ArityMismatch: Adding expressions with non-matching form arguments ('v_1',) vs ('conj(v_1)',)
` Hello,
I have a similar issue with the one in this post Problem with use of a ufl function in a NonlinearProblem
I’m trying to solve an eigenvalue problem in FEniCSx with complex-valued functions, and I’m encountering an ArityMismatch error when trying to assemble the discrete matrices from the variational form.
ArityMismatch: Adding expressions with non-matching form arguments (‘v_1’,) vs (‘conj(v_1)’,).
Here, I post the respective code snippet:
v=ufl.TrialFunction(V)
w=ufl.TestFunction(V)
#Terms of left-hand side
grad_term= ufl.dot(grad_r(v, omega, domain), ufl.conj(grad_r(w, omega, domain)))
pot_term= ufl.dot((potential_r + beta * ufl.inner(phi, phi)) * v,ufl.conj(w))
beta_expression=(ufl.dot(ufl.conj(phi),v))
beta_expression_real= 0.5 * (beta_expression + ufl.conj(beta_expression)) # line that produces the error
beta_term=2*beta*ufl.dot(beta_expression_real*phi,ufl.conj(w))
#Left-hand side
lhs = (grad_term + pot_term + beta_term)*ufl.dx(degree=4)
# Right-hand side
rhs = ufl.dot(v, ufl.conj(w)) * ufl.dx(degree=4)
# Assemble the matrices
form_lhs = dolfinx.fem.form(lhs)
form_rhs = dolfinx.fem.form(rhs)
A=assemble_matrix(form_lhs,[bc])
B=assemble_matrix(form_rhs,[bc])
B.assemble()
Here, phi is a precomputed wavefunction, beta and omega some constants, and potential_r another interpolated function on the mesh.
The problem is with the computation of beta_expression_real, which causes incompatibility with the form arguments. Alternatively, when I tried intead to extract the real part of beta_expression by using ufl.real(), I encouter the following error:
ArityMismatch: Applying nonlinear operator Real to expression depending on form argument v_1.
Is there any recommended way to ompute the real part of beta expression?
I didn’t post the entire code, as I thought it might be too overwhelming, but in case it is needed let me know.
Could you provide a minimal working example up till that line with the error.
For instance, I do not know what is grad_r in your code.
Of course. Thank you for your answer. I tried to simplified the code and make it more accesible.
import math
from dolfinx import mesh, fem
from dolfinx.fem import Function
from ufl import SpatialCoordinate, grad
from dolfinx.fem.petsc import  assemble_matrix
#Create the mesh
xmin,ymin=-6,-6
xmax,ymax=6,6
h=0.025
divisions_x=math.ceil((xmax - xmin)/h)
divisions_y=math.ceil((ymax - ymin)/h)
domain = mesh.create_rectangle(comm=MPI.COMM_WORLD,
                               points=[[xmin, ymin], [xmax, ymax]],
                               n=(divisions_x, divisions_y),
                               cell_type=mesh.CellType.triangle)
topology=domain.topology
geometry=domain.geometry
# Get the number of nodes (vertices)
num_nodes = topology.index_map(0).size_local
coords = domain.geometry.x
#Create a function space
V = fem.functionspace(domain, ("Lagrange", 1))
#Insert boundary conditions (homogenous)
phi_D=Function(V,dtype=np.complex128)
phi_D.x.array[:]=ScalarType(0)
tdim = topology.dim
fdim = tdim - 1
topology.create_connectivity(fdim, tdim)
boundary_dofs = fem.locate_dofs_topological(V, fdim, boundary_facets)
bc = fem.dirichletbc(phi_D, boundary_dofs)
#Define L2 norm
def l2_norm(phi,quadrature_degree):
    l2_norm = dolfinx.fem.assemble_scalar(
            dolfinx.fem.form(ufl.inner(phi,phi) * ufl.dx(degree=quadrature_degree))
    l2_norm = np.sqrt(l2_norm)
    return l2_norm
#Covariant Gradient
def grad_r(phi,omega,domain):
    x=SpatialCoordinate(domain)
    R_T=ufl.as_vector((-x[1], x[0]))
    return ufl.grad(phi)+1j*(omega/2)*R_T*phi
#Rotational momentum operator
def Lz(phi,domain):
    x = SpatialCoordinate(domain)
    Lz_phi = -1j* (x[0] * grad(phi)[1] - x[1] * grad(phi)[0])
    return Lz_phi
#Harmonic trapping Potential
def Vtr(gamma_x, gamma_y,V,omega ):
    trap_potential = Function(V)
    trap_potential.interpolate(
        lambda x:
        ((gamma_x**2 * x[0]**2 + gamma_y**2 * x[1]**2))-1/4*(omega**2)*(x[0]**2 +  x[1]**2)
    return trap_potential
#Solution function
def phi_init(omega,V,quadrature_degree):
    phi_0=Function(V,dtype=np.complex128)
    phi_0.interpolate(
        lambda x:
            (1 - omega) * (1/np.sqrt(np.pi)*np.exp(-(x[0]**2+x[1]**2)/2))\
            + omega * (1/np.sqrt(np.pi) * (x[0] * np.exp(-(x[0]**2 + x[1]**2)/2) + 1j * x[1] * np.exp(-(x[0]**2 + x[1]**2)/2)))
    l2_norm_phi_0=l2_norm(phi_0,quadrature_degree)
    phi_0.x.array[:] /= l2_norm_phi_0
    return phi_0
#Set parameters
omega=1.4
beta=200
gamma_x=1.1
gamma_y=1.0
potential_r= Vtr(gamma_x, gamma_y,V,omega)
potential= Vtr(gamma_x, gamma_y,V,0)
#Set solution function
phi=phi_init(omega,V,quadrature_degree=4)
#Define variational problem
#Left-hand side
# Right-hand side
B.assemble()
I tried running your code and got the following error:
tmp: for the --non-global-value-max-name-size option: may only occur zero or one times!
  File "/home/marazzato/PostDoc/Coding/arity.py", line 97, in <module>
  File "/home/marazzato/PostDoc/Coding/arity.py", line 83, in phi_init
  File "/home/marazzato/PostDoc/Coding/arity.py", line 47, in l2_norm
  File "/usr/lib/petsc/lib/python3/dist-packages/dolfinx/fem/forms.py", line 249, in form
    return _create_form(form)
  File "/usr/lib/petsc/lib/python3/dist-packages/dolfinx/fem/forms.py", line 244, in _create_form
    return _form(form)
  File "/usr/lib/petsc/lib/python3/dist-packages/dolfinx/fem/forms.py", line 229, in _form
    f = ftype(
TypeError: __init__(): incompatible function arguments. The following argument types are supported:
    1. __init__(self, spaces: list[dolfinx.cpp.fem.FunctionSpace_float64], integrals: dict[dolfinx.cpp.fem.IntegralType, list[tuple[int, int, ndarray[dtype=int32, writable=False, shape=(*), order='C']]]], coefficients: list[dolfinx.cpp.fem.Function_float64], constants: list[dolfinx.cpp.fem.Constant_float64], need_permutation_data: bool, entity_maps: dict[dolfinx.cpp.mesh.Mesh_float64, ndarray[dtype=int32, writable=False, shape=(*), order='C']], mesh: Optional[dolfinx.cpp.mesh.Mesh_float64]) -> None
    2. __init__(self, form: int, spaces: list[dolfinx.cpp.fem.FunctionSpace_float64], coefficients: list[dolfinx.cpp.fem.Function_float64], constants: list[dolfinx.cpp.fem.Constant_float64], subdomains: dict[dolfinx.cpp.fem.IntegralType, list[tuple[int, ndarray[dtype=int32, writable=False, shape=(*), order='C']]]], entity_maps: dict[dolfinx.cpp.mesh.Mesh_float64, ndarray[dtype=int32, writable=False, shape=(*), order='C']], mesh: Optional[dolfinx.cpp.mesh.Mesh_float64]) -> None
Invoked with types: dolfinx.cpp.fem.Form_float64, _CDataBase, list, list, list, dict, dict, dolfinx.cpp.mesh.Mesh_float64
Could you simplify your code further? Only putting in what creates the error you are asking about?
Yes, I can do this. Here’s the minimal code to reproduce the error:
# Create mesh
domain = mesh.create_rectangle(MPI.COMM_WORLD, [[-6, -6], [6, 6]], [480, 480], cell_type=mesh.CellType.triangle)
# Define complex function
phi = fem.Function(V, dtype=np.complex128)
phi.interpolate(lambda x: 1 + 1j * x[1])
# Variational problem
v, w = ufl.TrialFunction(V), ufl.TestFunction(V)
expression = ufl.dot(v, ufl.conj(phi))
expression_real = 0.5 * (expression + ufl.conj(expression))  # Error source
lhs = ufl.dot(expression_real * phi, ufl.conj(w)) * ufl.dx
# Assemble the matrix
A=assemble_matrix(form_lhs)
Currently you end up mixing conj(v) and v in the same form (due to expression_real), this is not supported in UFL
What kind of strong form of a PDE are you considering as you need this?
This is the strong form of the eigenvalue problem, I am trying to solve:
-\Delta v + \left(V_R + \beta |\phi|^2\right)v + 2\beta \operatorname{Re}(\phi v)\phi = \lambda v ,
where:
\beta a real constant, \phi a pre-computed complex valued function on the mesh and V_R another real valued interpolated function.
\operatorname{Re}(\phi v).
In the weak form with v being the trial function, ufl.real() results in an error, as nonlinear operator on a form argument and if I extract the real part as
\frac{\phi v + \overline{\phi v}}{2}
I end up mixing conj(v) and v.
The problem here doesn’t fall under the natural complex number abstraction in UFL.
Consider the following:
\int_\Omega u \cdot \bar{v}~\mathrm{d}x=\int_\Omega f \cdot \bar{v}~\mathrm{d}c
If we want to solve this with «complex numbers» in dolfinx, we have the following anzats
u=\sum_{i=1}^N c_i \phi_i(x) where c_i=a_i+1j*b_i, a_i, b_i\in\mathbb{R}
and \phi_k:\Omega\mapsto\mathbb{R}.
Inserting this into the above equation, you would get
Ac=B
where
A_{ji}=\int_\Omega \phi_i(x)\phi_j(x)~\mathrm{d}x
b_j = \int_\Omega f \cdot \phi_j~\mathrm{d}x
If you would introduce a term \int_\Omega\mathrm{Re}(u)\cdot\bar{v}~\mathrm{d}x it wouldn’t fit into a row of the aforementioned A as you would only have coefficients a_i, not b_i.
To solve your problem, you could:
  1. split your problem into two real valued function spaces, one for a_i and another one for b_i.
  2. Write out your variational for with this split, and gather all real valued terms in one block of the matrix, all complex valued in another. You can then get a real valued matrix system coupling a and b
