2D Elasticity code in fenicsx does not match the code from fenics
It would be great to have some advice on this code which confirms numerically the theoretical maximum deflection.
I’m trying to write the code in fenicsx, but the result does not confirm the theoretical deflections as the the preivous fenics code.
Here is my version of the code in fenicsx
from dolfinx import mesh
import numpy
# Domain
d_x0 = 25.0  #  size along x0, m
d_x1 = 1.0  #  size along x1, m
n_x0 = 250
n_x1 = 10
domain = mesh.create_rectangle(
    MPI.COMM_WORLD,
    [[0, 0], [d_x0, d_x1]],
    [n_x0, n_x1])
from dolfinx import fem
# Parameters
# Density
rho = 1.0e-3 #fem.Constant(domain, 1.0)
# Young's modulus and Poisson's ratio
E = 1.0e5
nu = 0.3
# Lame's constants
mu = E/(2*(1.0+nu))
lambda_ = E*nu/((1.0+nu)*(1.0-2.0*nu))
model = "plane_stress"
if model == "plane_stress":
    lambda_ = 2.0*mu*lambda_/(lambda_+2.0*mu)
from dolfinx.fem import FunctionSpace
#V = fem.VectorFunctionSpace(domain, ("Lagrange", 2))
element = ufl.VectorElement("Lagrange", domain.ufl_cell(), 2)
V = FunctionSpace(domain, element)
u = ufl.TrialFunction(V)
# Boundary Functions
tdim = domain.topology.dim
fdim = tdim - 1
def bottom(x):
    return np.isclose(x[1], 0)
def top(x):
    return np.isclose(x[1], 1)
def left(x):
    return np.isclose(x[0], 0)
def right(x):
    return np.isclose(x[0], 25)
bottom_facets = mesh.locate_entities_boundary(domain, fdim, bottom)
bottom_values = np.full_like(bottom_facets, 1)
top_facets = mesh.locate_entities_boundary(domain, fdim, top)
top_values = np.full_like(top_facets, 2)
left_values = np.full_like(left_facets, 3)
right_values = np.full_like(right_facets, 4)
facets = np.hstack([bottom_facets,top_facets, left_facets, right_facets])
values = np.hstack([bottom_values,top_values, left_values, right_values])
sort_order = np.argsort(facets)
facet_tags = dolfinx.mesh.meshtags(domain, fdim, facets[sort_order], values[sort_order])
ds = ufl.Measure("ds", domain=domain, subdomain_data=facet_tags)
dx = ufl.Measure("dx", domain=domain)
u_bc = fem.Function(V)
u_bc.interpolate(lambda x: ([x[0]*0,x[1]*0]))
#u_bc=fem.Constant(domain,(0.0, 0.0))
bcl = fem.dirichletbc(u_bc, left_facets)
bcr = fem.dirichletbc(u_bc, right_facets)
# Load
g_z = 0.0
b_z = -1.0
g  = fem.Constant(domain,(0,g_z))
b  = fem.Constant(domain,(0,b_z))
# Forms
    return ufl.sym(ufl.grad(u))  # Equivalent to 0.5*(ufl.nabla_grad(u) + ufl.nabla_grad(u).T)
def sigma(u):
    #return lambda_ * ufl.tr(epsilon(u)) * ufl.Identity(2) + 2 * mu * epsilon(u)
    return lambda_ * ufl.nabla_div(u) * ufl.Identity(2) + 2.0 * mu * epsilon(u)
L = rho*ufl.dot(b, v)*ufl.dx + ufl.dot(g, v)*ds((2))
uh = dolfinx.fem.Function(V)
problem = LinearProblem(a, L, bcs=[bcl], petsc_options={"ksp_type": "preonly", "pc_type": "lu"})
uh = problem.solve()
print("Max vertical deflection",np.max(-uh.sub(1).x.array))
print("Theoretical vertical deflection",3*(rho)*d_x0**4/2/E/d_x1**3)
