Dear all,
Hi, I am recently looking at ADIOS4DOLFINx to write a field out into a file and then read it with another script. However, when I install it with dolfinx 0.9.0 instead of 0.8.0, it seems that it will make pyvista not working (not showing interactive view with show()). However, everything is fine with 0.8.0. Does anyone know the solution to this?
dokken
January 9, 2025, 7:21pm
2
Jujian_Zhang:
This can’t be an adios4dolfinx issue, as you are talking about how pyvista visualizes a pyvista unstructured grid.
Could you please specify how you are running dolfinx, and how you installed it?
Thanks for the quick response. I followed the installation on github page, which uses conda install -c conda-forge fenics-dolfinx mpich pyvista to install dolfinx on my Linux system. And then, I use conda install -c conda-forge adios4dolfinx to install adios4dolfinx.
dokken
January 9, 2025, 7:36pm
4
Thanks, no it doesn’t visualize anything. Here is the code I run with the corresponding environment:
from __future__ import annotations
import pyvista as pv
cyl = pv.Cylinder()
arrow = pv.Arrow()
sphere = pv.Sphere()
plane = pv.Plane()
line = pv.Line()
box = pv.Box()
cone = pv.Cone()
poly = pv.Polygon()
disc = pv.Disc()
p = pv.Plotter(shape=(3, 3))
# Top row
p.subplot(0, 0)
p.add_mesh(cyl, color='lightblue', show_edges=True)
p.subplot(0, 1)
p.add_mesh(arrow, color='lightblue', show_edges=True)
p.subplot(0, 2)
p.add_mesh(sphere, color='lightblue', show_edges=True)
# Middle row
p.subplot(1, 0)
p.add_mesh(plane, color='lightblue', show_edges=True)
p.subplot(1, 1)
p.add_mesh(line, color='lightblue', line_width=3)
p.subplot(1, 2)
p.add_mesh(box, color='lightblue', show_edges=True)
# Bottom row
p.subplot(2, 0)
p.add_mesh(cone, color='lightblue', show_edges=True)
p.subplot(2, 1)
p.add_mesh(poly, color='lightblue', show_edges=True)
p.subplot(2, 2)
p.add_mesh(disc, color='lightblue', show_edges=True)
# Render all of them
p.show()
No errors come out, but also no figures
One thing to add. The pyvista works well if I create a new environment and install dolfinx 0.9.0. It will bug only if I install the ADIOS4DOLFINx.
dokken
January 9, 2025, 8:40pm
7
That is very weird, as there is nothing in the adios4dolfinx conda build that should interfere with pyvista: adios4dolfinx-feedstock/recipe/meta.yaml at main · conda-forge/adios4dolfinx-feedstock · GitHub
Could you do conda env export of the env in question, as well as trying to set:
pyvista.OFF_SCREEN=False at the beginning of the script.
Sure, here is the output:
channels:
- conda-forge
- defaults
dependencies:
- _libgcc_mutex=0.1=conda_forge
- _openmp_mutex=4.5=2_kmp_llvm
- adios2=2.10.2=mpi_mpich_py313h17dafd0_1
- adios4dolfinx=0.9.1=pyh458ca06_0
- aiohappyeyeballs=2.4.4=pyhd8ed1ab_1
- aiohttp=3.11.11=py313h8060acc_0
- aiosignal=1.3.2=pyhd8ed1ab_0
- alsa-lib=1.2.13=hb9d3cd8_0
- aom=3.9.1=hac33072_0
- attr=2.5.1=h166bdaf_1
- attrs=24.3.0=pyh71513ae_0
- binutils_impl_linux-64=2.43=h4bf12b8_2
- binutils_linux-64=2.43=h4852527_2
- blas=1.0=openblas
- blosc=1.21.6=he440d0b_1
- brotli=1.1.0=hb9d3cd8_2
- brotli-bin=1.1.0=hb9d3cd8_2
- brotli-python=1.1.0=py313h46c70d0_2
- bzip2=1.0.8=h4bc722e_7
- c-ares=1.34.4=hb9d3cd8_0
- c-blosc2=2.15.2=h3122c55_1
- ca-certificates=2024.12.31=h06a4308_0
- cairo=1.18.2=h3394656_1
- certifi=2024.12.14=py313h06a4308_0
- cffi=1.17.1=py313hfab6e84_0
- charset-normalizer=3.4.1=pyhd8ed1ab_0
- contourpy=1.3.1=py313h33d0bda_0
- cycler=0.12.1=pyhd8ed1ab_1
- cyrus-sasl=2.1.27=h54b06d7_7
- dav1d=1.2.1=hd590300_0
- dbus=1.13.6=h5008d03_3
- double-conversion=3.3.0=h59595ed_0
- expat=2.6.4=h5888daf_0
- fenics-basix=0.9.0=py313h867a91d_2
- fenics-basix-nanobind-abi=0.2.1.13=h6c05e69_2
- fenics-dolfinx=0.9.0=py313h29c2d7e_106
- fenics-ffcx=0.9.0=pyh2e48890_0
- fenics-libbasix=0.9.0=h7cb7ce6_2
- fenics-libdolfinx=0.9.0=h9e81c43_106
- fenics-ufcx=0.9.0=hb7f7608_0
- fenics-ufl=2024.2.0=pyhd8ed1ab_1
- ffmpeg=7.1.0=gpl_h099772d_709
- fftw=3.3.10=mpi_mpich_hbcf76dd_10
- fmt=11.0.2=h434a139_0
- font-ttf-dejavu-sans-mono=2.37=hab24e00_0
- font-ttf-inconsolata=3.000=h77eed37_0
- font-ttf-source-code-pro=2.038=h77eed37_0
- font-ttf-ubuntu=0.83=h77eed37_3
- fontconfig=2.15.0=h7e30c49_1
- fonts-conda-ecosystem=1=0
- fonts-conda-forge=1=0
- fonttools=4.55.3=py313h8060acc_1
- freetype=2.12.1=h267a509_2
- fribidi=1.0.10=h36c2ea0_0
- frozenlist=1.5.0=py313h536fd9c_0
- gcc_impl_linux-64=13.3.0=hfea6d02_1
- gcc_linux-64=13.3.0=hc28eda2_7
- gdk-pixbuf=2.42.12=hb9ae30d_0
- gl2ps=1.4.2=hae5d5c5_1
- glew=2.1.0=h9c3ff4c_2
- gmp=6.3.0=hac33072_2
- graphite2=1.3.13=h59595ed_1003
- h2=4.1.0=pyhd8ed1ab_1
- harfbuzz=10.1.0=h0b3b770_0
- hdf4=4.2.15=h2a13503_7
- hdf5=1.14.4=mpi_mpich_h7f58efa_5
- hpack=4.0.0=pyhd8ed1ab_1
- hyperframe=6.0.1=pyhd8ed1ab_1
- hypre=2.32.0=mpi_mpich_h2e71eac_1
- icu=75.1=he02047a_0
- idna=3.10=pyhd8ed1ab_1
- jsoncpp=1.9.6=hf42df4d_1
- kahip=3.16=h2fbc463_4
- kernel-headers_linux-64=3.10.0=he073ed8_18
- keyutils=1.6.1=h166bdaf_0
- kiwisolver=1.4.7=py313h33d0bda_0
- krb5=1.21.3=h659f571_0
- lame=3.100=h166bdaf_1003
- lcms2=2.16=hb7c19ff_0
- ld_impl_linux-64=2.43=h712a8e2_2
- lerc=4.0.0=h27087fc_0
- level-zero=1.19.2=h84d6215_1
- libabseil=20240722.0=cxx17_hbbce691_4
- libadios2=2.10.2=mpi_mpich_h70f2d8c_1
- libaec=1.1.3=h59595ed_0
- libamd=3.3.3=ss783_h889e182
- libass=0.17.3=hba53ac1_1
- libblas=3.9.0=26_linux64_openblas
- libboost=1.86.0=h6c02f8c_3
- libboost-devel=1.86.0=h1a2810e_3
- libboost-headers=1.86.0=ha770c72_3
- libbrotlicommon=1.1.0=hb9d3cd8_2
- libbrotlidec=1.1.0=hb9d3cd8_2
- libbrotlienc=1.1.0=hb9d3cd8_2
- libbtf=2.3.2=ss783_h2377355
- libcamd=3.3.3=ss783_h2377355
- libcap=2.71=h39aace5_0
- libcblas=3.9.0=26_linux64_openblas
- libccolamd=3.3.4=ss783_h2377355
- libcholmod=5.3.0=ss783_h3fa60b6
- libclang-cpp19.1=19.1.6=default_hb5137d0_0
- libclang13=19.1.6=default_h9c6a7e4_0
- libcolamd=3.3.4=ss783_h2377355
- libcups=2.3.3=h4637d8d_4
- libcurl=8.11.1=h332b0f4_0
- libdeflate=1.23=h4ddbbb0_0
- libdrm=2.4.124=hb9d3cd8_0
- libedit=3.1.20240808=pl5321h7949ede_0
- libegl=1.7.0=ha4b6fd6_2
- libev=4.33=hd590300_2
- libexpat=2.6.4=h5888daf_0
- libfabric=1.22.0=ha770c72_3
- libfabric1=1.22.0=ha594dbc_3
- libffi=3.4.2=h7f98852_5
- libgcc=14.2.0=h77fa898_1
- libgcc-devel_linux-64=13.3.0=h84ea5a7_101
- libgcc-ng=14.2.0=h69a702a_1
- libgcrypt-lib=1.11.0=hb9d3cd8_2
- libgfortran=14.2.0=h69a702a_1
- libgfortran-ng=14.2.0=h69a702a_1
- libgfortran5=14.2.0=hd5240d6_1
- libgl=1.7.0=ha4b6fd6_2
- libglib=2.82.2=h2ff4ddf_0
- libglu=9.0.3=h03adeef_0
- libglvnd=1.7.0=ha4b6fd6_2
- libglx=1.7.0=ha4b6fd6_2
- libgomp=14.2.0=h77fa898_1
- libgpg-error=1.51=hbd13f7d_1
- libhwloc=2.11.2=default_h0d58e46_1001
- libiconv=1.17=hd590300_2
- libjpeg-turbo=3.0.0=hd590300_1
- libklu=2.3.5=ss783_hfbdfdfc
- liblapack=3.9.0=26_linux64_openblas
- libllvm19=19.1.6=ha7bfdaf_0
- liblzma=5.6.3=hb9d3cd8_1
- libmpdec=4.0.0=h4bc722e_0
- libnetcdf=4.9.2=nompi_h5ddbaa4_116
- libnghttp2=1.64.0=h161d5f1_0
- libnl=3.11.0=hb9d3cd8_0
- libntlm=1.8=hb9d3cd8_0
- libogg=1.3.5=h4ab18f5_0
- libopenblas=0.3.28=openmp_hd680484_1
- libopenvino=2024.6.0=hac27bb2_3
- libopenvino-auto-batch-plugin=2024.6.0=h4d9b6c2_3
- libopenvino-auto-plugin=2024.6.0=h4d9b6c2_3
- libopenvino-hetero-plugin=2024.6.0=h3f63f65_3
- libopenvino-intel-cpu-plugin=2024.6.0=hac27bb2_3
- libopenvino-intel-gpu-plugin=2024.6.0=hac27bb2_3
- libopenvino-intel-npu-plugin=2024.6.0=hac27bb2_3
- libopenvino-ir-frontend=2024.6.0=h3f63f65_3
- libopenvino-onnx-frontend=2024.6.0=h6363af5_3
- libopenvino-paddle-frontend=2024.6.0=h6363af5_3
- libopenvino-pytorch-frontend=2024.6.0=h5888daf_3
- libopenvino-tensorflow-frontend=2024.6.0=h630ec5c_3
- libopenvino-tensorflow-lite-frontend=2024.6.0=h5888daf_3
- libopus=1.3.1=h7f98852_1
- libpciaccess=0.18=hd590300_0
- libpng=1.6.45=h943b412_0
- libpq=17.2=h3b95a9b_1
- libprotobuf=5.28.3=h6128344_1
- libptscotch=7.0.5=h7ea1560_4
- librsvg=2.58.4=h49af25d_2
- libsanitizer=13.3.0=heb74ff8_1
- libscotch=7.0.5=ha3546ae_4
- libsodium=1.0.20=h4ab18f5_0
- libspqr=4.3.4=ss783_hae1ff0d
- libsqlite=3.47.2=hee588c1_0
- libssh2=1.11.1=hf672d98_0
- libstdcxx=14.2.0=hc0a3c3a_1
- libstdcxx-ng=14.2.0=h4852527_1
- libsuitesparseconfig=7.8.3=ss783_h83006af
- libsystemd0=257.2=h3dc2cb9_0
- libtheora=1.1.1=h4ab18f5_1006
- libtiff=4.7.0=hd9ff511_3
- libudev1=257.2=h9a4d06a_0
- libumfpack=6.3.5=ss783_hd4f9ce1
- libuuid=2.38.1=h0b41bf4_0
- libva=2.22.0=h8a09558_1
- libvorbis=1.3.7=h9c3ff4c_0
- libvpx=1.14.1=hac33072_0
- libwebp-base=1.5.0=h851e524_0
- libxcb=1.17.0=h8a09558_0
- libxkbcommon=1.7.0=h2c5496b_1
- libxml2=2.13.5=h8d12d68_1
- libzip=1.11.2=h6991a6a_0
- libzlib=1.3.1=hb9d3cd8_2
- llvm-openmp=19.1.6=h024ca30_0
- loguru=0.7.2=py313h78bf25f_2
- lz4-c=1.10.0=h5888daf_1
- matplotlib-base=3.10.0=py313h129903b_0
- metis=5.1.0=hd0bcaf9_1007
- mpi=1.0.1=mpich
- mpi4py=4.0.1=py313h7246b6a_1
- mpich=4.2.3=h239ebd3_102
- msgpack-python=1.1.0=py313h33d0bda_0
- multidict=6.1.0=py313h8060acc_2
- mumps-include=5.7.3=ha770c72_5
- mumps-mpi=5.7.3=hb595572_5
- munkres=1.1.4=pyh9f0ad1d_0
- mysql-common=9.0.1=h266115a_4
- mysql-libs=9.0.1=he0572af_4
- ncurses=6.5=he02047a_1
- nlohmann_json=3.11.3=he02047a_1
- numpy=2.2.1=py313hb30382a_0
- ocl-icd=2.3.2=hb9d3cd8_2
- opencl-headers=2024.10.24=h5888daf_0
- openh264=2.5.0=hf92e6e3_0
- openjpeg=2.5.3=h5fbd93e_0
- openldap=2.6.9=he970967_0
- openssl=3.4.0=h7b32b05_1
- packaging=24.2=pyhd8ed1ab_2
- pango=1.54.0=h861ebed_4
- parmetis=4.0.3=hc7bef4e_1007
- pcre2=10.44=hba22ea6_2
- petsc=3.22.2=real_hc5e87de_102
- petsc4py=3.22.2=py313h159419d_0
- pillow=11.1.0=py313h8db990d_0
- pip=24.3.1=pyh145f28c_2
- pixman=0.44.2=h29eaf8c_0
- pkg-config=0.29.2=h4bc722e_1009
- platformdirs=4.3.6=pyhd8ed1ab_1
- pooch=1.8.2=pyhd8ed1ab_1
- proj=9.5.1=h0054346_0
- propcache=0.2.1=py313h536fd9c_0
- pthread-stubs=0.4=hb9d3cd8_1002
- pugixml=1.14=h59595ed_0
- pycparser=2.22=pyh29332c3_1
- pyparsing=3.2.1=pyhd8ed1ab_0
- pysocks=1.7.1=pyha55dd90_7
- python=3.13.1=ha99a958_104_cp313
- python-dateutil=2.9.0.post0=pyhff2d567_1
- python_abi=3.13=5_cp313
- pyvista=0.44.2=pyhd8ed1ab_1
- qhull=2020.2=h434a139_5
- qt6-main=6.8.1=h588cce1_2
- rdma-core=55.0=h5888daf_0
- readline=8.2=h8228510_1
- requests=2.32.3=pyhd8ed1ab_1
- scalapack=2.2.0=h7e29ba8_4
- scipy=1.14.1=py313h3a69d60_0
- scooby=0.10.0=pyhd8ed1ab_1
- setuptools=75.6.0=pyhff2d567_1
- six=1.17.0=pyhd8ed1ab_0
- slepc=3.22.2=real_h754b140_300
- slepc4py=3.22.2=py313hb77a934_0
- snappy=1.2.1=h8bd8927_1
- spdlog=1.14.1=hed91bc2_1
- sqlite=3.47.2=h9eae976_0
- superlu=5.2.2=h00795ac_0
- superlu_dist=9.1.0=h0804ebd_0
- svt-av1=2.3.0=h5888daf_0
- sysroot_linux-64=2.17=h0157908_18
- tbb=2022.0.0=hceb3a55_0
- tk=8.6.13=noxft_h4845f30_101
- typing-extensions=4.12.2=hd8ed1ab_1
- typing_extensions=4.12.2=pyha770c72_1
- tzdata=2024b=hc8b5060_0
- ucx=1.17.0=h53fb5aa_4
- urllib3=2.3.0=pyhd8ed1ab_0
- utfcpp=4.0.6=h005c6e1_0
- vtk=9.3.1=egl_py313h3373a60_13
- vtk-base=9.3.1=egl_py313ha6db0fb_13
- vtk-io-ffmpeg=9.3.1=egl_py313h3373a60_13
- wayland=1.23.1=h3e06ad9_0
- wayland-protocols=1.37=hd8ed1ab_0
- wslink=2.2.2=pyhd8ed1ab_0
- x264=1!164.3095=h166bdaf_2
- x265=3.5=h924138e_3
- xcb-util=0.4.1=hb711507_2
- xcb-util-cursor=0.1.5=hb9d3cd8_0
- xcb-util-image=0.4.0=hb711507_2
- xcb-util-keysyms=0.4.1=hb711507_0
- xcb-util-renderutil=0.3.10=hb711507_0
- xcb-util-wm=0.4.2=hb711507_0
- xkeyboard-config=2.43=hb9d3cd8_0
- xorg-libice=1.1.2=hb9d3cd8_0
- xorg-libsm=1.2.5=he73a12e_0
- xorg-libx11=1.8.10=h4f16b4b_1
- xorg-libxau=1.0.12=hb9d3cd8_0
- xorg-libxcomposite=0.4.6=hb9d3cd8_2
- xorg-libxcursor=1.2.3=hb9d3cd8_0
- xorg-libxdamage=1.1.6=hb9d3cd8_0
- xorg-libxdmcp=1.1.5=hb9d3cd8_0
- xorg-libxext=1.3.6=hb9d3cd8_0
- xorg-libxfixes=6.0.1=hb9d3cd8_0
- xorg-libxi=1.8.2=hb9d3cd8_0
- xorg-libxrandr=1.5.4=hb9d3cd8_0
- xorg-libxrender=0.9.12=hb9d3cd8_0
- xorg-libxt=1.3.1=hb9d3cd8_0
- xorg-libxtst=1.2.5=hb9d3cd8_3
- xorg-libxxf86vm=1.1.6=hb9d3cd8_0
- yaml=0.2.5=h7f98852_2
- yarl=1.18.3=py313h536fd9c_0
- zeromq=4.3.5=h3b0a872_7
- zfp=0.5.5=h9c3ff4c_8
- zlib=1.3.1=hb9d3cd8_2
- zlib-ng=2.2.3=h7955e40_0
- zstandard=0.23.0=py313h80202fe_1
- zstd=1.5.6=ha6fb4c9_0
Unfortunately pyvista.OFF_SCREEN=False didn’t solve it
dokken
January 10, 2025, 8:27am
9
I cant reproduce this with an environment file:
channels:
- conda-forge
dependencies:
- pyvista
- adios4dolfinx
and
mamba env create -f environment.yml
and
cyl = pv.Cylinder()
p.add_mesh(cyl, color="lightblue", show_edges=True)
p.show()
Conda env export:
channels:
- conda-forge
dependencies:
- _openmp_mutex=4.5=2_gnu
- adios2=2.10.2=mpi_openmpi_py313h19e81a3_1
- blis=0.9.0=h4ab18f5_2
- ca-certificates=2024.12.14=hbcca054_0
- certifi=2024.12.14=pyhd8ed1ab_0
- fenics-dolfinx=0.9.0=py313hd2102f0_107
- fenics-libdolfinx=0.9.0=h3dd6bb7_107
- fftw=3.3.10=mpi_openmpi_h99e62ba_10
- hdf5=1.14.3=mpi_openmpi_h39ae36c_8
- hypre=2.32.0=mpi_openmpi_h398ea61_1
- kahip=3.17=hd8b01d5_0
- level-zero=1.20.0=h84d6215_0
- libadios2=2.10.2=mpi_openmpi_h5580805_1
- libblas=3.9.0=26_linux64_blis
- libcblas=3.9.0=26_linux64_blis
- libevent=2.1.12=hf998b51_1
- libfabric=2.0.0=ha770c72_1
- libfabric1=2.0.0=h14e6f36_1
- liblapack=3.9.0=8_h3b12eaf_netlib
- libnetcdf=4.9.2=nompi_h00e09a9_116
- libpmix=5.0.6=h658e747_0
- libptscotch=7.0.6=hb0c3d77_0
- libscotch=7.0.6=h4914014_0
- mpi=1.0=openmpi
- mpi4py=4.0.1=py313hffb1895_0
- mumps-include=5.7.3=ha770c72_6
- mumps-mpi=5.7.3=h80cd639_6
- openmpi=5.0.6=h3ee89b5_101
- pango=1.56.0=h861ebed_0
- parmetis=4.0.3=h02de7a9_1007
- petsc=3.22.2=real_hdb68103_103
- petsc4py=3.22.2=py313hc49d176_0
- scalapack=2.2.0=h16fb9de_4
- setuptools=75.7.0=pyhff2d567_0
- slepc=3.22.2=real_h221cefa_300
- slepc4py=3.22.2=py313h004cd3b_0
- superlu_dist=9.1.0=h3349319_0
- ucc=1.3.0=h0f835a6_3
- vtk=9.3.1=qt_py313h71fb23e_214
- vtk-base=9.3.1=qt_py313h245430a_214
- vtk-io-ffmpeg=9.3.1=qt_py313h71fb23e_214
prefix: /home/dokken/src/mambaforge/envs/pv-test
The biggest difference i can spot is:
My conda env uses blas not blis
openmpi vs mpich
Major version difference in libfabric (2.0 vs 1.22)
Maybe @minrk has any ideas here.
