820-Tower:~$ fenics-version
2019.2.0.dev0
ayush@ayush-Precision-5820-Tower:~$ dolfin-
dolfin-convert dolfin-get-demos dolfin-order dolfin-plot dolfin-version
ayush@ayush-Precision-5820-Tower:~$ ufl
Command 'ufl' not found, did you mean:
command 'ufw' from snap ufw (0.36.2)
command 'ofl' from deb hxtools (20211204-1)
command 'uil' from deb uil (2.3.8-3)
command 'ul' from deb bsdextrautils (2.38-4ubuntu1)
command 'ufw' from deb ufw (0.36.1-4build1)
See 'snap info <snapname>' for additional versions.
Python 3.10.7 (main, Mar 10 2023, 10:47:39) [GCC 12.2.0] on linux
Type "help", "copyright", "credits" or "license" for more information.
[10]+ Stopped python3
hwloc/linux: Ignoring PCI device with non-16bit domain.
Pass --enable-32bits-pci-domain to configure to support such devices
(warning: it would break the library ABI, don't enable unless really needed).
File "/usr/lib/python3/dist-packages/fenics/__init__.py", line 7, in <module>
File "/usr/lib/petsc/lib/python3/dist-packages/dolfin/__init__.py", line 144, in <module>
from .fem.assembling import (assemble, assemble_system, assemble_multimesh, assemble_mixed,
File "/usr/lib/petsc/lib/python3/dist-packages/dolfin/fem/assembling.py", line 38, in <module>
from ufl.form import sub_forms_by_domain
ImportError: cannot import name 'sub_forms_by_domain' from 'ufl.form' (/home/ayush/.local/lib/python3.10/site-packages/ufl/form.py)
i also try in the same way given in the above post but it is not resolve. tell me the steps how I can uninstall everything and install fenics again
May be that information provide some idea to you in order to help me
