2D Kelvin-Helmholtz instability - velocity diverges
Hi! I’m trying to learn FEniCS and I thought I’d try applying it to the initial conditions from this arxiv article I found on simulating the 2D Kelvin-Helmholtz instability.
I’ve managed to collect a bunch of ad hoc solutions to various problems I’ve run into while setting this up, and I think I’ve got something now. I’m mostly adapting the example of the FEniCS tutorial’s Navier-Stokes solver. Here’s my code:
from sympy import *
x, y = symbols('x[0] x[1]')
U, C, delta = symbols('U_oo c_n delta')
phi = U * exp(-(y-0.5)**2/delta**2) * (cos(8*pi*x) + cos(20 * pi * x))
ux = U * tanh((2 * y - 1)/delta) + C * phi.diff(y)
uy = - C * phi.diff(x)
ux_expression = ccode(ux).replace("M_PI", "pi")
uy_expression = ccode(uy).replace("M_PI", "pi")
T = 0.05            # final time
num_steps = 50   # number of time steps
mu = 0.0         # dynamic viscosity
rho = 1            # density
U_oo = 1
c_n = 1e-3
delta = 1/28
# Create mesh
channel = Rectangle(Point(0, 0), Point(1, 1))
domain = channel
mesh = generate_mesh(domain, 64)
    # Left boundary is "target domain" G
        return bool(x[0] < DOLFIN_EPS and x[0] > -DOLFIN_EPS and on_boundary)
    # Map right boundary (H) to left boundary (G)
    def map(self, x, y):
        y[0] = x[0] - 1.0
        y[1] = x[1]
pbc = PeriodicBoundary()
# Define function spaces
V = VectorFunctionSpace(mesh, 'P', 2, constrained_domain=pbc)
Q = FunctionSpace(mesh, 'P', 1, constrained_domain=pbc)
# Define boundaries
inflow   = 'near(x[0], 0)'
outflow  = 'near(x[0], 1)'
walls    = 'near(x[1], 0) || near(x[1], 1)'
# Define inflow profile
inflow_profile = ('4.0*1.5*x[1]*(1 - x[1]) / pow(1, 2)', '0')
initial_condition_profile = (
    ux_expression, uy_expression,
initial_condition = Expression(initial_condition_profile,
                               degree=2,
                               U_oo = U_oo,
                               c_n = c_n,
                               delta = delta,
# Define boundary conditions
bcu_free_slip = DirichletBC(V.sub(1), 0.0, walls)
bcp_outflow = DirichletBC(Q, Constant(0), outflow)
bcu = [
       bcu_free_slip,
bcp = [bcp_outflow]
p = TrialFunction(Q)
q = TestFunction(Q)
# Define functions for solutions at previous and current time steps
u_n = Function(V)
u_  = Function(V)
u_n.interpolate(initial_condition)
u_.interpolate(initial_condition)
p_n = Function(Q)
p_  = Function(Q)
u_n
U  = 0.5*(u_n + u)
n  = FacetNormal(mesh)
f  = Constant((0, 0))                # is this gravity?
k  = Constant(dt)
mu = Constant(mu)
rho = Constant(rho)
# Define symmetric gradient
    return sym(nabla_grad(u))
# Define stress tensor
def sigma(u, p):
    return 2*mu*epsilon(u) - p*Identity(len(u))
# Define variational problem for step 1
    # time stepping
    # convective term
    # stress tensor - diffusion and pressure
    # pressure on boundary
    # diffusion
    # gravity????
F1 = rho*dot((u - u_n) / k, v)*dx \
   + rho*dot(dot(u_n, nabla_grad(u_n)), v)*dx \
   + inner(sigma(U, p_n), epsilon(v))*dx \
   + dot(p_n*n, v)*ds \
   - dot(mu*nabla_grad(U)*n, v)*ds \
   - dot(f, v)*dx
a1 = lhs(F1)
L1 = rhs(F1)
a2 = dot(nabla_grad(p), nabla_grad(q))*dx
L2 = dot(nabla_grad(p_n), nabla_grad(q))*dx - (1/k)*div(u_)*q*dx
a3 = dot(u, v)*dx
L3 = dot(u_, v)*dx - k*dot(nabla_grad(p_ - p_n), v)*dx
# Assemble matrices
A1 = assemble(a1)
A2 = assemble(a2)
A3 = assemble(a3)
# Apply boundary conditions to matrices
[bc.apply(A1) for bc in bcu]
[bc.apply(A2) for bc in bcp]
# Create XDMF files for visualization output
# xdmffile_u = XDMFFile('navier_stokes_kh/velocity.xdmf')
# xdmffile_p = XDMFFile('navier_stokes_kh/pressure.xdmf')
# Time-stepping
t = 0
from tqdm import auto
with auto.tqdm(total=num_steps) as pbar:
    for n in range(num_steps):
        # Update current time
        b1 = assemble(L1)
        [bc.apply(b1) for bc in bcu]
        solve(A1, u_.vector(), b1, 'bicgstab', 'hypre_amg')
        b2 = assemble(L2)
        [bc.apply(b2) for bc in bcp]
        solve(A2, p_.vector(), b2, 'bicgstab', 'hypre_amg')
        b3 = assemble(L3)
        solve(A3, u_.vector(), b3, 'cg', 'sor')
        # Plot solution
        plt.figure()
        mappable = plot(u_**2, title='Velocity squared')
        plt.colorbar(mappable)
#         plt.figure()
#         plot(p_, title='Pressure')
#         # Save solution to file (XDMF/HDF5)
#         xdmffile_u.write(u_, t)
#         xdmffile_p.write(p_, t)
        # Update previous solution
        u_n.assign(u_)
        p_n.assign(p_)
        pbar.set_postfix({'u max': u_.vector().max(), "t": t})
        pbar.update(1)
# xdmffile_u.close()
# xdmffile_p.close()
However, on running this within a jupyter notebook, my velocity blows up to infinity somewhere on the mesh - the plot doesn’t display it. I have tried bumping up the number of steps to 500, but that doesn’t seem to have helped.
Is there anything obvious that I’m missing here?
I’m having the same problem.
Hi, I run it with a uniform mesh and some dissipation (mu=0.0001) and it is working ok.
But the boundary conditions for pressure are giving something non-periodic.
If you run for a long time (T=2) you will see 2 instabilities forming one on the center and the other on the boundary, that one getting destroyed very quickly because the boundary.
I guess one should give bc for the pressure on the top-botton part.
