Hello everyone, I am using the code below to extract the coordinates on the circumference (facet_coordinates
) and the indices (boundary_vertices
). However, I encountered a very strange error during sorting: my expected result is that the x coordinates are in ascending order (this requirement can be fulfilled); if the x coordinates are the same, the y coordinates should be in ascending order (but the result I got for this requirement was descending order for the y coordinates). However, when I print facet_coordinates
and define it directly, I get the correct result. I have not been able to find the reason behind this issue and hope to receive some help.
# Obtain the vertex coordinates and indices on the circumference, and then sort them.
import joblib
from dolfinx.io import gmshio
# obtain coordinates on boundary
mesh, cell_markers, facet_markers = gmshio.read_from_msh("m.msh", MPI.COMM_WORLD, gdim=2)
facets = facet_markers.find(14)
send_coordinates = []
# Calculate all the coordinates
coordinates = mesh.geometry.x
# Obtain the indices of the boundary vertices
boundary_vertices = dolfinx.mesh.compute_incident_entities(mesh.topology, facets, mesh.topology.dim-1, 0)
for vertex in boundary_vertices:
send_coordinates.append(coordinates[vertex])
# Convert the list of coordinates to array
facet_coordinates = np.asarray(send_coordinates).reshape(-1, coordinates.shape[1])
# Sort by x coordinates, and if the x coordinates are the same, sort by y coordinates
sort_idx = np.lexsort((facet_coordinates[:, 1], facet_coordinates[:, 0]))
# Reorder using the sorted position indices
sorted_i = [boundary_vertices[i] for i in sort_idx]
sorted_coordinates = facet_coordinates[sort_idx]
# print results
for (index, coord) in zip(sorted_i, sorted_coordinates):
print(index, coord)
The incorrect result is as follows (y coordinates in descending order):
132 [-7.12500000e+00 -1.49481173e-14 0.00000000e+00]
123 [-6.77627768 2.20174608 0. ]
169 [-6.77627768 -2.20174608 0. ]
105 [-5.76424608 4.18796992 0. ]
179 [-5.76424608 -4.18796992 0. ]
133 [-4.18796992 5.76424608 0. ]
312 [-4.18796992 -5.76424608 0. ]
145 [-2.20174608 6.77627768 0. ]
343 [-2.20174608 -6.77627768 0. ]
197 [-1.06381942e-14 7.12500000e+00 0.00000000e+00]
462 [-7.63711251e-15 -7.12500000e+00 0.00000000e+00]
213 [2.20174608 6.77627768 0. ]
486 [ 2.20174608 -6.77627768 0. ]
389 [4.18796992 5.76424608 0. ]
702 [ 4.18796992 -5.76424608 0. ]
407 [5.76424608 4.18796992 0. ]
728 [ 5.76424608 -4.18796992 0. ]
503 [6.77627768 2.20174608 0. ]
712 [ 6.77627768 -2.20174608 0. ]
532 [7.125 0. 0. ]
Print facet_coordinates
and redefine it:
# Print facet_coordinates and redefine it
print(facet_coordinates)
facet_coordinates = np.array([
[-5.76424608e+00, 4.18796992e+00, 0.00000000e+00],
[-6.77627768e+00, 2.20174608e+00, 0.00000000e+00],
[-7.12500000e+00, -1.49481173e-14, 0.00000000e+00],
[-4.18796992e+00, 5.76424608e+00, 0.00000000e+00],
[-2.20174608e+00, 6.77627768e+00, 0.00000000e+00],
[-6.77627768e+00, -2.20174608e+00, 0.00000000e+00],
[-5.76424608e+00, -4.18796992e+00, 0.00000000e+00],
[-1.06381942e-14, 7.12500000e+00, 0.00000000e+00],
[ 2.20174608e+00, 6.77627768e+00, 0.00000000e+00],
[-4.18796992e+00, -5.76424608e+00, 0.00000000e+00],
[-2.20174608e+00, -6.77627768e+00, 0.00000000e+00],
[ 4.18796992e+00, 5.76424608e+00, 0.00000000e+00],
[ 5.76424608e+00, 4.18796992e+00, 0.00000000e+00],
[-7.63711251e-15, -7.12500000e+00, 0.00000000e+00],
[ 2.20174608e+00, -6.77627768e+00, 0.00000000e+00],
[ 6.77627768e+00, 2.20174608e+00, 0.00000000e+00],
[ 7.12500000e+00, 0.00000000e+00, 0.00000000e+00],
[ 4.18796992e+00, -5.76424608e+00, 0.00000000e+00],
[ 6.77627768e+00, -2.20174608e+00, 0.00000000e+00],
[ 5.76424608e+00, -4.18796992e+00, 0.00000000e+00]
# print results
print(index, coord)
Obtained the correct result:
532 [7.125 0. 0. ]
This is just a set of coordinate data, and I am confident that it has nothing to do with the grid.
