2D Navier-Stokes with given inlet velocity - resulting pressure field is not physically right
I am working with the Navier-Stokes equation - the flow in the rectangular channel. And I was following the (provided example for channel flow. Thanks Dokken for really helpful example.
In my case, I have to consider the flow with given uniform velocity at the inlet = 2 m/s. Also, I should consider the Neumann boundary condition for pressure, but I just started to use FEniCS and didn’t get how to do this - I will appreciate any help with this.
Everything else is the same as is in example. The issue is that the resulting pressure doesn’t look right.
So here are the boundary conditions I have changed:
#define the boundary conditions
gdim = domain.geometry.dim
#walls
def walls(x):
    return np.logical_or(np.isclose(x[1], 0), np.isclose(x[1], width))
w_b_facets = mesh.locate_entities_boundary(domain, fdim, walls)
u_noslip = np.array((0,) * domain.geometry.dim, dtype=PETSc.ScalarType)
bcu_noslip = fem.dirichletbc(u_noslip, fem.locate_dofs_topological(V, fdim, w_b_facets), V)
# Inlet
def inflow(x):
    return np.isclose(x[0], 0)
class InletVelocity():
    def __init__(self, t):
        self.t = t
    def __call__(self, x):
        values = np.zeros((gdim, x.shape[1]), dtype=PETSc.ScalarType)
        values[0, :] = 2
        return values
in_b_facets = mesh.locate_entities_boundary(domain, fdim, inflow)
u_inlet = fem.Function(V)
inlet_velocity = InletVelocity(t)
u_inlet.interpolate(inlet_velocity)
bcu_inflow = fem.dirichletbc(u_inlet, fem.locate_dofs_topological(V, fdim, in_b_facets))
#outlet
def outflow(x):
    return np.isclose(x[0], lenght)
out_b_facets = mesh.locate_entities_boundary(domain, fdim, outflow)
bcp_outlet = fem.dirichletbc(PETSc.ScalarType(0), fem.locate_dofs_topological(Q, fdim, out_b_facets), Q)
bcu = [bcu_noslip, bcu_inflow]
bcp = [bcp_outlet]
For the images below I used density (rho) = 1 and viscosity (mu) = 1e-2
And here is a resulting pressure:
And resulting velocity:
Also, one more question, when I changed the density = 1000 and dynamic viscosity = 1e-3 (as right for water) the solution seems really unreasonable.
I will appreciate any help, to solve this issue. Thank you.
Please clarify what pressure you were expecting.
I can guess that you were expecting a pressure like in the Poiseuille flow. Note however that your velocity boundary conditions have jumps at the corners on the left, and this results in a singularity of the pressure, which is likely what you are seeing in your plot.
Furthermore, in FEM we typically do not impose strong boundary conditions on p at the outlet.
Changing density/viscosity means increasing a lot the Reynolds number. You may need some stabilization.
Yes, I am expecting the pressure like in Poiseuille flow (decreasing gradient towards the outlet). As you noticed, I have those jumps in the corners, might be because of the high Re number, will try to play with the variables.
I agree about strong boundary conditions for pressure. I prefer to set up the Neumann BC at the outlet, but I cannot figure out how to do it. Could you please help with this?
then you must impose a parabolic profile at the inlet, not a flat one
you don’t need to do anything to set a homogeneous Neumann BC, because it would result in a boundary integral with zero integrand.
Thank you.
So, you mean that I don’t need to set up the outlet boundary conditions for pressure?
Indeed, you don’t need it.
I follow your suggestion and run the code with no outlet boundary conditions.
But the solution is not right. With rho = 1, mu = 0.1, inlet velocity = 1, and lengths of the channel = 2 - the Reynolds number = 20, which mean laminar flow:
But here you can see the jumps in the inlet corners, and the values for pressure -9.11e+11 = too much.
So, I do need some boundary conditions for the pressure and with Dirichlet BC I used, at least the values are not that high.
I can’t help much more unless I see the code.
Here are the code. I really appreciate your help. Thank you.
import pyvista
from dolfinx import fem, mesh, io, plot
from dolfinx.fem.petsc import assemble_vector, assemble_matrix, create_vector, apply_lifting, set_bc
#define the constants:
lenght = 2
width = 0.5
mu = 1e-2
rho = 1
#create the rectangular mesh
domain = mesh.create_rectangle(MPI.COMM_WORLD, [np.array([0, 0]), np.array([lenght, width])],
                               [41, 6], cell_type=mesh.CellType.triangle)
#time steps
t = 0
Tend = 5
num_steps = 5000
dt = Tend / num_steps
#create the function space
from basix.ufl import element
v_cg2 = element("Lagrange", domain.topology.cell_name(), 2, shape=(domain.geometry.dim, ))
s_cg1 = element("Lagrange", domain.topology.cell_name(), 1)
V = fem.functionspace(domain, v_cg2)
Q = fem.functionspace(domain, s_cg1)
#create the trial and test functions
p, q = ufl.TrialFunction(Q), ufl.TestFunction(Q)
#walls
def walls(x):
# Inlet
def inflow(x):
        self.t = t
        values[0, :] = 2
        return values
#outlet
def outflow(x):
bcp = [bcp_outlet]
#define the variational problem
u_n = fem.Function(V)
u_n.name = "u_n"
U = 0.5 * (u_n + u)
n = ufl.FacetNormal(domain)
f = fem.Constant(domain, PETSc.ScalarType((0, 0)))
k = fem.Constant(domain, PETSc.ScalarType(dt))
mu = fem.Constant(domain, PETSc.ScalarType(mu))
rho = fem.Constant(domain, PETSc.ScalarType(rho))
# Define strain-rate tensor
    return ufl.sym(ufl.nabla_grad(u))
# Define stress tensor
def sigma(u, p):
    return 2 * mu * epsilon(u) - p * ufl.Identity(len(u))
# Define the variational problem for the first step
p_n = fem.Function(Q)
p_n.name = "p_n"
F1 = rho * ufl.dot((u - u_n) / k, v) * ufl.dx
F1 += rho * ufl.dot(ufl.dot(u_n, ufl.nabla_grad(u_n)), v) * ufl.dx
F1 += ufl.inner(sigma(U, p_n), epsilon(v)) * ufl.dx
F1 += ufl.dot(p_n * n, v) * ufl.ds - ufl.dot(mu * ufl.nabla_grad(U) * n, v) * ufl.ds
F1 -= ufl.dot(f, v) * ufl.dx
a1 = fem.form(ufl.lhs(F1))
L1 = fem.form(ufl.rhs(F1))
A1 = assemble_matrix(a1, bcs=bcu)
A1.assemble()
b1 = create_vector(L1)
u_ = fem.Function(V)
a2 = fem.form(ufl.dot(ufl.nabla_grad(p), ufl.nabla_grad(q)) * ufl.dx)
L2 = fem.form(ufl.dot(ufl.nabla_grad(p_n), ufl.nabla_grad(q)) * ufl.dx - (rho / k) * ufl.div(u_) * q * ufl.dx)
A2.assemble()
b2 = create_vector(L2)
p_ = fem.Function(Q)
a3 = fem.form(rho * ufl.dot(u, v) * ufl.dx)
L3 = fem.form(rho * ufl.dot(u_, v) * ufl.dx - k * ufl.dot(ufl.nabla_grad(p_ - p_n), v) * ufl.dx)
A3 = assemble_matrix(a3)
A3.assemble()
b3 = create_vector(L3)
# Solver for step 1
solver1 = PETSc.KSP().create(domain.comm)
solver1.setOperators(A1)
pc1 = solver1.getPC()
pc1.setHYPREType("boomeramg")
# Solver for step 2
solver2 = PETSc.KSP().create(domain.comm)
solver2.setOperators(A2)
solver2.setType(PETSc.KSP.Type.BCGS)
pc2 = solver2.getPC()
pc2.setHYPREType("boomeramg")
# Solver for step 3
solver3 = PETSc.KSP().create(domain.comm)
solver3.setOperators(A3)
pc3 = solver3.getPC()
from pathlib import Path
folder = Path("results")
folder.mkdir(exist_ok=True, parents=True)
vtx_u = io.VTXWriter(domain.comm, folder / "u.bp", u_n, engine="BP4")
vtx_p = io.VTXWriter(domain.comm, folder / "p.bp", p_n, engine="BP4")
vtx_u.write(t)
vtx_p.write(t)
for i in range(num_steps):
    # Update current time step
    # Step 1: Tentative veolcity step
    with b1.localForm() as loc_1:
        loc_1.set(0)
    assemble_vector(b1, L1)
    set_bc(b1, bcu)
    solver1.solve(b1, u_.vector)
    u_.x.scatter_forward()
    # Step 2: Pressure corrrection step
    with b2.localForm() as loc_2:
        loc_2.set(0)
    assemble_vector(b2, L2)
    set_bc(b2, bcp)
    solver2.solve(b2, p_.vector)
    p_.x.scatter_forward()
    with b3.localForm() as loc_3:
        loc_3.set(0)
    assemble_vector(b3, L3)
    solver3.solve(b3, u_.vector)
    u_n.x.array[:] = u_.x.array[:]
    p_n.x.array[:] = p_.x.array[:]
    # Write solutions to file
    vtx_u.write(t)
    vtx_p.write(t)
# Close xmdf file
vtx_u.close()
vtx_p.close()
b1.destroy()
b2.destroy()
b3.destroy()
solver1.destroy()
solver2.destroy()
solver3.destroy()
I won’t be able to run it for a couple of days now, but at first glance, the inlet profile is not parabolic, which was suggested above.
Yes, I have to stuck with this profile for the class project, unfortunately.
