Dear groups,
Hi I’m working on applying the adaptive mesh generation to solve phasefield method. To handle this, what I need is the adaptive mesh generation.
To solve this problem, I have looked at several posts.
But this refine method only for dividing meshes not for coarsening and only with refining, the number of elements be calculated only increases in the case of transient state.
Thus I want to use the “AdaptiveLinearVariationalSolver” which is implemented in FEniCS to adjust the number of elements.
I just want to follow the following example and I got this error message. ( 1. Auto adaptive Poisson equation — FEniCS Project
*** Error: Unable to perform operation in parallel.
*** Reason: Extrapolation of functions is not yet working in parallel.
*** Consider filing a bug report at https://bitbucket.org/fenics-project/dolfin/issues.
*** Where: This error was encountered inside log.cpp.
*** Process: 34
*** DOLFIN version: 2019.1.0
*** Git changeset: 74d7efe1e84d65e9433fd96c50f1d278fa3e3f3f
Can you give me a help? I also found that there was the same problem with me, but I have no idea what I have to do… (fenics.AdaptiveNonlinearVariationalSolver doesn't work in parallel · Issue #48 · geo-fluid-dynamics/phaseflow-fenics · GitHub)
Do I have to update my dolfin? It is 2019.1.0.
Thanks in advance.
