Hele-Shaw flow past a circle in dolfinx
I was trying to learn to simulate in fenicsx the Hele-Shaw flow past a circle based on a tutorial — Fig 1. Hele-Shaw flow past a circle · An album of computational fluid motion. But the tutorial uses older package dolfin, I am trying to recreate in dolfinx (fenicx) but getting error, and unable to understand the reason of error.
from dolfinx import fem, io, mesh, plot, cpp
from dolfinx.io import (VTXWriter, distribute_entity_data, gmshio)
# Physical parameters
D = 1.0  # Circle diameter
L = 6.0  # Channel length
Ht = 3.0  # Channel height
Hb = 3.0  # Channel height
U_in = 1.0  # Inlet velocity
# Numerical parameters
resolution = 0.05  # Target characteristic length factor
EPS = np.finfo(float).eps  # Machine epsilon for float
mesh_comm = MPI.COMM_WORLD
model_rank = 0
mesh_dim=2
# Create gmsh geometry
# gmsh.model.occ.add("Channel with circle")
# Create channel
rectangle = gmsh.model.occ.addRectangle(-L/2, -Hb, 0, L, Ht + Hb)
# Create circle
circle = gmsh.model.occ.addDisk(0, 0, 0, D/2,D/2)
gmsh.model.occ.cut([(2, rectangle)], [(2, circle)])
gmsh.model.occ.synchronize()
# Set mesh resolution
gmsh.option.setNumber("Mesh.CharacteristicLengthFactor", resolution)
gmsh.option.setNumber("Mesh.Algorithm", 6)
gmsh.model.mesh.generate(mesh_dim)
# Convert gmsh mesh to dolfinx mesh
mesh_obj, a, b = dolfinx.io.gmshio.model_to_mesh(gmsh.model, mesh_comm, model_rank, gdim=2)
# mesh_obj = dolfinx.mesh.create_mesh(gmsh.model.getMesh(False, False, dolfinx.io.gmsh_codim(gmsh.model.getDimension())))
gmsh.finalize()
gmsh.write("mesh2.msh")
# Create finite element spaces
BDM = ufl.VectorElement("Lagrange", mesh_obj.ufl_cell(), 1)
DG = ufl.FiniteElement("Discontinuous Lagrange", mesh_obj.ufl_cell(), 0)
V = fem.FunctionSpace(mesh_obj, BDM * DG)
# Define test, trial and solution function
u, p = ufl.TrialFunctions(V)
v, q = ufl.TestFunctions(V)
u_sol = fem.Function(V)
I am getting error with mesh_obj, a, b = dolfinx.io.gmshio.model_to_mesh(gmsh.model, mesh_comm, model_rank, gdim=2). Can anyone please help?
Next time it would be useful if you post the whole error message:
  File "/root/shared/mwe123.py", line 49, in <module>
  File "/usr/local/dolfinx-real/lib/python3.10/dist-packages/dolfinx/io/gmshio.py", line 232, in model_to_mesh
    cell_id = cell_information[perm_sort[-1]]["id"]
IndexError: index -1 is out of bounds for axis 0 with size 0
You can search for the IndexError on the forum to find
which all points you to the fact that you need to add physical groups to your mesh in GMSH to be able to read it with gmshio.model_to_mesh
https://docs.fenicsproject.org/dolfinx/v0.7.3/python/generated/dolfinx.io.gmshio.html?highlight=model_to_mesh#dolfinx.io.gmshio.model_to_mesh
Thanks. I will try your suggestions, and update in the forum. So once a mesh is created,
I need to add a physical group to it before calling
Yes (and do not call syncronize after adding the groups, as it tends to mess them up).
Thanks, @dokken . Adding the physics group actually worked. I am stuck at the last few steps, which I tried to resolve but could not understand how to proceed.
D = 1
Ht = 1.62 # height till top
Hb = 1.9 # height till bottom
L = 6
H = Ht+Hb
c_x = L/2
c_y = Hb
r = D/2
model_rank = 0
mesh_dim=2
# Create channel
rectangle = gmsh.model.occ.addRectangle(0, 0, 0, L, H)
# Create circle
circle = gmsh.model.occ.addDisk(c_x, c_y, 0, r, r)
# gmsh.model.occ.synchronize()
fluid_marker = 1
volumes = gmsh.model.getEntities(dim=mesh_dim)
gmsh.model.addPhysicalGroup(volumes[0][0], [volumes[0][1]], fluid_marker)
gmsh.model.setPhysicalName(volumes[0][0], fluid_marker, "Fluid")
gmsh.option.setNumber("Mesh.RecombinationAlgorithm", 2)
gmsh.option.setNumber("Mesh.RecombineAll", 1)
gmsh.option.setNumber("Mesh.SubdivisionAlgorithm", 1)
gmsh.model.mesh.generate(2)
gmsh.model.mesh.setOrder(2)
# gmsh.finalize()
BDM = ufl.FiniteElement("Lagrange", mesh_obj.ufl_cell(), 1)
V = fem.FunctionSpace(mesh_obj, BDM*DG)
# Define boundary conditions
def boundary_noflow(x):
    return x[1] < -Hb+EPS or x[1] > Ht - EPS \
        or x[0]**2+x[1]**2 < (D/2)**2+EPS
def boundary_inflow(x):
    return x[0] < -L/2+EPS
bcs = [fem.dirichletbc(V.sub(0), fem.Constant((0.0, 0.0)), boundary_noflow), \
       fem.dirichletbc(V.sub(0), fem.Constant((1.0, 0.0)), boundary_inflow),]
# Weak formulation
a = (ufl.dot(u, v) + ufl.div(v) * p + ufl.div(u) * q) * ufl.dx
Lrhs = - fem.Constant(0) * q * ufl.dx
# Solve and export
solve(a == Lrhs, u_sol, bcs)
(u,p) = u_sol.split()
u.rename('u','u')
File("sol.pvd") << u
This is the code. From
# Weak formulation
# Solve and export
u.rename('u','u')
This section of code I have issue with. I am following old code as provided -
Fig 1. Hele-Shaw flow past a circle · An album of computational fluid motion. I am getting error bcs and Lrhs. The solve function too I don’t undertand.
  Cell In[7], line 1
TypeError: Constant.__init__() missing 1 required positional argument: 'c'
< minor highjack of thread >
Funny I should see this. Do you think you could update the code on the website once you have the fenicsx version running? That would be valuable for future readers.
Maybe the best approach would be to add your codeblock underneath mine. The website is opensource (using typical git workflow of forking, editing, merge-requesting). You can find the .md file on: content/chapters/01-creeping/Fig1/index.md · main · Stein Stoter / album-of-computational-fluid-motion · GitLab.
< /minor highjack of thread >
Yes, Definitely. That’s a good learning exercise for me too.
I would advice you to have a look at the API of DOLFINx:
dolfinx.fem — DOLFINx 0.7.3 documentation which states that you first need to send in the mesh, ie mesh_obj.
Secondly, for the solve command, see any of the demos or the DOLFINx tutorial for the updated API
D = 1
L = 6
H = Ht+Hb
c_x = 0
c_y = 0
r = D/2
model_rank = 0
mesh_dim=2
# Create channel
rectangle = gmsh.model.occ.addRectangle(-L/2, -Hb, 0, L, H)
# Create circle
fluid_marker = 1
gmsh.option.setNumber("Mesh.Algorithm", 8)
# gmsh.option.setNumber("Mesh.RecombinationAlgorithm", 1)
# gmsh.option.setNumber("Mesh.RecombineAll", 1)
# gmsh.option.setNumber("Mesh.SubdivisionAlgorithm", 1)
# gmsh.model.mesh.setOrder(2)
# gmsh.write("mesh2.msh")
mesh_obj, _, _ = dolfinx.io.gmshio.model_to_mesh(gmsh.model, mesh_comm, model_rank, gdim=2)
gmsh.finalize()
BDM = ufl.FiniteElement("BDM", mesh_obj.ufl_cell(), 1)
DG  = ufl.FiniteElement("DG", mesh_obj.ufl_cell(), 0)
# V = fem.FunctionSpace(mesh_obj, BDM)
# Q = fem.FunctionSpace(mesh_obj, DG)
    return np.logical_or(x[1] < -Hb+EPS, x[1] > Ht-EPS, x[0]**2 + x[1]**2 < (D/2)**2 + EPS)
    return np.isclose(x[0], -L/2)
fdim = mesh_obj.topology.dim - 1
V1, _ = V.sub(0).collapse()
u_D = fem.Function(V1)
u_D.x.array[:] =1
facets_noflow = mesh.locate_entities_boundary(mesh_obj, fdim, boundary_noflow)
bc_noflow = fem.dirichletbc(u_D, fem.locate_dofs_topological((V.sub(0), V1), 1, facets_noflow), V.sub(0))
facets_inflow = mesh.locate_entities_boundary(mesh_obj, 1, boundary_inflow)
bc_inflow = fem.dirichletbc(u_D, fem.locate_dofs_topological((V.sub(0), V1), 1, facets_inflow), V.sub(0))
# inflow_dofs = fem.locate_dofs_geometrical(V, boundary_inflow)
# bc_inflow = fem.dirichletbc(PETSc.ScalarType((1, 0)), inflow_dofs)
# Weak formulation
Lrhs = - fem.Constant(mesh_obj, PETSc.ScalarType(0)) * q * ufl.dx
# Solve and export
problem_loc = LinearProblem(a, Lrhs,  [bc_noflow, bc_inflow],u_sol)
# uh = problem_loc.solve()
# u_sol.interpolate(uh)
with io.XDMFFile(mesh_obj.comm, "Out_Hele_Shaw_flow/Hele-Shaw-flow.xdmf", "w") as file:
    file.write_mesh(mesh_obj)
    file.write_function(u, 0)
This is the final code, but some error is coming, which I am unable to correct.
  File /usr/lib/petsc/lib/python3/dist-packages/dolfinx/io/utils.py:235 in write_function
    super().write_function(getattr(u, "_cpp_object", u), t, mesh_xpath)
RuntimeError: Only Lagrange functions are supported. Interpolate Functions before output.
See Interpolating Functions on higher order elements - #2 by dokken
The problem is mostly solved. I am able to export uh_p, but I am having issue exporting the velocity field, uh_u. It would be greatly appreciated if anyone could help with export.
D = 1
L = 6
H = Ht+Hb
c_x = 0
c_y = 0
r = D/2
model_rank = 0
mesh_dim=2
# Create channel
# Create circle
fluid_marker = 1
gmsh.finalize()
# with io.XDMFFile(MPI.COMM_WORLD, "problem_interval_mesh.xdmf", "w") as xdmf:
#       xdmf.write_mesh(mesh_obj)
# Define test, trial and solution functshoes that fits feet designion
(u, p) = ufl.TrialFunctions(V)
(v, q) = ufl.TestFunctions(V)
    return np.logical_or(np.isclose(x[1], -Hb+EPS), np.isclose(x[1], Ht-EPS), np.isclose(x[0]**2 + x[1]**2, r**2 + EPS))
V0 = V.sub(0)
Q, _ = V0.collapse()
# Noflow
dofs_noflow = fem.locate_dofs_topological((V0, Q), fdim, facets_noflow)
def f1(x):
    values = np.zeros((2, x.shape[1]))
    return values
f_h1 = fem.Function(Q)
f_h1.interpolate(f1)
bc_noflow = fem.dirichletbc(f_h1, dofs_noflow, V0)
#Inflow
facets_inflow = mesh.locate_entities_boundary(mesh_obj, fdim, boundary_inflow)
dofs_inflow = fem.locate_dofs_topological((V0, Q), fdim, facets_inflow)
def f2(x):
    values[0, :] = 1
    return values
f_h2 = fem.Function(Q)
f_h2.interpolate(f2)
bc_inflow = fem.dirichletbc(f_h2, dofs_inflow, V0)
bcs = [bc_noflow, bc_inflow]
# Weak formulation
a = (ufl.inner(u, v) + ufl.div(v) * p + ufl.div(u) * q) * ufl.dx
# Lrhs = - fem.Constant(mesh_obj, PETSc.ScalarType(0)) * q * ufl.dx
# Solve and export
# problem_loc = LinearProblem(a, Lrhs,  bcs)
# uh_u, uh_p = uh.split()
# u, p = u_sol.split()
# u.interpolate(uh_u)
# p.interpolate(uh_p)
# problem = LinearProblem(
#     a,
#     Lrhs,
#     bcs=bcs,
#     petsc_options={"ksp_type": "preonly", "pc_type": "lu", "pc_factor_mat_solver_type": "mumps"},
# try:
#     uh = problem.solve()
# except PETSc.Error as e:  # type: ignore
#     if e.ierr == 92:
#         print("The required PETSc solver/preconditioner is not available. Exiting.")
#         print(e)
#         exit(0)
#     else:
#         raise e
# W0_DG = fem.FunctionSpace(mesh_obj, ("BDM", 1))
# sigma_DG = fem.Function(W0_DG)
# sigma_DG.interpolate(uh_u)
# uh_u_expr = fem.Expression(uh_u, V1.element.interpolation_points())
# u.interpolate(uh_u_expr)
# u.x.scatter_forward()
# from pathlib import Path
# name = "DFG_navier_stokes"
# folder = Path("results")
# with io.VTXWriter(mesh_obj.comm, folder / f"{name}_velocity_final.bp", uh_p,  engine="BP4") as f:
#     f.write(0)
with io.XDMFFile(mesh_obj.comm, "out_mixed_poisson/u.xdmf", "w") as file:
    file.write_function(uh_p)
# with dolfinx.io.VTXWriter(mesh_obj.comm, "moisture_solution1D.bp", uh_u, engine="BP4") as vtx:
#     vtx.write(0.0)
Reference:
[1] Mixed formulation for the Poisson equation - DOLFINx Tutorial
You are not mentioning what issue you are having.
You need to interpolate uh_u in to a suitable Lagrange (or DG) space for visualization in paraview with VTXWriter.
Suppose If I run for uh_u to XDMFFILE
    file.write_function(uh_u)
I am getting this error
 Cell In[2], line 3
As I said, you need to interpolate uh_u into a suitable (discontinuous) Lagrange space.
For XDMFFile this means a first order Lagrange space if the geometry is linear.
For VTXWriter you can use an arbitrary order (discontinuous) Lagrange space for visualization.
Thanks @dokken. @Stein
I suppose you are asking for this
gdim = mesh_obj.geometry.dim
V1 = fem.functionspace(mesh_obj, ("Discontinuous Lagrange", 1, (gdim,)))
u1 = fem.Function(V1, dtype=default_scalar_type)
u1.interpolate(uh_u)
Complete code:
from dolfinx import default_scalar_type, plot
D = 1
L = 6
H = Ht+Hb
c_x = 0
c_y = 0
r = D/2
model_rank = 0
mesh_dim=2
# Create channel
# Create circle
fluid_marker = 1
gmsh.finalize()
V0 = V.sub(0)
# Noflow
def f1(x):
    return values
#Inflow
def f2(x):
    values[0, :] = 1
    return values
# Weak formulation
# Solve and export
#     a,
#     Lrhs,
#     bcs=bcs,
# try:
#     if e.ierr == 92:
#         print(e)
#         exit(0)
#     else:
#         raise e
# uh_u.interpolate(sigma_DG)
#     f.write(0)
# with io.XDMFFile(mesh_obj.comm, "out_mixed_poisson/u.xdmf", "w") as file:
#     file.write_mesh(mesh_obj)
#     file.write_function(uh_u)
with dolfinx.io.VTXWriter(mesh_obj.comm, "moisture_solution1D.bp", u1, engine="BP4") as vtx:
    vtx.write(0.0)
I have to check the values though for the correctness.
Hey everyone, the values seems correct, but the velocity profile seems different from what is shown here Fig 1. Hele-Shaw flow past a circle · An album of computational fluid motion. I tried but somehow not able to correct it. Any help?
Could you be more specific? How does the velocity profile differ?
Could you add side by side plots?
Secondly, your latest post is 6 months ago, are you running the exact same script as in your previous post, or a modified version?
Yes, the script is similar.
from ufl import Measure, SpatialCoordinate, TestFunctions, TrialFunctions, div, exp, inner
from dolfinx.fem import (functionspace, dirichletbc)
from dolfinx.io import (VTXWriter, distribute_entity_data, gmshio, XDMFFile)
D = 1
L = 6
H = Ht+Hb
c_x = 0
c_y = 0
r = D/2
resolution = 0.1  # Target characteristic length factor #0.05
# EPS = np.finfo(float).eps  # Machine epsilon for float
model_rank = 0
gdim=2
# Create channel
# Create circle
obstacle = gmsh.model.occ.addDisk(c_x, c_y, 0, r, r)
gmsh.model.occ.cut([(gdim, rectangle)], [(gdim, obstacle)])
# # Set mesh resolution
# gmsh.option.setNumber("Mesh.RecombinationAlgorithm", 2)
# # gmsh.fltk().run()
# Add physical tag for bulk
fluid_marker = 1
    assert (len(volumes) == 1)
# # Add physical tag for boundaries
# boundary = gmsh.model.getBoundary(
#     [(2, surface)], combined=False, oriented=False, recursive=False)
# for i, (boundary) in enumerate(boundary):
#     gmsh.model.addPhysicalGroup(boundary[0], [boundary[1]], i)
# # Convert gmsh mesh to dolfinx mesh
mesh_obj, _, _ = gmshio.model_to_mesh(gmsh.model, mesh_comm, model_rank, gdim=gdim)
gmsh.finalize()
# Function spaces for the velocity and for the pressure
k = 1
Q_el = element("BDM", mesh_obj.basix_cell(), k)
P_el = element("DG", mesh_obj.basix_cell(), k - 1)
V_el = mixed_element([Q_el, P_el])
V = functionspace(mesh_obj, V_el)
# Get subspace of V
V0 = V.sub(0)
# u = TrialFunctions(V)
# v = TestFunctions(V)
# p = TrialFunctions(V)
# q = TestFunctions(V)
    return np.logical_or(np.isclose(x[1], -Hb), np.isclose(x[1], Ht), np.isclose(x[0]**2 + x[1]**2, r**2))
# Walls
# u_noflow = np.array((0,) * mesh_obj.geometry.dim, dtype=PETSc.ScalarType)
# bc_noflow = dirichletbc(u_noflow, dofs_noflow, V0)
# Define a function for the inflow velocity on the full vector space V
u_noflow_func = fem.Function(Q)
# Define a function to set the inflow profile
def noflow_profile(x):
    values = np.zeros((mesh_obj.geometry.dim, x.shape[1]))
    values[0, :] = 0.0  # Set x-component of the velocity
    return values
# Interpolate the inflow profile into the function
u_noflow_func.interpolate(noflow_profile)
# Apply the Dirichlet BC using the function
bc_noflow = fem.dirichletbc(u_noflow_func, dofs_noflow, V0)
# # InFlow
# u_inflow = np.array((1,) * mesh_obj.geometry.dim, dtype=PETSc.ScalarType)
# bc_inflow = fem.dirichletbc(u_inflow, dofs_inflow, V0)
u_inflow_func = fem.Function(Q)
def inflow_profile(x):
    values[0, :] = 1.0  # Set x-component of the velocity
    return values
u_inflow_func.interpolate(inflow_profile)
bc_inflow = fem.dirichletbc(u_inflow_func, dofs_inflow, V0)
#Defining the variational problem
f = - fem.Constant(mesh_obj, PETSc.ScalarType(0))
# Define the bilinear form correctly
a = (ufl.inner(u, v) + ufl.div(v)*p + ufl.div(u)*q) * ufl.dx
L = -f*q*ufl.dx
#solving the equation
    a,
    L,
    bcs=bcs,
try:
    w_h = problem.solve()
    if e.ierr == 92:
        print(e)
        exit(0)
        raise e
sigma_h, u_h = w_h.split()
    file.write_function(u_h)
# Different way 2
V1 = fem.functionspace(mesh_obj, ("Lagrange", 2, (gdim,)))
u1.interpolate(sigma_h)
with dolfinx.io.VTXWriter(mesh_obj.comm, "album1.bp", u1, engine="BP4") as vtx:
    vtx.write(0.0)
And this is the distribution profile for velocity reported by Fig 1. Hele-Shaw flow past a circle · An album of computational fluid motion
As you can see, my velocity profile reported previously is different.
I don’t understand the reason of this discrepancy.
You can check that the facets on your circular boundary has not been found:
facet_func = dolfinx.mesh.meshtags(mesh_obj, fdim, facets_noflow, np.full_like(facets_noflow, 2, dtype=np.int32))
with dolfinx.io.XDMFFile(mesh_obj.comm, "out_mixed_poisson/mesh.xdmf", "w") as file:
    file.write_meshtags(facet_func, mesh_obj.geometry)
thus you are not applying the correct condition there.
This is due to your usage of:
Which is incorrect, as you can only send in two arguments to logical_or: numpy.logical_or — NumPy v2.0 Manual
You should use:
    walls = np.logical_or(np.isclose(x[1], -Hb), np.isclose(x[1], Ht))
    obstacle = np.isclose((x[0]-c_x)**2 + (x[1]-c_y)**2, r**2)
    return np.logical_or(walls, obstacle)
which yields:
Thanks a lot for the help :pray:. I will go through it.
