I try to run the code below (2D steady state heat equation) with 2 Neumann conditions on left and right respectively and 2 dirichlet on top and bottom respectively. I followed a previous post explaining how to implement multiple Neumann Boundaries (dirichlet boundary conditions are relatively easy to do).
However the code below does not work properly: I succeed to apply the Neumann condition on Left but not on right.
Any idea to find the error ?
Also if I want to apply a different flux on each of the two Neumann Boudaries, is my code correctly made ?
Thanks
#Plate with Boundary Conditions (BC): psi (Flux) on left & right sides, theta_0 (temperature) on top & Bottom sides
#C1 Load modules
from future import print_function
kappa = 1 #non dimensional diffusivity
psi = 10 #non dimensional flux
theta_0 = 10. # Celcius, temperature
tol = 1E-14
#C3 Geometry of the problem
X=1
Y=1
#C4 Mesh
nx2=20
ny2=20
mesh2 = RectangleMesh(Point(0.0, 0.0), Point(X, Y), nx2, ny2, diagonal=“left”)
plt.figure(1)
plot(mesh2, title=“Mesh of Plate”)
#C5 Space definition to search the solution
Hh2 = FunctionSpace(mesh2, ‘P’, 1)
#C6 Boundary Conditions
#C6.1 Top side BC: Dirichlet BC → Temperature imposed
def Top(x, on_boundary):
return on_boundary and (abs(x[1] - 1) < tol)
reD2 = DirichletBC(Hh2, Constant(theta_0), Top)
#C6.1bis Bottom side BC: Dirichlet BC → Temperature imposed
def Bot(x, on_boundary):
return on_boundary and (abs(x[1] - 0) < tol)
reD4 = DirichletBC(Hh2, Constant(theta_0), Bot)
bc = [ reD2, reD4 ]
# Neumann BC on left, right and bottom sides → Flux imposed
# Create classes for defining parts of the boundaries
class Left(SubDomain):
return on_boundary and (abs(x[0] - 0) < tol)
class Right(SubDomain):
return on_boundary and (abs(x[0] - 1) < tol)
# Initialize sub-domain instances
leN2 = Left()
RiN2 = Right()
boundaries2 = MeshFunction(“size_t”, mesh2, mesh2.topology().dim()-1, 0 )
boundaries2.set_all(0)
leN2.mark(boundaries2, 1)
RiN2.mark(boundaries2, 2)
# Define new measures associated with the exterior boundaries
ds2 = Measure(“ds”, domain=mesh2, subdomain_data=boundaries2)
#Fin C6.2 Left side: Neumann BC → Flux imposed
C7 Variationnal Formulation
u2 = TrialFunction(Hh2)
v2 = TestFunction(Hh2)
l2 = psiv2ds2(1)
a2 = kappa*inner(grad(u2), grad(v2))*dx
C8 Find the solution (SOLVER)
u2 = Function(Hh2)
solve(a2 == l2, u2, bc)
C8 Plot the solution
plt.figure(2)
plu=plot(u2)
plt.title(‘Numerical Solution u2’)
plt.xlabel(‘x’)
plt.ylabel(‘y’)
plt.colorbar(plu)
