3D PCB Coil Inductance Calculation
I am currently working on a FEM simulation in FEnicCSx09 to calculate the inductance of a PCB Coil. My current code and debug is attached below. The results for my coil shape are multiple orders of magnitude too high and I don`t know why. Can someone please help me find the error?
# solve_spiral_inductance_3d.py (verbose)
import argparse, json, time
from dolfinx import fem, io
from dolfinx.io import gmshio
# Hilfsfunktionen
def build_rect_centerline(params):
    """Polyline der rechteckigen Spirale (2D, z wird separat gesetzt)."""
    N   = int(params["num_turns"])
    din = float(params["inner_diameter"])
    w   = float(params["trace_width"])
    s   = float(params["spacing"])
    directions = [(1,0), (0,1), (-1,0), (0,-1)]
    seg_len = din  # Start = inner_diameter
    x = y = 0.0
    pts = [(x,y)]
    dir_idx = 0
    for i in range(N * 4):
        dx, dy = directions[dir_idx]
        x += dx * seg_len
        y += dy * seg_len
        pts.append((x,y))
        dir_idx = (dir_idx + 1) % 4
        if i % 2 == 1:
            seg_len += (w + s)
    return pts
def cell_centroid(domain, cell):
    """Schwerpunkt einer 3D-Zelle (arithm. Mittel der Eckpunkte)."""
    topo = domain.topology
    tdim = topo.dim
    if topo.connectivity(tdim, 0) is None:
        topo.create_connectivity(tdim, 0)
    c2v = topo.connectivity(tdim, 0)
    vtx = c2v.links(cell)
    X = domain.geometry.x[vtx]
    return X.mean(axis=0)  # (x,y,z)
def segments3d_from_path(centerline_xy, z_spiral_mid, p0, p1, z_top, via_h, z_bridge_mid):
    Erzeuge 3D-Segmente mit Typ-Labels:
      - Spiral: rückwärts (p1->p0) in der Ebene z_spiral_mid
      - Via0:   von p0 z_top -> z_top+via_h
      - Bridge: p0->p1 auf z_bridge_mid
      - Via1:   von p1 z_top+via_h -> z_top
    Rückgabe: Liste [(A,B,t_hat,L,kind), ...] und Längen-Stats.
    segs = []
    L_spiral = 0.0
    # Spirale rückwärts
    for i in range(len(centerline_xy)-1, 0, -1):
        A = np.array([centerline_xy[i][0],   centerline_xy[i][1],   z_spiral_mid])
        B = np.array([centerline_xy[i-1][0], centerline_xy[i-1][1], z_spiral_mid])
        v = B - A; L = float(np.linalg.norm(v))
        if L > 0:
            segs.append((A, B, v/L, L, "spiral"))
            L_spiral += L
    # Via an p0: nach oben
    A = np.array([p0[0], p0[1], z_top]);       B = np.array([p0[0], p0[1], z_top + via_h])
    v = B - A; L_via0 = float(np.linalg.norm(v))
    segs.append((A, B, v/L_via0, L_via0, "via0"))
    # Brücke: p0 -> p1, mittig in der Brücke
    A = np.array([p0[0], p0[1], z_bridge_mid]); B = np.array([p1[0], p1[1], z_bridge_mid])
    v = B - A; L_bridge = float(np.linalg.norm(v))
    segs.append((A, B, v/L_bridge, L_bridge, "bridge"))
    # Via an p1: nach unten
    A = np.array([p1[0], p1[1], z_top + via_h]); B = np.array([p1[0], p1[1], z_top])
    v = B - A; L_via1 = float(np.linalg.norm(v))
    segs.append((A, B, v/L_via1, L_via1, "via1"))
    stats = {
        "L_spiral": L_spiral,
        "L_via0": L_via0,
        "L_bridge": L_bridge,
        "L_via1": L_via1,
        "L_total": L_spiral + L_via0 + L_bridge + L_via1
    return segs, stats
def nearest_tangent_3d(segs3d, pxyz):
    """Tangente des nächstgelegenen Segmentes an Punkt pxyz."""
    p = np.array(pxyz)
    best_d2 = 1e300
    best_t  = np.array([1.0, 0.0, 0.0])
    for A, B, t_hat, L, kind in segs3d:
        v = B - A
        t = np.dot(p - A, v) / (L*L)
        t = min(1.0, max(0.0, t))
        q = A + t*v
        d2 = float(np.sum((p - q)**2))
        if d2 < best_d2:
            best_d2 = d2
            best_t  = t_hat
    return best_t
# Main
def main():
    # --- imports lokal halten, damit Drop-in einfach ist ---
    parser = argparse.ArgumentParser()
    parser.add_argument("--msh", default="rect_spiral_with_inner_d.msh",
                        help="Gmsh mesh (MSH4.1) (default: rect_spiral_with_inner_d.msh)")
    parser.add_argument("--meta", default="spiral_meta.json",
                        help="JSON metadata file (default: spiral_meta.json)")
    parser.add_argument("--I", type=float, default=1.0, help="Total current [A]")
    parser.add_argument("--alpha", type=float, default=1e-4, help="Gauge parameter (div-div penalty)")
    parser.add_argument("--mu_r_air", type=float, default=1.0)
    parser.add_argument("--mu_r_cu",  type=float, default=1.0)
    parser.add_argument("--save-xdmf", type=int, default=1, help="Write XDMF with A and |B|")
    parser.add_argument("--xdmf", default="solution_fields.xdmf")
    parser.add_argument("--debug", type=int, default=1, help="Verbose prints (0/1)")
    args = parser.parse_args()
    comm = MPI.COMM_WORLD
    rank = comm.rank
    dbg  = (args.debug == 1)
    t0 = time.perf_counter()
    if rank == 0 and dbg:
        print(f"\n[dbg] start solve_spiral_inductance_3d: I={args.I}, alpha={args.alpha}\n")
    # --- Mesh laden ---
    t = time.perf_counter()
    domain, cell_tags, facet_tags = gmshio.read_from_msh(args.msh, comm, rank)
        print(f"[dbg] read_from_msh: {time.perf_counter()-t:.3f} s")
    tdim = domain.topology.dim
    COIL = 1
    AIR  = 2
    coil_cells = cell_tags.find(COIL)
    air_cells  = cell_tags.find(AIR)
    if rank == 0:
        total_cells = cell_tags.indices.size
        print(f"[info] cells: total={total_cells}, coil={coil_cells.size}, air={air_cells.size}")
    # --- Metadaten lesen ---
    if rank == 0:
        with open(args.meta, "r") as f:
            meta = json.load(f)
        meta = None
    meta = comm.bcast(meta, root=0)
    params = meta.get("params", {})
    num_layers   = int(params.get("num_layers", 1))
    layer_offset = float(params.get("layer_offset", 0.0))
    thickness    = float(params.get("thickness", 0.0))
    w_trace      = float(params.get("trace_width", 0.0))
    N   = int(params.get("num_turns", 0))
    din = float(params.get("inner_diameter", 0.0))
    s   = float(params.get("spacing", 0.0))
    if rank == 0:
        print(f"[info] params: N={N}, din={din}, w={w_trace}, s={s}, layers={num_layers}, t={thickness}, offset={layer_offset}")
    # Return-Loop Info (falls vorhanden, sonst Fallbacks)
    rmeta = meta.get("return_loop", {})
    via_h     = float(rmeta.get("via_h",     max(6.0*thickness, 0.2*w_trace)))
    bridge_tz = float(rmeta.get("bridge_tz", max(2.0*thickness, 0.02*w_trace)))
    z_top     = float(rmeta.get("z_top",     thickness))
    z_bridge  = float(rmeta.get("z_bridge",  z_top + max(6.0*thickness, 0.2*w_trace)))
    z_spiral_mid = thickness * 0.5
    z_bridge_mid = z_bridge + 0.5 * bridge_tz
        print(f"[dbg] return_loop: via_h={via_h:g}, bridge_tz={bridge_tz:g}, z_top={z_top:g}, z_bridge={z_bridge:g}")
        print(f"[dbg] z_spiral_mid={z_spiral_mid:g}, z_bridge_mid={z_bridge_mid:g}")
    # --- Konstanten & Räume ---
    mu0 = 4e-7 * np.pi
    mu_air = mu0 * args.mu_r_air
    mu_cu  = mu0 * args.mu_r_cu
        print(f"[dbg] mu_air={mu_air:.6e}, mu_cu={mu_cu:.6e}")
    V = fem.FunctionSpace(domain, ("N1curl", 1))   # H(curl)
    Q = fem.FunctionSpace(domain, ("DG", 0))       # skalar DG0 (für invmu)
    A = ufl.TrialFunction(V)
    dx = ufl.Measure("dx", domain=domain, subdomain_data=cell_tags)
    # --- 1/mu (DG0) ---
    invmu = fem.Function(Q)
    invmu.x.array[:] = 0.0
    dofs_air  = fem.locate_dofs_topological(Q, tdim, air_cells)
    dofs_coil = fem.locate_dofs_topological(Q, tdim, coil_cells)
    invmu.x.array[dofs_air]  = 1.0/mu_air
    invmu.x.array[dofs_coil] = 1.0/mu_cu
    invmu.x.scatter_forward()
        print(f"[dbg] invmu set (air/coils): {time.perf_counter()-t:.3f} s, "
              f"n_dofs(Q)={Q.dofmap.index_map.size_local}")
    # --- Stromdichte-Skalierung & Geometriepfad ---
    I = float(args.I)
    if w_trace <= 0 or thickness <= 0:
        raise RuntimeError("trace_width or thickness missing/non-positive in meta.")
    # 2D-Mittellinie & Ports (Fallbacks aus meta)
    cl = build_rect_centerline({
        "num_turns": N,
        "inner_diameter": din,
        "trace_width": w_trace,
        "spacing": s
    p0 = tuple(meta.get("port_plus_xy",  [cl[0][0],  cl[0][1]]))
    p1 = tuple(meta.get("port_minus_xy", [cl[-1][0], cl[-1][1]]))
    # 3D-Segmente & Stats
    segs3d, segstats = segments3d_from_path(cl, z_spiral_mid, p0, p1, z_top, via_h, z_bridge_mid)
        print(f"[dbg] built segments3d in {time.perf_counter()-t:.3f} s (n={len(segs3d)})")
        print(f"      L_spiral={segstats['L_spiral']:.6e}, "
              f"L_via0={segstats['L_via0']:.6e}, "
              f"L_bridge={segstats['L_bridge']:.6e}, "
              f"L_via1={segstats['L_via1']:.6e}, "
              f"L_total={segstats['L_total']:.6e}")
    # Volumen der Spule (aus Mesh) und Pfadlänge (3D)
    one = fem.Function(Q); one.x.array[:] = 1.0
    V_coil_loc = fem.assemble_scalar(fem.form(one * dx(COIL)))
    V_coil = domain.comm.allreduce(V_coil_loc, op=MPI.SUM)
    L_path = segstats["L_total"]
    # 2D-Pfadlänge + V_theo (nur Diagnose)
    L_theo2d = 0.0
    for i in range(1, len(cl)):
        dx2 = cl[i][0] - cl[i-1][0]
        dy2 = cl[i][1] - cl[i-1][1]
        L_theo2d += float((dx2*dx2 + dy2*dy2)**0.5)
    V_theo = L_theo2d * w_trace * thickness
    if rank == 0:
        print(f"[diag] V_coil(mesh) = {V_coil:.3e} m^3")
        print(f"[diag] L_path(3D)   = {L_path:.3e} m")
        print(f"[diag] L_theo2d     = {L_theo2d:.3e} m,  V_theo ≈ {V_theo:.3e} m^3")
    if V_coil <= 0 or L_path <= 0:
        raise RuntimeError("V_coil oder L_path ist 0 – Mesh/Tags prüfen.")
    # --- Outer Airbox Dirichlet-BC: A × n = 0 (magnetic insulation) ---
    from dolfinx import mesh as dmesh
    # Airbox aus Meta: [ax, ay, az, adx, ady, adz]
    ax, ay, az, adx, ady, adz = [float(v) for v in meta.get("airbox", [0, 0, 0, 0, 0, 0])]
    if (adx <= 0) or (ady <= 0) or (adz <= 0):
        raise RuntimeError("Airbox-Daten fehlen oder sind ungültig in meta['airbox'].")
    # Geometrische Toleranz für die Ebenen (1e-6 der Boxgröße ist robust)
    tol = 1e-6 * max(adx, ady, adz)
    # Marker: alle **äußeren** Facetten der Box (x==ax|ax+adx oder y==... oder z==...)
    def on_outer_boundary(x):
        near_xmin = np.isclose(x[0], ax, atol=tol)
        near_xmax = np.isclose(x[0], ax + adx, atol=tol)
        near_ymin = np.isclose(x[1], ay, atol=tol)
        near_ymax = np.isclose(x[1], ay + ady, atol=tol)
        near_zmin = np.isclose(x[2], az, atol=tol)
        near_zmax = np.isclose(x[2], az + adz, atol=tol)
        return near_xmin | near_xmax | near_ymin | near_ymax | near_zmin | near_zmax
    facet_dim = tdim - 1
    outer_facets = dmesh.locate_entities_boundary(domain, facet_dim, on_outer_boundary)
    # DOFs des H(curl)-Raums auf diesen Facetten
    outer_dofs = fem.locate_dofs_topological(V, facet_dim, outer_facets)
    # Zero-Function als Wert (setzt die **tangentialen** Nédélec-DOFs auf 0)
    A_zero = fem.Function(V)
    A_zero.x.array[:] = 0.0
    bc_outer = fem.dirichletbc(A_zero, outer_dofs)
        print(f"[dbg] outer BC: facets={outer_facets.size}, dofs={outer_dofs.size}")
    # robuste J-Skalierung
    Jmag = I * (L_path / V_coil)
    J0_th = I / (w_trace * thickness)
    if rank == 0:
        print(f"[diag] Jmag = {Jmag:.3e} A/m^2  (skalierte J-Größe)")
        print(f"[diag] J0_th (I/(w*t)) = {J0_th:.3e} A/m^2,  ratio Jmag/J0_th = {Jmag/J0_th:.3f}")
    # --- J als DG0-Vektorfeld (zellweise konstant entlang 3D-Tangente) ---
    Wv = fem.VectorFunctionSpace(domain, ("DG", 0))
    J = fem.Function(Wv); J.x.array[:] = 0.0
    jx_vals, jy_vals, jz_vals = [], [], []
    for cell in coil_cells:
        cx, cy, cz = cell_centroid(domain, int(cell))
        t_hat = nearest_tangent_3d(segs3d, (cx, cy, cz))
        jx_vals.append(Jmag * t_hat[0])
        jy_vals.append(Jmag * t_hat[1])
        jz_vals.append(Jmag * t_hat[2])
    Jx = J.sub(0); Vx = Jx.function_space
    Jy = J.sub(1); Vy = Jy.function_space
    Jz = J.sub(2); Vz = Jz.function_space
    dofs_x = fem.locate_dofs_topological(Vx, tdim, coil_cells)
    dofs_y = fem.locate_dofs_topological(Vy, tdim, coil_cells)
    dofs_z = fem.locate_dofs_topological(Vz, tdim, coil_cells)
    Jx.x.array[dofs_x] = np.asarray(jx_vals, dtype=np.float64)
    Jy.x.array[dofs_y] = np.asarray(jy_vals, dtype=np.float64)
    Jz.x.array[dofs_z] = np.asarray(jz_vals, dtype=np.float64)
    J.x.scatter_forward()
        nWv = Wv.dofmap.index_map.size_local * Wv.dofmap.index_map_bs
        print(f"[dbg] filled J (DG0 vec) in {time.perf_counter()-t:.3f} s, n_dofs(Wv)={nWv}")
    # zusätzliche J-Diagnosen
    J_L2_loc = fem.assemble_scalar(fem.form(ufl.inner(J, J) * dx(COIL)))
    J_L2 = domain.comm.allreduce(J_L2_loc, op=MPI.SUM)
        print(f"[dbg] ||J||_L2^2 over COIL = {J_L2:.6e}")
        print(f"[dbg] Jx min/max on set DOFs = {np.min(Jx.x.array[dofs_x]):.3e} / {np.max(Jx.x.array[dofs_x]):.3e}")
        print(f"[dbg] Jy min/max on set DOFs = {np.min(Jy.x.array[dofs_y]):.3e} / {np.max(Jy.x.array[dofs_y]):.3e}")
        print(f"[dbg] Jz min/max on set DOFs = {np.min(Jz.x.array[dofs_z]):.3e} / {np.max(Jz.x.array[dofs_z]):.3e}")
    # ===== Magnetisierungs-RHS: M(x) = 1/2 * (x - c_cell) x J_cell  (DG0) =====
    Vsc = fem.FunctionSpace(domain, ("DG", 0))
    Cx = fem.Function(Vsc); Cy = fem.Function(Vsc); Cz = fem.Function(Vsc)
    Cx.x.array[:] = 0.0; Cy.x.array[:] = 0.0; Cz.x.array[:] = 0.0
    dofs_sc = fem.locate_dofs_topological(Vsc, tdim, coil_cells)  # DG0: 1 DOF pro Zelle
    cx_list, cy_list, cz_list = [], [], []
        cx_list.append(cx); cy_list.append(cy); cz_list.append(cz)
    Cx.x.array[dofs_sc] = np.asarray(cx_list, dtype=np.float64)
    Cy.x.array[dofs_sc] = np.asarray(cy_list, dtype=np.float64)
    Cz.x.array[dofs_sc] = np.asarray(cz_list, dtype=np.float64)
    Cx.x.scatter_forward(); Cy.x.scatter_forward(); Cz.x.scatter_forward()
    C = ufl.as_vector((Cx, Cy, Cz))
    r = ufl.as_vector((x[0] - C[0], x[1] - C[1], x[2] - C[2]))  # x - c_cell
    M = 0.5 * ufl.cross(r, J)
        print(f"[dbg] built magnetization field M in {time.perf_counter()-t:.3f} s")
    # M-Diagnosen
    M_L2_loc = fem.assemble_scalar(fem.form(ufl.inner(M, M) * dx(COIL)))
    M_L2 = domain.comm.allreduce(M_L2_loc, op=MPI.SUM)
        print(f"[dbg] ||M||_L2^2 over COIL = {M_L2:.6e}")
    # RHS-Tests: Norm der RHS-Vektoren für beide Formen
    bM_vec = fem.petsc.assemble_vector(fem.form(ufl.inner(M, ufl.curl(v)) * dx(COIL)))
    bM_norm2 = bM_vec.norm(PETSc.NormType.NORM_2)
    bJ_vec = fem.petsc.assemble_vector(fem.form(ufl.inner(J, v) * dx(COIL)))
    bJ_norm2 = bJ_vec.norm(PETSc.NormType.NORM_2)
    if rank == 0:
        print(f"[diag] ||b_M||_2 = {bM_norm2:.6e}  (RHS for M·curl(v))")
        print(f"[diag] ||b_J||_2 = {bJ_norm2:.6e}  (RHS for J·v)")
    use_Mcurlv = True
    if not np.isfinite(bM_norm2) or bM_norm2 < 1e-14:
        if rank == 0:
            print("[warn] b_M is ~0 → switching RHS to ∫ J·v dx(COIL) for this run.")
        use_Mcurlv = False
    # Variationsform & Lösung
    curlA = ufl.curl(A);  curlv = ufl.curl(v)
    divA  = ufl.div(A);   divv  = ufl.div(v)
    a_form = ufl.inner(invmu * curlA, curlv) * dx + args.alpha * ufl.inner(divA, divv) * dx
    L_form = ufl.inner(M, curlv) * dx(COIL) if use_Mcurlv else ufl.inner(J, v) * dx(COIL)
    petsc_opts = {
        "ksp_type": "cg",
        "pc_type": "hypre",
        "ksp_rtol": 1e-8,
        "ksp_max_it": 50000
    if dbg:
        petsc_opts.update({"ksp_monitor_true_residual": None})
    # (optional) Matrix- und RHS-Diagnose
    if dbg:
        A_mat = fem.petsc.assemble_matrix(fem.form(a_form)); A_mat.assemble()
        b_vec = fem.petsc.assemble_vector(fem.form(L_form))
        if rank == 0:
            m, n = A_mat.getSize()
            print(f"[dbg] assembled A: {m}x{n},  ||b||_2 (used) = {b_vec.norm(PETSc.NormType.NORM_2):.6e}")
    problem = fem.petsc.LinearProblem(a_form, L_form, bcs=[bc_outer], petsc_options=petsc_opts)
    A_sol = problem.solve()
        print(f"[dbg] linear solve done in {time.perf_counter()-t:.3f} s")
    # Energie & Induktivität
    energy_density = 0.5 * ufl.inner(invmu * ufl.curl(A_sol), ufl.curl(A_sol))
    Wm_local = fem.assemble_scalar(fem.form(energy_density * dx))
    Wm = domain.comm.allreduce(Wm_local, op=MPI.SUM)
    L_val = 2.0 * Wm / (I * I)
    if rank == 0:
        print("---------- Ergebnisse ----------")
        print(f"I           = {I:.6g} A")
        print(f"W_m         = {Wm:.6e} J")
        print(f"L (Num)     = {L_val:.6e} H  ({L_val*1e6:.3f} µH)")
        print(f"alpha (gauge) = {args.alpha:g}")
        print("Hinweis: alpha zu klein -> langsamer; zu groß -> leichte Verfälschung (1e-5..3e-4 üblich).")
        print(f"[dbg] energy & L computed in {time.perf_counter()-t:.3f} s")
        print(f"[dbg] total wall time: {time.perf_counter()-t0:.3f} s\n")
    # Feldausgabe (optional)
    if args.save_xdmf:
        with io.XDMFFile(comm, args.xdmf, "w") as xdmf:
            xdmf.write_mesh(domain)
            A_sol.name = "A"
            xdmf.write_function(A_sol)
            # |B| ≡ |curl A| als DG0-Projektion
            V0 = fem.FunctionSpace(domain, ("DG", 0))
            bmag_trial = ufl.TrialFunction(V0)
            bmag_test  = ufl.TestFunction(V0)
            b_abs = ufl.sqrt(ufl.inner(ufl.curl(A_sol), ufl.curl(A_sol)))
            Mmat = fem.petsc.assemble_matrix(fem.form(ufl.inner(bmag_trial, bmag_test) * dx))
            Mmat.assemble()
            rhs = fem.petsc.assemble_vector(fem.form(ufl.inner(b_abs, bmag_test) * dx))
            kspM = PETSc.KSP().create(comm)
            kspM.setOperators(Mmat)
            kspM.setType("preonly")
            kspM.getPC().setType("lu")
            Bmag = fem.Function(V0)
            kspM.solve(rhs, Bmag.vector)
            kspM.destroy(); Mmat.destroy()
            Bmag.name = "B_mag"
            xdmf.write_function(Bmag)
            print(f"[dbg] wrote XDMF '{args.xdmf}' in {time.perf_counter()-t:.3f} s")
if __name__ == "__main__":
    main()
DEBUG:
Info    : Reading 'rect_spiral_with_inner_d.msh'...
Info    : 354 entities
Info    : 87399 nodes
Info    : 514648 elements
Info    : Done reading 'rect_spiral_with_inner_d.msh'
[dbg] read_from_msh: 2.935 s
[info] cells: total=514172, coil=64634, air=449538
[info] params: N=5, din=0.02, w=0.001, s=0.000305, layers=1, t=3.5e-05, offset=0.1
[dbg] return_loop: via_h=0.00021, bridge_tz=7e-05, z_top=3.5e-05, z_bridge=0.000245
[dbg] z_spiral_mid=1.75e-05, z_bridge_mid=0.00028
[dbg] mu_air=1.256637e-06, mu_cu=1.256637e-06
[dbg] invmu set (air/coils): 0.011 s, n_dofs(Q)=514172
[dbg] built segments3d in 0.000 s (n=23)
      L_spiral=5.174500e-01, L_via0=2.100000e-04, L_bridge=9.227743e-03, L_via1=2.100000e-04, L_total=5.270977e-01
[diag] V_coil(mesh) = 1.840e-08 m^3
[diag] L_path(3D)   = 5.271e-01 m
[diag] L_theo2d     = 5.175e-01 m,  V_theo ≈ 1.811e-08 m^3
[dbg] outer BC: facets=15438, dofs=23157
[diag] Jmag = 2.865e+07 A/m^2  (skalierte J-Größe)
[diag] J0_th (I/(w*t)) = 2.857e+07 A/m^2,  ratio Jmag/J0_th = 1.003
[dbg] filled J (DG0 vec) in 6.484 s, n_dofs(Wv)=1542516
[dbg] ||J||_L2^2 over COIL = 1.509898e+07
[dbg] Jx min/max on set DOFs = -2.865e+07 / 2.865e+07
[dbg] Jy min/max on set DOFs = -2.865e+07 / 2.865e+07
[dbg] Jz min/max on set DOFs = -2.865e+07 / 2.865e+07
[dbg] built magnetization field M in 0.478 s
[dbg] ||M||_L2^2 over COIL = 6.966018e-03
[diag] ||b_M||_2 = 0.000000e+00  (RHS for M·curl(v))
[diag] ||b_J||_2 = 1.168467e+01  (RHS for J·v)
[dbg] assembled A: 609289x609289,  ||b||_2 (used) = 1.168467e+01
  Residual norms for dolfinx_solve_140392748349328 solve.
  0 KSP preconditioned resid norm 2.391738792685e-09 true resid norm 1.168467430546e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP preconditioned resid norm 2.115977861520e-09 true resid norm 3.025691613538e+01 ||r(i)||/||b|| 2.589453102791e+00
  2 KSP preconditioned resid norm 2.889406258169e-09 true resid norm 2.725998075772e+01 ||r(i)||/||b|| 2.332968814115e+00
  3 KSP preconditioned resid norm 3.558588537718e-09 true resid norm 2.740711052062e+01 ||r(i)||/||b|| 2.345560501230e+00
93 KSP preconditioned resid norm 2.078192668759e-05 true resid norm 8.471668680144e+04 ||r(i)||/||b|| 7.250239466397e+03
 94 KSP preconditioned resid norm 2.288764633062e-05 true resid norm 9.188390810838e+04 ||r(i)||/||b|| 7.863625951940e+03
 95 KSP preconditioned resid norm 2.554314848967e-05 true resid norm 1.022047265633e+05 ||r(i)||/||b|| 8.746904183328e+03
[dbg] linear solve done in 17.914 s
I           = 1 A
W_m         = 6.438404e+00 J
L (Num)     = 1.287681e+01 H  (12876807.870 µH)
alpha (gauge) = 0.0001
[dbg] energy & L computed in 0.085 s
[dbg] total wall time: 29.302 s
[dbg] wrote XDMF 'solution_fields.xdmf' in 0.249 s
Process finished with exit code 0
