i am trying to implement the Green-Lagrange-Strain into my 3D-Problem.
As long as i use the InfinitesimalStrain and the PK2_lin stress tensor everything works out quite well, but when i try to use the GreenLagrangeStrain with PK2, i get the following error message:
ArityMismatch: Adding expressions with non-matching form arguments () vs (βv_0β,).
# import modules
# define geometry & parameters
thickness = 50e-6 #thickness in m
diameter = 1.5e-3 #diameter in m
radius = diameter/2
E = Constant(330e6) #Young's Modulus in Pa
nu = Constant(0.25) #Poisson's ratio
mu = Constant(E/(2.0*(1.0+nu)))
lmbda = Constant(E*nu/((1.0+nu)*(1.0-2.0*nu)))
# mesh geometry
No_Segments = int((diameter/thickness)+1)
membrane_domain = Cylinder(Point(0, 0, 0), Point(0, 0, thickness), radius, radius, 100)
mesh = generate_mesh(membrane_domain, No_Segments)
#defining subdomains
class Bottom(SubDomain):
return near(x[2], 0.0) and on_boundary
class Top(SubDomain):
return near(x[2], thickness) and on_boundary
class Outer(SubDomain):
return near(sqrt(x[0]*x[0]+x[1]*x[1]), radius, 4e-6) and on_boundary
#define function space for displacement, velocity and acceleration
V = VectorFunctionSpace(mesh, "CG", 1)
#test and trial functions
du = TrialFunction(V)
u_ = TestFunction(V)
u = Function(V, name="Displacement")
# define subdomains
boundary_subdomains = MeshFunction("size_t", mesh, mesh.topology().dim()-1)
boundary_subdomains.set_all(0) #mark all with '0'
outer = Outer()
outer.mark(boundary_subdomains, 1)
top = Top()
top.mark(boundary_subdomains, 2)
bottom = Bottom()
bottom.mark(boundary_subdomains, 3)
#define measure for boundary condition integral
dss = ds(subdomain_data=boundary_subdomains)
#set up boundary condition on outer region (dirichlet)
zero = Constant((0.0, 0.0, 0.0))
bc = DirichletBC(V, zero, outer)
bcs = [bc]
file = XDMFFile("example/results.xdmf")
file.parameters["functions_share_mesh"] = True
file.parameters["flush_output"] = True
file.parameters["rewrite_function_mesh"] = False
def InfinitesimalStrain(u):
return variable(0.5*(grad(u) + grad(u).T))
def PK2_lin(u):
epsilon = InfinitesimalStrain(u)
psi = lmbda/2*(tr(epsilon)**2) + mu*tr(epsilon*epsilon)
S = variable(diff(psi, epsilon))
return S
def GreenLagrangeStrain(u):
d = len(u)
I = Identity(d)
F = I+grad(u)
C = F.T * F
E = 0.5*(C - I)
return E
def PK2_GLS(u):
E = GreenLagrangeStrain(u)
psi = lmbda/2*(tr(E)**2) + mu*tr(E*E) #St. Venant Kirchhoff material
#E = variable(E)
S = variable(diff(psi, E))
return S
#form compiler options
p0 = 200000 #load amplitude in Pa
p = Constant((0, 0, p0))
#elastic stiffness form
def k(u, u_):
return inner(PK2_lin(u), InfinitesimalStrain(u_))*dx
#return inner(PK2_GLS(u), GreenLagrangeStrain(u_))*dx
#work of external forces
def Wext(u_):
return dot(u_, p)*dss(3)
res = k(u, u_) - Wext(u_)
J = derivative(res, u)
problem = NonlinearVariationalProblem(res, u, bcs=bcs, J=J)
NLsolver = NonlinearVariationalSolver(problem)
NLsolver.parameters['newton_solver']['relative_tolerance'] = 1e-6
NLsolver.parameters['newton_solver']['linear_solver'] = 'mumps'
NLsolver.solve()
file.write(u, 0)
The used measures of stress and strain are defined in the elastic stiffness form at the end section of the code.
Do i have a general mistake in my formulation?
Any help to resolve this would be great
Thanks in advance!
Joey
