I see, yes.
I tried 2 approaches, still unable to get it working.
First approach is by implementing the function curl_2d(), as a copy-paste of the example you provide.
Jecurl_flux_calculator = Expression(curl_2d(J_vector), Jcurl.element.interpolation_points())
but I get the same kind of errors:
File "/root/shared/debug_discourse/curl_MWE.py", line 188, in <module>
Jecurl.interpolate(Jecurl_flux_calculator)
File "/usr/local/dolfinx-real/lib/python3.10/dist-packages/dolfinx/fem/function.py", line 397, in interpolate
_interpolate(u, cells)
File "/usr/lib/python3.10/functools.py", line 889, in wrapper
File "/usr/local/dolfinx-real/lib/python3.10/dist-packages/dolfinx/fem/function.py", line 388, in _
self._cpp_object.interpolate(expr._cpp_object, cells)
RuntimeError: Function value size not equal to Expression value size
The 2nd approach is to use Nate’s code:
Jecurl_flux_calculator = Expression(as_vector((J_vector[1].dx(0)-J_vector[0].dx(1))), Jcurl.element.interpolation_points() )
yielding a different error:
File "/root/shared/debug_discourse/curl_MWE.py", line 186, in <module>
File "/usr/local/lib/python3.10/dist-packages/ufl/tensors.py", line 312, in as_vector
raise ValueError("Expecting rank 1 tensor.")
ValueError: Expecting rank 1 tensor.
