Here’s the complete code:
from dolfinx import mesh, fem, io, plot, default_scalar_type
import os
from tqdm import tqdm
import csv
import sys
### (1a) define the 3D domain
coords_lower_left = [0.0, 0.0, 0.0]
Lx, Ly, Lz = 1.0, 1.0, 1.0
coords_upper_right = [Lx, Ly, Lz]
num_elements = [1, 1, 1]
domain = mesh.create_box(MPI.COMM_WORLD, [coords_lower_left, coords_upper_right], num_elements, mesh.CellType.hexahedron)
### (1b) set element types
element_u = ufl.VectorElement("CG", domain.ufl_cell(), degree=2) ## vector: displacement
element_p= ufl.FiniteElement("CG", domain.ufl_cell(), degree=1) ## scalar: pressure
element_mix = ufl.MixedElement(element_u, element_p)
V = fem.FunctionSpace(domain, element_mix)
V_disp = V.sub(0)
V_press = V.sub(1)
### displacement component in x direction
V_disp_x = V_disp.sub(0)
def front(x):
return np.isclose(x[0], 1, atol=1.0e-12)
value_zero= fem.Constant(domain, 0.1)
facet_front = mesh.locate_entities_boundary(domain, fdim, front)
dofs_front_x = fem.locate_dofs_topological(V_disp_x, fdim, facet_front)
bc_front_x = fem.dirichletbc(value_zero, dofs_front_x, V_disp_x)
bcs = [bc_front_x]
I tried “fem.locate_dofs_topological” in the above to get dofs.
For plot the figure in Paraview, the code is
##### plot boundary conditions to Paraview for mixed formulation
Mixed_Space = V
u_boundary = fem.Function(Mixed_Space, name='boundary')
fem.petsc.set_bc(u_boundary.vector, bcs)
u_boundary.x.scatter_forward()
with io.XDMFFile(domain.comm, "boundary/bc_geometrical.xdmf", "w") as xdmf:
xdmf.write_mesh(domain)
xdmf.write_function(u_boundary.sub(0))
