Try to convert msh into xdmf
def export_domain(msh, dim, directory, prefix):
    Export the domain XDMF file as well as the subdomains values.
    # Set cell type
    if dim == 2:
        cell_type = "triangle"
    elif dim == 3:
        cell_type = "tetra"
    # Generate the cell block for the domain cells
    data_array = [arr for (t, arr) in msh.cells if t == cell_type]
    if len(data_array) == 0:
        print("WARNING: No domain physical group found.")
        return
        data = np.concatenate(data_array)
    cells = [
        meshio.CellBlock(
            type=cell_type,
            data=data,
error:
raceback (most recent call last):
  File "/home/ayush/msh2xdmf.py", line 257, in <module>
    msh2xdmf(args.msh_file, args.dimension, directory=current_directory)
  File "/home/ayush/msh2xdmf.py", line 28, in msh2xdmf
  File "/home/ayush/msh2xdmf.py", line 45, in export_domain
  File "/home/ayush/msh2xdmf.py", line 45, in <listcomp>
TypeError: cannot unpack non-iterable CellBlock object
Without a msh file its hard to reproduce your problem.
Also, consider the create_mesh function at Mesh generation and conversion with GMSH and PYGMSH | Jørgen S. Dokken
