Adios4dolfinx misreads written function
I am trying to solve wave equation using a mesh generated with gmsh. When adios reads the exported function, it mismatches with the solution. Here is MWE;
from ufl import FiniteElement, Measure, inner, grad, TrialFunction, TestFunction, dx
from dolfinx.fem import form, Function, FunctionSpace
from dolfinx.fem.petsc import assemble_matrix
from dolfinx.io.gmshio import model_to_mesh
from slepc4py import SLEPc
from pathlib import Path
import adios4dolfinx
import sys
import os
gmsh.option.setNumber("General.Terminal", 0)
gmsh.model.add(__name__)
cube = gmsh.model.occ.addBox(0,0,0, 1, 1, 1, tag=1)
gmsh.model.occ.synchronize()
gmsh.option.setNumber('Mesh.MeshSizeMin', 1)
gmsh.model.mesh.generate(3)
boundaries_entities = [i[1] for i in gmsh.model.getEntities(2)]
for tag, surf in enumerate(boundaries_entities):
    gmsh.model.addPhysicalGroup(2,[surf],tag)
gmsh.model.addPhysicalGroup(3,[1],1)
if '-nopopup' not in sys.argv:
    gmsh.fltk.run()
path = os.path.dirname(os.path.abspath(__file__))
mesh, subdomains, facet_tags = model_to_mesh(gmsh.model, MPI.COMM_WORLD, 0, gdim=3)
degree = 2
v_cg = FiniteElement("CG", mesh.ufl_cell(), degree)
V = FunctionSpace(mesh, v_cg)
c = 340
A = assemble_matrix(form(-c**2* inner(grad(u), grad(v))*dx))
C = assemble_matrix(form(inner(u , v) * dx))
C.assemble()
target = PETSc.ScalarType(2*np.pi*180)
E = SLEPc.EPS().create(MPI.COMM_WORLD)
C = - C
E.setOperators(A, C)
st = E.getST()
st.setType('sinvert')
E.setTarget(target**2)
E.setFromOptions()
E.solve()
A = E.getOperators()[0]
eig = E.getEigenvalue(0)
print("eig: ", np.sqrt(eig))
p_dir = Function(V)
p_dir_i = Function(V)
E.getEigenvector(0, p_dir.vector, p_dir_i.vector)
path_out = Path("adios_dir/checkpoint.bp")
# write it
adios4dolfinx.write_mesh(mesh, path_out, engine="BP4")
adios4dolfinx.write_function(p_dir, path_out, engine="BP4")
# read it back
mesh_import = adios4dolfinx.read_mesh(MPI.COMM_WORLD, path_out, engine='BP4', ghost_mode=dolfinx.mesh.GhostMode.shared_facet)
v_cg = FiniteElement("CG", mesh_import.ufl_cell(), degree)
V_import = FunctionSpace(mesh_import, v_cg)
p_dir_import = Function(V_import)
adios4dolfinx.read_function(p_dir_import, path_out, engine="BP4")
np.testing.assert_allclose(p_dir.x.array, p_dir_import.x.array, atol=1e-14)
gives;
AssertionError:
Not equal to tolerance rtol=1e-07, atol=1e-14
Mismatched elements: 41 / 63 (65.1%)
Max absolute difference: 0.34638213
Max relative difference: 2.94448321e+15
 x: array([ 8.114930e-16-7.606003e-15j, -7.413879e-02+1.565202e-01j,
       -7.519621e-02+1.587526e-01j, -7.413879e-02+1.565202e-01j,
       -7.005317e-02+1.478948e-01j, -6.627179e-02+1.399116e-01j,...
 y: array([ 8.114930e-16-7.606003e-15j, -7.413879e-02+1.565202e-01j,
I could not figure out what is wrong here. I am using dolfinx v0.7.3 and adios4dolfinx v0.7.2.
I feel like we have discussed this before. Here you assume that adios4dolfin reads in the mesh in the same way as it was created. Please use “original_checkpoint” i.e. write_function_on_input_mesh for this.
See: Checkpoint on input mesh — ADIOS2Wrappers
for a detailed description. This means that you actually do not need to store the mesh, but you can read the data directly in on your mesh object and V.
