OK thanks! I am trying now.
from dolfinx.cpp.mesh import CellType
from dolfinx.io import (XDMFFile, extract_gmsh_geometry,
extract_gmsh_topology_and_markers, ufl_mesh_from_gmsh)
from dolfinx.fem import (Constant, DirichletBC, Function, FunctionSpace, apply_lifting, assemble_matrix,
assemble_scalar, assemble_vector, create_vector, locate_dofs_topological, set_bc)
from ufl import (FacetNormal, FiniteElement, Identity, Measure, TestFunction, TrialFunction, VectorElement,
as_vector, div, dot, ds, dx, inner, lhs, grad, nabla_grad, rhs, sym)
print(f"DOLFINx version: {dolfinx.__version__} is installed")
filename="small-mesh.xdmf"
with dolfinx.io.XDMFFile(MPI.COMM_WORLD, "Small-Mesh-With-Naming.xdmf", "r") as xdmf:
#### local mesh ####
## mesh = UnitCubeMesh(MPI.COMM_WORLD, 10, 10, 10)
t = 0.000000
T = 1 #8 # Final time
dt = 1/1600 # Time step size
num_steps = int(T/dt)
k = Constant(mesh, dt)
mu = Constant(mesh, 0.001) # Dynamic viscosity
rho = Constant(mesh, 1) # Density
import dolfinx.fem as fem
V = fem.VectorFunctionSpace(mesh, ("CG", 2))
Q = fem.FunctionSpace(mesh, ("CG", 1))
eps=1e-14
def Inflow(x):
return np.abs(x[0] - 0.) < eps
def Outflow(x):
return np.abs(x[0] - 1.5) < eps
def Walls(x):
result = np.logical_or(np.abs(x[1] + 0.) < eps, np.abs(x[1] - 1.) < eps)
result2 = np.logical_or(np.abs(x[2] - 0.) < eps, np.abs(x[2] - 1.) < eps)
return np.logical_or(result, result2)
def Sphere(x):
result = np.logical_and(x[0] > .45 - eps, x[0] < .55 + eps)
result2 = np.logical_and(x[1] > .45 - eps, x[1] < .55 + eps)
result3 = np.logical_and(x[2] > .45 - eps, x[2] < .55 + eps)
return np.logical_and(np.logical_and(result, result2), result3)
def inflow_profile(x):
values = np.zeros(x.shape)
values[0,:]=1
return values
u_in = fem.Function(V)
u_in.interpolate(inflow_profile)
u_zero = fem.Function(V)
u_zero.x.array[:] = 0
p_zero = fem.Function(Q)
p_zero.x.array[:] = 0
inflow_boundary_dofs = fem.locate_dofs_geometrical(V, Inflow)
outflow_boundary_dofs = fem.locate_dofs_geometrical(Q, Outflow)
walls_boundary_dofs = fem.locate_dofs_geometrical(V, Walls)
facets = dolfinx.mesh.locate_entities_boundary(
mesh, mesh.topology.dim-1, Sphere)
mt = dolfinx.mesh.MeshTags(mesh, mesh.topology.dim-1,
facets, np.full(len(facets), 1, dtype=np.int32))
with dolfinx.io.XDMFFile(MPI.COMM_WORLD, "mt.xdmf", "w") as xdmf:
xdmf.write_mesh(mesh)
xdmf.write_meshtags(mt)
#sphere_boundary_dofs = fem.locate_dofs_geometrical(V, Sphere)
sphere_boundary_dofs = fem.locate_dofs_topological(
V, mesh.topology.dim-1, facets)
bcu_inflow = fem.DirichletBC(u_in, inflow_boundary_dofs)
bcp_outflow = fem.DirichletBC(p_zero, outflow_boundary_dofs)
bcu_walls = fem.DirichletBC(u_zero, walls_boundary_dofs)
bcu_sphere = fem.DirichletBC(u_zero, sphere_boundary_dofs)
bcu = [bcu_inflow, bcu_walls, bcu_sphere]
bcp = [bcp_outflow]
p = TrialFunction(Q)
q = TestFunction(Q)
# Define functions for solutions at previous and current time steps
u_n = Function(V)
u_ = Function(V)
p_n = Function(Q)
p_ = Function(Q)
U = 0.5 * (u_n + u)
f = Constant(mesh, PETSc.ScalarType((0,0,0)))
mu = Constant(mesh, PETSc.ScalarType(.001))
rho = Constant(mesh, PETSc.ScalarType(1))
# Define symmetric gradient
return sym(nabla_grad(u))
# Define stress tensor
def sigma(u, p):
return 2 * mu * epsilon(u) - p * Identity(len(u))
# Define variational problem for step 1
F1 = rho * dot((u - u_n) / k, v) * dx \
+ rho * dot(dot(u_n, nabla_grad(u_n)), v) * dx \
+ inner(sigma(U, p_n), epsilon(v)) * dx \
+ dot(p_n * n, v) * ds - dot(mu * nabla_grad(U) * n, v) * ds \
- dot(f, v) * dx
a1 = lhs(F1)
L1 = rhs(F1)
a2 = dot(nabla_grad(p), nabla_grad(q)) * dx
L2 = dot(nabla_grad(p_n), nabla_grad(q)) * dx - (1 / k) * div(u_) * q * dx
a3 = dot(u, v) * dx
L3 = dot(u_, v) * dx - k * dot(nabla_grad(p_ - p_n), v) * dx
# Assemble matrices
#A1 = assemble(a1)
#A2 = assemble(a2)
#A3 = assemble(a3)
A1 = assemble_matrix(a1, bcs=bcu)
A1.assemble()
b1 = create_vector(L1)
A2.assemble()
b2 = create_vector(L2)
A3 = assemble_matrix(a3)
A3.assemble()
b3 = create_vector(L3)
# Solver for step 1
solver1 = PETSc.KSP().create(MPI.COMM_WORLD)
solver1.setOperators(A1)
pc1 = solver1.getPC()
pc1.setType(PETSc.PC.Type.JACOBI)
# Solver for step 2
solver2 = PETSc.KSP().create(MPI.COMM_WORLD)
solver2.setOperators(A2)
solver2.setType(PETSc.KSP.Type.MINRES)
pc2 = solver2.getPC()
pc2.setHYPREType("boomeramg")
# Solver for step 3
solver3 = PETSc.KSP().create(MPI.COMM_WORLD)
solver3.setOperators(A3)
pc3 = solver3.getPC()
import dolfinx.io
xdmf = dolfinx.io.XDMFFile(MPI.COMM_WORLD, "solution-1.xdmf", "w")
xdmf.write_function(u_n, t)
xdmf.write_function(p_n, t)
for i in range(num_steps):
# Update current time step
# Step 1: Tentative veolcity step
with b1.localForm() as loc_1:
loc_1.set(0)
assemble_vector(b1, L1)
set_bc(b1, bcu)
solver1.solve(b1, u_.vector)
u_.x.scatter_forward()
# Step 2: Pressure corrrection step
with b2.localForm() as loc_2:
loc_2.set(0)
assemble_vector(b2, L2)
set_bc(b2, bcp)
solver2.solve(b2, p_.vector)
p_.x.scatter_forward()
with b3.localForm() as loc_3:
loc_3.set(0)
assemble_vector(b3, L3)
solver3.solve(b3, u_.vector)
u_n.x.array[:] = u_.x.array[:]
p_n.x.array[:] = p_.x.array[:]
# Write solutions to file
# Close xmdf file
xdmf.close()
and I am getting the following error:
DOLFINx version: 0.3.1.0 is installed
#003: H5Fint.c line 2165 in H5F__close_cb(): can't close file, there are objects still open
major: File accessibility
minor: Unable to close file
File "sphere-1.py", line 78, in <module>
RuntimeError: Failed to write HDF5 local dataset into hyperslab.
Could you please tell me what causes this error?
