2D heat-transfer (conduction/Laplacian/Poisson) in spherical annulus, axisymmetric spherical coordinates
Dear Community
This is not a query or plea for help. I am new to FEniCS and have been working for the past two weeks to understand how conduction in a spherical annulus may be modeled using 2D spherical axisymmetric coordinates. I have been fortunate to receive prompt assistance from other community members on the questions I had posed.
Since there appears to be a lot of material on dealing with axisymmetric cylindrical coordinates, but not the spherical case, I thought I would share with you the mathematical formulation, and the FEniCS script which solves the variational problem for this case.
1. Governing equation and variational formulation
\nabla^2 u=0;\,u(r=1,\theta)=1.0,\,u(r=R,\theta)=0.0
with
\nabla^2 u = \dfrac{1}{r^2}\dfrac{\partial}{\partial r}\left(r^2\dfrac{\partial u}{\partial r}\right)+\dfrac{1}{r^2\sin\theta}\dfrac{\partial}{\partial \theta}\left(\sin\theta\dfrac{\partial u}{\partial \theta}\right)
The variational problem is written as
\langle\nabla^2u,v\rangle_{\Omega}=\int_{r=1}^{r=R}\int_{\theta=0}^{\theta=2\pi}\left[\dfrac{1}{r^2}\dfrac{\partial}{\partial r}\left(r^2\dfrac{\partial u}{\partial r}\right)+\dfrac{1}{r^2\sin\theta}\dfrac{\partial}{\partial \theta}\left(\sin\theta\dfrac{\partial u}{\partial \theta}\right)\right]v(rdrd\theta)=0
Assuming that the trial and test functions (u and v, respectively) may be written in the
variable-separable form
u(r,\theta)=X(r)Y(\theta); \quad v(r,\theta)=A(r)B(\theta),
it may be shown that
\int_{r}\int_{\theta}\left[\dfrac{1}{r^2}\dfrac{\partial}{\partial r}\left(r^2\dfrac{\partial u}{\partial r}\right)\right]vrdrd\theta=\left[\int_{\theta}B(\theta)Y(\theta)d\theta\right]\times\left[\int_{r}\dfrac{A(r)}{r}\left(r^2\dfrac{d X}{d r}\right)dr\right]
=\left[\int_{\theta}B(\theta)Y(\theta)d\theta\right]\times\left[\cancel{A(r)r\dfrac{dX}{dr}\Biggr|_{r=1}^{r=R}}-\int_{r}\left(r\dfrac{dA}{dr}-A\right)\dfrac{dX}{dr}dr\right]
=-\int_{r}\int_{\theta}\left[r\dfrac{dA}{dr}B(\theta)\dfrac{dX}{dr}Y(\theta)-A(r)B(\theta)\dfrac{dX}{dr}Y(\theta)\right]drd\theta
resulting in
\int_{r}\int_{\theta}\left[\dfrac{1}{r^2}\dfrac{\partial}{\partial r}\left(r^2\dfrac{\partial u}{\partial r}\right)\right]vrdrd\theta=-\int_{r}\int_{\theta}r\left(\dfrac{\partial u}{\partial r}\right)\left(\dfrac{\partial v}{\partial r}-v\right)drd\theta
Similarly, we may derive
\int_{r}\int_{\theta}\left[\dfrac{1}{r^2\sin\theta}\dfrac{\partial}{\partial \theta}\left(\sin\theta\dfrac{\partial u}{\partial \theta}\right)\right]vrdrd\theta=-\int_{r}\int_{\theta}\dfrac{1}{r}\left[\dfrac{\partial v}{\partial \theta}\dfrac{\partial u}{\partial \theta}-v\dfrac{\partial u}{\partial \theta}\cot\theta\right]drd\theta
The variational problem in polar coordinates is therefore
\langle\nabla^2u,v\rangle_{\Omega}=\int_{r}\int_{\theta}\left\{\dfrac{1}{r^2}\left[\dfrac{\partial v}{\partial \theta}\dfrac{\partial u}{\partial \theta}-v\dfrac{\partial u}{\partial \theta}\cot\theta\right]+\left[\dfrac{\partial v}{\partial r}\dfrac{\partial u}{\partial r}-\dfrac{v}{r}\dfrac{\partial u}{\partial r}\right]\right\}rdrd\theta=0
It is useful to cast the above equation in Cartesian form prior to its solution in FEniCS.
Recognizing that
x=r\cos\theta;\quad y=r\sin\theta;\quad r=\left(x^2+y^2\right)^{1/2};\quad \cot\theta=\left(\dfrac{x}{y}\right);\quad \theta=\tan^{-1}\left(\dfrac{y}{x}\right)
and
\dfrac{\partial x}{\partial r}=\cos\theta=\left(\dfrac{x}{r}\right);\quad\dfrac{\partial y}{\partial r}=\sin\theta=\left(\dfrac{y}{r}\right)
\dfrac{\partial x}{\partial \theta}=-r\sin\theta=-y;\quad\dfrac{\partial y}{\partial \theta}=r\cos\theta=x
we may write
\dfrac{\partial u}{\partial r}=\left(\dfrac{\partial u}{\partial x}\right)\left(\dfrac{\partial x}{\partial r}\right)+\left(\dfrac{\partial u}{\partial y}\right)\left(\dfrac{\partial y}{\partial r}\right)=\dfrac{1}{r}\left[x\dfrac{\partial u}{\partial x}+y\dfrac{\partial u}{\partial y}\right]
\dfrac{\partial u}{\partial \theta}=\left(\dfrac{\partial u}{\partial x}\right)\left(\dfrac{\partial x}{\partial \theta}\right)+\left(\dfrac{\partial u}{\partial y}\right)\left(\dfrac{\partial y}{\partial \theta}\right)=x\dfrac{\partial u}{\partial y}-y\dfrac{\partial u}{\partial x}
Noting that the differential area element in Cartesian and polar coordinates are related as dxdy=rdrd\theta, the variational problem in Cartesian coordinates may be written as
\langle\nabla^2u,v\rangle_{\Omega}=\int_{x}\int_{y}\left[\left(\dfrac{\partial u}{\partial x}\right)\left(\dfrac{\partial v}{\partial x}\right)+\left(\dfrac{\partial u}{\partial y}\right)\left(\dfrac{\partial v}{\partial y}\right)-\dfrac{v}{r\sin\theta}\left(\dfrac{\partial u}{\partial y}\right)\right]dxdy=0
2. FEniCS script
The FEniCS script that sets up and solves the above problem is given next.
import math
Re = 5.
Ri = 1.
domain = Circle(Point(0., 0.), Re, 100) - Circle(Point(0., 0.), Ri, 100)
mesh = generate_mesh(domain, 40)
V = FunctionSpace(mesh, "CG", 2)
x = SpatialCoordinate(mesh)
# Define boundary subdomains
TOL = 1e-1
u_inner = Constant(1.0)
def inside(x, on_boundary):
    return near(x[0]**2 + x[1]**2, Ri**2, TOL) and on_boundary
u_outer = Constant(0.0)
def outside(x, on_boundary):
    return near(x[0]**2 + x[1]**2, Re**2, TOL) and on_boundary
inner_circ = DirichletBC(V,u_inner,inside)
outer_circ = DirichletBC(V,u_outer,outside)
bcs = [inner_circ, outer_circ]
# Defining polar coordinates
r = Expression("sqrt(x[0]*x[0]+x[1]*x[1])", degree=2)
theta = Expression("atan2(x[1],x[0])", degree=2)
# Variational formulation
a1 = (u.dx(0)*v.dx(0))+(u.dx(1)*v.dx(1))
a2 = (Constant(1.0)/(r*sin(theta)))*v*(u.dx(1))
a = (a1-a2)*dx
f = Constant(0.0)
L = f*v*dx
# Compute solution
solve(a == L, u, bcs)
# writing output to file
ufile = File("sol_2d_annulus_cartesian.pvd")
ufile << u
Comments and suggestions for improvement are welcome. The numerical solution may be compared against the analytical solution for the problem, which is given by
u(r)=-\left(\dfrac{R}{R-1}\right)\left[\dfrac{1}{R}-\dfrac{1}{r}\right]
Thank You
Warm Regards
Thank you very much for your contribution!
I think I may have found a little mistake in the procedure. Check this line:
2021-10-03_17h41_13
r should be inside the parenthesis (\frac{\partial v}{\partial r} - v) according to the preceding development:
Let me know if this is the case.
Regards,
Santiago
Thank you, Santiago, yes I realize now that there is a typo in that step. But I believe the rest of the development and the final variational formulation is correct because I have been able to check against the analytical solution.
@rkailash,
I’m glad to know, it’s a good example to start with. I’m sure it will be useful to me.
Regards,
Santiago
I know this is a bit late, but I decided to modernize the script for users of the latter Fenicsx version. Additionally, since it looks to be that the more conventional meshing package is gmsh for Python, I created the annulus using that package instead since I assumed it would be a bit more streamlined for other users here. I used the tutorial here for creating complex geometries in gmsh to help guide me along since I’m not too keen on creating meshes outside of how it’s done using the simpler dolfinx implementations for generating simple meshes.
import dolfinx as df
import math
import pyvista as pv
Re = 5.
Ri = 1.
gmsh.model.add("DFG 2D") #Name the model
xc, yc, zc, r_out = 0, 0, 0, 5 # Define input parameters
channel = gmsh.model.occ.add_disk(xc,yc,zc,Re,Re) #Full circle
xc, yc, zc, r_in = 0, 0, 0, 2 # Define input for inner portion of circle to remove
circle = gmsh.model.occ.add_disk(xc,yc,zc,Ri,Ri) #Chunk of circle that we plan to cut out
# Remove inner circle
fluid = gmsh.model.occ.cut([(2, channel)], [(2, circle)]) #Cut out circle from the channel
gmsh.model.occ.synchronize() #Synchronize the model after the cutting operation
# Tagging physical entities
areas = gmsh.model.getEntities(dim=2)
fluid_marker = 11 # What do you want the fluid marker to be named?
gmsh.model.addPhysicalGroup(areas[0][0], [areas[0][1]], fluid_marker) # Create the physical group
gmsh.model.setPhysicalName(areas[0][0], fluid_marker, "Fluid volume")
# Refine mesh
res = (r_out-r_in)/10
gmsh.option.setNumber("Mesh.CharacteristicLengthMin", res)
gmsh.option.setNumber("Mesh.CharacteristicLengthMax", res)
# Generate mesh
gmsh.model.mesh.generate(2)
# Create dolfinx mesh
model_rank = 0
mesh, cell_tags, facet_tags = df.io.gmshio.model_to_mesh(gmsh.model, MPI.COMM_WORLD, model_rank)
Mesh will look like the image above. You will notice the immediate line of code below uses a 1st degree functionspace instead of a 2nd order one, I did this arbitrarily. Feel free to change it to 2nd order, everything should still run.
# Create functionspace
V = df.fem.functionspace(mesh, ("CG", 1))
TOL = .0001
# Create facet to cell connectivity required to determine boundary facets
tdim = mesh.topology.dim # Dimension of entities one is mapping from
fdim = mesh.topology.dim-1 # Dimension of entities one is mapping to
u_inner = df.default_scalar_type(1.0)
def inside(x):
    truth_arr = np.isclose(x[0]**2 + x[1]**2, Ri**2, TOL)
    return truth_arr
inside_dofs = df.fem.locate_dofs_geometrical(V,inside)
u_outer = df.default_scalar_type(0.0)
def outside(x):
    truth_arr = np.isclose(x[0]**2 + x[1]**2, Re**2, TOL)
    return truth_arr
outside_dofs = df.fem.locate_dofs_geometrical(V,outside)
bc_inner_circ = df.fem.dirichletbc(u_inner,inside_dofs,V)
bc_outer_circ = df.fem.dirichletbc(u_outer,outside_dofs,V)
x = ufl.SpatialCoordinate(mesh) # All Cartesian Coordinates packed into one variable
r = ufl.sqrt(x[0]**2 + x[1]**2) # Radial conversion
theta = ufl.atan2(x[1],x[0]) # Angular conversion
u = ufl.TrialFunction(V)
s = ufl.TestFunction(V)
f = df.fem.Constant(mesh, df.default_scalar_type(0))
a1 = (u.dx(0)*s.dx(0))+(u.dx(1)*s.dx(1))
a2 = s/(r*ufl.sin(theta)) * u.dx(1)
a = (a1-a2)*ufl.dx
L = f*s*ufl.dx
# Solve
problem = LinearProblem(a=a,L=L,bcs = [bc_inner_circ,bc_outer_circ])
uh = problem.solve()
# Exact solution for comparison
uex = df.fem.Function(V)
uex.interpolate(lambda x: -(Re/(Re-1))*(1/Re-1/(x[1]**2+x[0]**2)**(1/2)))
# Error
error_form = df.fem.form(ufl.inner(uh-uex, uh-uex) * ufl.dx)
error_local = df.fem.assemble_scalar(error_form)
errorL2 = np.sqrt(mesh.comm.allreduce(error_local, op=MPI.SUM))
print("errorL2: " errorL2)
> errorL2: np.float64(0.06631065894092619)
Above is the approximation of the solution, and below is the exact solution:
From my computation, the approximation wasn’t the best based on the error, but could probably be refined and improved with more mesh refinements or picking different solvers. Hope this helps someone in the future!
Dear FeniCSX users,
Dear @fea, thank you for your contribution! I just found a typo in this line:
It should read:
xc, yc, zc, r_in = 0, 0, 0, 1 # Define input for inner portion of circle to remove
And the error is errorL2: 0.015219730593285156.
Best regards,
Mamadou
