Dear Fenics community,
I would like to apply a geometric constraint on a PDE defined over a 2D domain [0, R]x[0,L], namely u_1(L, x_2) = u_1(L, 0) for all x_2 . I introduced a lagrange multiplier p and wrote the following code:
definition of the mesh and the functionspaces:
mesh = RectangleMesh(Point(0.0, 0.0), Point(L, R), 300, 8)
V_element = VectorElement(‘CG’,triangle, 1)
V0_element = FiniteElement(‘CG’,triangle, 1)
V = FunctionSpace(mesh, V_element)
V0 = FunctionSpace(mesh, V0_element)
W_element = MixedElement([V_element,V0_element])
W = FunctionSpace(mesh, W_element)w = Function(W)
(u,p) = split(w) -
element of area to include informations about the boundary condition:
class Boundary(SubDomain):
return x[0]>L-R/20. and on_boundaryboundary_parts = MeshFunction(“size_t”,mesh, mesh.topology().dim()-1, 0)
my_boundary = Boundary()
my_boundary.mark(boundary_parts, 1)
my_ds = ds(subdomain_data=boundary_parts) -
expression assigned to 0 in the interior of the domain (the Lagrange multiplier p acts only on the surface):
Exp = Expression(‘x[0] < L ? 1. : 0.0001’, degree = 1) -
energy with Lagrange multiplier:
bulk_energy = bulk_energy_density(u) + Exp*inner(p,p))*dx
surface_energy = inner(p,(u[0] - u[0](L, 0)))*my_ds(3)
However, the syntax of the last line is wrong, and I wonder what the right syntax would be ?
thank you in advance for your help,
Kind regards,
Claire
