You can try defining an expression that you can interpolate to get rid of your third axis.
Something like this:
#Dummy problem
# Create mesh and define function space
mesh = UnitCubeMesh(8, 8, 8)
V = FunctionSpace(mesh, 'CG', 1)
# Define boundary condition
u_D = Constant(0)
def boundary(x, on_boundary):
return on_boundary
bc = DirichletBC(V, u_D, boundary)
# Define variational problem
u = TrialFunction(V)
f = Constant(100)
a = dot(grad(u), grad(v))*dx
L = f*v*dx
# Compute solution
u = Function(V)
solve(a == L, u, bc)
# Plot solution and mesh
plt.colorbar(plot(u))
plt.title('u')
Define an expression to evaluate u
at some value of z:
class u_slice(UserExpression):
def eval(self, value, x):
value[0] = u(x[0],x[1],0.5)
def value_shape(self):
return ()
mesh_2D = UnitSquareMesh(8, 8)
V_2D = FunctionSpace(mesh_2D, 'CG', 1)
u_sl = interpolate(u_slice(), V_2D)
plt.colorbar(plot(u_sl))
plt.title('u in the middle plane')
