2D and 1D linear elasticity problem result don't match
I am trying to modify the “2D linear elasticity” problem linked:
https://comet-fenics.readthedocs.io/en/latest/demo/elasticity/2D_elasticity.py.html
to make it “1D linear elasticity” problem.
When I compare the 1D displacement extracted from the 2D problem with the displacement obtained directly from 1D problem, there is difference in shape and magnitude.
Guidance in this regard is required.
Below is python script.
Blockquote
L = 25.0
H = 1.0
Nx = 250
Ny = 10
E = Constant(1e5)
nu = Constant(0.3)
mesh = RectangleMesh(Point(0.0, 0.0), Point(L, H), Nx, Ny, “crossed”)
def eps(v):
return sym(grad(v))
model = “plane_stress”
mu = E/2/(1 + nu)
lmbda = Enu/(1 + nu)/(1 - 2nu)
if model == “plane_stress”:
lmbda = 2mulmbda/(lmbda + 2*mu)
def sigma(v):
return lmbdatr(eps(v))Identity(2) + 2.0mueps(v)
rho_g = 1e-3
f = Constant((0.0, -rho_g))
V = VectorFunctionSpace(mesh, ‘Lagrange’, degree=2)
du = TrialFunction(V)
u_ = TestFunction(V)
a = inner(sigma(du), eps(u_))*dx
l = inner(f, u_)*dx
def left(x, on_boundary):
return near(x[0], 0.0)
bc = DirichletBC(V, Constant((0.0, 0.0)), left)
u = Function(V, name =“Displacement”)
solve(a == l, u, bc)
plot(u, mode=“displacement”)
plt.grid(color = ‘k’, linestyle = ‘-’, linewidth = 0.1)
plt.title(“2D Displacemnt”)
plt.xlabel(‘x’)
plt.ylabel(‘Displacement’)
extraction of 1D value from 2D
y_position = H/2
x_min = 0
x_max = L
N_steps = 1000
delta_x = (x_max - x_min)/float(N_steps)
u_vector = np.zeros(N_steps,float)
for i in range(N_steps):
x_position = float(i * delta_x)
u_vector[i] = u(x_position, y_position)[1]
x_values = [i * delta_x for i in range(N_steps)]
plt.xlabel(‘x’)
plt.plot(x_values, u_vector)
plt.title(“1D Displacemnt”)
print(“Maximal deflection:”, -u(L, H/2.0)[1])
print(“Beam theory deflection:”, float(3rho_gL4/2/E/H3))
L = 25.0
H = 1.0
Nx = 250
Ny = 10
E = Constant(1e5)
nu = Constant(0.3)
mesh = IntervalMesh(Nx, 0.0, L)
def eps(v):
return sym(grad(v))
mu = E / (2*(1 + nu))
lmbda = (Enu) / ((1 + nu)(1 - 2*nu))
def sigma(v):
return lmbdatr(eps(v))Identity(1) + 2.0mueps(v)
rho_g = 1e-3
f = Constant((-rho_g,))
l = inner(f, u_)*dx
bc = DirichletBC(V, Constant((0.0,)), left)
z = np.linspace(0, 25, 100)
u_line = np.array([u(point) for point in z])
plt.plot(z, u_line)
plt.grid(color=‘r’, linestyle=‘-’, linewidth=0.1)
plt.legend([‘Displacement’], markerfirst = False, loc=‘best’)
print(“Maximal deflection:”, -u(L/2))
your 1D problem is by no means a correct implementation of a 1D beam model. Your comparison makes no sense.
Best
Dear Sir,
Thank you very much for the reply. Actually, I am not from mechanics background. Can you please suggest a source from where I can understand the conversion of 2D beam model to the 1D model.
Thank you.
Hi there,
Did you manage to find an answer to this?
No. I have not found the answer to this yet.
