Hi FEniCS family,
I am getting error in creating function space using periodic boundary conditions. Please find the below MWE.
a1 = 1
## Create mesh and define function space
mesh = BoxMesh(Point(-0.5, -0.5, -0.5), Point(0.5,0.5,0.5), a1, a1, a1)
# return True if on left or bottom boundary AND NOT on one of the two slave edges
return bool ((near(x[0], -a1/2) or near(x[1], -a1/2) or near(x[2], -a1/2)) and
(not ((near(x[0], a1/2) and near(x[2], a1/2)) or
(near(x[0], a1/2) and near(x[1], a1/2)) or
(near(x[1], a1/2) and near(x[2], a1/2)))) and on_boundary)
# Map right boundary (H) to left boundary (G)
def map(self, x, y):
#### define mapping for a single point in the box, such that 3 mappings are required
if near(x[0], a1/2) and near(x[1], a1/2) and near(x[2],a1/2):
y[0] = x[0] - a1
y[1] = x[1] - a1
y[2] = x[2] - a1
##### define mapping for edges in the box, such that mapping in 2 Cartesian coordinates are required
elif near(x[0], a1/2) and near(x[2], a1/2):
y[0] = x[0] - a1
y[1] = x[1]
y[2] = x[2] - a1
elif near(x[1], a1/2) and near(x[2], a1/2):
y[0] = x[0]
y[1] = x[1] - a1
y[2] = x[2] - a1
elif near(x[0], a1/2) and near(x[1], a1/2):
y[0] = x[0] - a1
y[1] = x[1] - a1
y[2] = x[2]
#### right maps to left: left/right is defined as the x-direction
elif near(x[0], a1/2):
y[0] = x[0] - a1
y[1] = x[1]
y[2] = x[2]
### back maps to front: front/back is defined as the y-direction
elif near(x[1], a1/2):
y[0] = x[0]
y[1] = x[1] - a1
y[2] = x[2]
#### top maps to bottom: top/bottom is defined as the z-direction
elif near(x[2], a1/2):
y[0] = x[0]
y[1] = x[1]
y[2] = x[2] - a1
Ve = VectorElement("CG", mesh.ufl_cell(), 1,dim=3)
Re = VectorElement("R", mesh.ufl_cell(), 0,dim=3)
W = FunctionSpace(mesh, MixedElement([Ve, Re]), constrained_domain=PeriodicBoundary())
I am getting the following error
/tmp/ipykernel_166/3967937147.py in <module>
1 Ve = VectorElement("CG", mesh.ufl_cell(), 1,dim=3)
2 Re = VectorElement("R", mesh.ufl_cell(), 0,dim=3)
----> 3 W = FunctionSpace(mesh, MixedElement([Ve, Re]), constrained_domain=PeriodicBoundary())
/usr/lib/petsc/lib/python3/dist-packages/dolfin/function/functionspace.py in __init__(self, *args, **kwargs)
29 pass
30 elif len(args) == 2:
---> 31 self._init_from_ufl(*args, **kwargs)
32 else:
33 self._init_convenience(*args, **kwargs)
/usr/lib/petsc/lib/python3/dist-packages/dolfin/function/functionspace.py in _init_from_ufl(self, mesh, element, constrained_domain)
50 dolfin_dofmap = cpp.fem.DofMap(ufc_dofmap, mesh)
51 else:
---> 52 dolfin_dofmap = cpp.fem.DofMap(ufc_dofmap, mesh,
53 constrained_domain)
54
RuntimeError:
*** Error: Unable to periodic boundary mapping.
*** Reason: Need to set coordinate 0 in sub_domain.map.
*** Where: This error was encountered inside PeriodicBoundaryComputation.cpp.
*** Process: 0
*** Git changeset: unknown
The error,I guess, is due to the MixedElement in the FunctionSpace. When I changed my FunctionSpace to
V = FunctionSpace(mesh, 'Lagrange', 3, constrained_domain=PeriodicBoundary())
I got no error. In the example of periodic homogenizationof FEniCS, there was no error in using MixedElement. I have only changed the 2D terms to 3D using the following resources.
Can you help me to remove this error?
Any help is appreciated.
